Everything posted by ocei77
Can i build a frankenmotor with a dohc ej25?
ocei77 replied to comatosellama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo offense, but if you don't know what/and where a hg is, you should not be attempting this. Insofar as DOHC heads on an EJ22, which would be boost friendly, go to legacygt.com and look up posts by DOHCEJ22e and you'll find complete info on this particular hybrid. Do search on frankenmotor for the other way around. O.
Help with Swap.
A friend blew his 2000 2.5 SOHC. I am going to give him my 96 2.5 DOHC short block. I know to use his heads, intake manifold, sensors and tensioner bracket. Also to block the egr port if his doesn't have egr. My question is, is it ok to use the ej25 turbo gasket (642) or is another thickness required as this was the only year that the head design required premium gas. thx in advance. O.
2001 2.5 sohc splitting the case to do bearings & rings
ocei77 replied to montana tom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurning the crank would make the job easier, then you can get one size bearing as they are not the same from the factory.(This adds to cost) Subaru , King or ACL for bearings, your choice. NPR for rings, keep the pistons. Engine gaskets from Fel Pro and the odd O rings from Subaru. O.
Forester door handle removal help needed!
ocei77 replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnce the panel is removed. Lower the window. At some point (maybe halfway) the bolts will be accessible. Just look at it as you lower, you'll find that point. O.
EJ22 Water Pump Removal
ocei77 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo you do not. Just need to disconnect the bypass pipe and radiator hoses and the bolts. Wiggle or pry to remove. Only use a metal gasket on install. I use a little sealant to hold the gasket in place as I work it back on. O.
99 legacy outback ej25 manual cylinder head torque settings
ocei77 replied to Shaggysubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse attached link for FSM and go from there. . O. fsm.txt
Left hand threads?
ocei77 replied to scatgo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have not removed the t belt, lock the flexplate if auto or block flywheel if mt. Should be a lot easier then. If t belt already removed, take off valve covers and hold the flat part of cam with an open end.. O.
P0483
ocei77 replied to Zoom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the meanwhile use the Subaru "conditioner" to help slow the external hg leak. Make sure the system is full. Once it gets hot and pushes into the overflow, you have to do everything to make sure the block side has coolant and minimal air. Stant makes an Xacstat #(not positive of number 474.....) that is the same as Subaru's unit. O.
Subaru RS 2009 MY10 P0420 error code?
ocei77 replied to PitBull07's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't know of this "fix". Generally (tho not always) this code is related to the 2nd O2 sensor. The fix for this is to replace that sensor. Many have resolved this issue with a spark plug spacer .if there is room to mount. Do search for P0420. O.
AT OIL TEMP - LOSING FLUID
ocei77 replied to mannixconnors's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it's disappearing it must be leaking somewhere. He can clean off the bottom of engine and tranny pan as best he can, then park over clean cardboard and trace back to the leak. Definitely have him check the small hoses from the cooler. O/
Son wants to take 2001 Forester cross country. What maintenance should I have performed?
ocei77 replied to nitroman58's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave him take a spare alternator belt and tools needed to change it (12mm socket). If he doesn't know how, show him. Few things worse than being stuck in the middle of nowhere and being hosed by someone over a $15 belt. O.
Legacy Brighton
ocei77 replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBrightons also had rear drums not discs O.
Head gasket! :(
ocei77 replied to Genedoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru's 2.2 gaskets are composite but the 2.5's are MLS. Replacement preferences, Subaru, Six Star, Cometic and then Fel Pro. IMO. Many times your dealer will come close to price matching an online price and it saves the shipping plus wait time. O.
Starts w/ 2.5 ecm not w/ 2.2 ecm?
ocei77 replied to YJ4000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is an egr workaround. Do a search on legacygt.com. Will have pics etc. O.
Rolled 2004 Legacy, no start, ideas?
ocei77 replied to a57oval's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a rollover valve in the tank piping. Never had occasion to deal with it. I'd call a dealer and ask if it has/needs to be reset and if so how. Spark? Timing correct.? No fuel? Any codes in the system? O.
Headlamp assembly upgrade
ocei77 replied to Hcm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf necessary just splice the correct plug end. O.
1999 forester power locks lock randomly and repeatedly
ocei77 replied to fishernut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemote has lost its program. Go to cars101.com and see remote section.to reprogram. Happens when you lose battery connection. O.
blinking ATF light on dash
ocei77 replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for reminding me that 95 Suby's are OBDII O.
ocei77 replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a code stored for a transmission fault. Do a search for how to read transmission codes via handshake method. Will determine exactly which one you have. If you turn in slow hard circles does the tranny bind? O.
Replacing entire exhaust on a 2000 Legacy?
ocei77 replied to Smo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWorking in a yard, no lift and no air tools look at about an hour. If you can take a portable drill with a cut off wheel it'll make life easier. O.
Is the left or right front tire the dominant driven tire? Or does it change?
ocei77 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^ Thanks for this detailed explanation O.
No Spark
ocei77 replied to scatgo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 99 Forester should be the same as the same as the 2000 Legacy. Look under my name in the new gen faq sticky above. Has links for fsm. O.
ocei77 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^?????? Not sure I get this answer. ie What if all four tires are the same? Can't say this is definitive, ( I only remember 3 occasions, an 07,a 96 and a 99), but with all four wheels off the ground and the car in gear, the left front and the right rear turns until and unless you start the others to turn, then they will remain doing so. O.
95 Legacy L timing belt job.
ocei77 replied to nicholi2789's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn a car this age it's probably your separator plate that is leaking. Only way to fix is to pull engine and replace with the updated unit. Til then you'll have to live with the burning oil. O.
