45
Everything posted by carfreak85
I was reading an article on this subject and it appears that VW is also building each TDI powered vehicle at a several thousand dollar loss per vehicle in an effort to corner the U.S. diesel market. Plus we have tons more sulfer in our gas than they do in Europe. I think the 2.0TD would be a hit in this market (I would buy one, after a year to let Fuji work all the bugs out) but it is sad they aren't bringing it. On the other hand, they have responded to our complaints in the past, 2002 WRX=too ugly2008 WRX=too soft, etc. So there is still hope.
Best place to buy EA81 transmission mounts
carfreak85 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Found them. For future reference, they are under "Engine", "Engine Mounts", "Rear with M/T", and yes they are cheap, approx $11 per mount. -
Turbo Traction Coupe !!
carfreak85 replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Great looking coupe, I'm glad someone stepped up to save another turbo! Until you find a replacement hardline or get the original one brazed, just don't drive the car. More pics please!!! -
Any updates? Were you able to find parts to rebuild the steering rack/pump?
I have an EA82 flywheel and clutch between my EA81T and 5 speed DR. I needed shims for the bolt holes because the EA82 bolt holes are larger than on the EA81 flywheel.
Repost....this time with numbers
carfreak85 replied to Turbone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Super cool thread Rob! Must be fast as all get out versus the stock RX. Makes me jealous and curious at the same time to see what my pathetic EA81T can spin out. -
Siiiiiiiiiiick!!! Probably one of the only non-GC/GD based vehicles to have operational DCCD, period... Very cool stuff. Any more insights into the benefits of this new tool of mayhem?
My newest J/Y find...
carfreak85 replied to Twitch de la Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
After going through my own digi-dash dilemma and had to weigh my options. I could repair my original dash, source a used pre-owned unit, build my own gauge panel or swap to the analog cluster. I decided to keep my car as original as possible and that meant using as many factory parts as possible. I swapped in the analog cluster from a lower trim EA81T wagon and in doing so, was forced to install the matching analog dash harness. While it wasn't truly "plug-and-play" all the swap required was unplugging a bunch of electrical connectors and snaking the harness out from behind a sharp, metal dashboard while keeping my fingers and my harness intact. I also had to manufacture a few jumper harnesses to connect a few components. (Brake switches, found a spare power source for some aftermarket parts, etc.) I just went to the junkyard and harvested a few sets of OEM male/female connectors to use, in case I ever had an oppourtunity to swap back to the digi set up. The swap took me a few weeks of working on it, along with a ton of other related projects for last year's WCSS. I wouldn't recomment it to the novice mechanic, but it is by no means an impossible task. If you're sick of swapping in new digi-dashes as each old one finally croaks, take a look into finding the space and the parts, after mine was done, it looked great! It was more functional, easier to read and more reliable than the digi dash. I did lose the dual trip meters and the timer, but being able to read the engine RPM and vehicle speed over a long trip were more important to me, given the questionable durability of the originally installed digital dash. Still have all the old parts too, and another vehichle to potentially swap over. If I do, I promise to do a better job documenting it than with the first conversion... http://www.ultimatesubaru.org/forum/showthread.php?t=89603&highlight=digi+analog+harness&page=3 -
digi dash clock flashing
carfreak85 replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Chuck the digi in the rubbish bin and throw and analog harness and gauges in its place. That's what I did, and besides the fuel level being off, everything works just fine. -
FOUND! 1983 ea81 turbo coupe at junkyard
carfreak85 replied to LuberJack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If money were no object I would just buy it outright for a parts car, but I've got no money for car parts as it is. -
83 Coupe Love ..Restore Progress ( Pics page 2)
carfreak85 replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Let me know what your body shop ends up doing about those sunroof mounts. Mine look about the same and I'll need to get them fixed sooner than later... -
Whatever happened to these wheels?
70's AM/FM Radio search - gather 'em up!
carfreak85 replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
Next time I'm home I'll see what we have kicking around. Might have one, two or even three... -
VERY cool looking wagon! Doesn't look like its missing anything!
Subaru 360 van Dyno day
carfreak85 replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
Sweet. You might be the first person to put a 360 on a dyno for the purposes of measuring power! -
Someone's looking to get banned from the Meet and Greet. . .
Very cool, did you have fun? I've been autoxing for a few years now and it is a blast! Only advice I have is get more time behind the wheel, and ask an experienced driver to ride along with you a few times to give you pointers. Oh, and work on your hand-to-wheel placement.
Gen 1 brat with hard cover / louvers!
carfreak85 replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What percentage of a complete cover would you say you have? If I could someday borrow the pieces to make new molds, I would happily lay one up for you pro bono, so that I could have one for my BRAT eventually. Several other covers could be pulled from those molds for interested parties. I just need to raise the fiberglass skills and funds first... -
Just a couple suggentions/opninion on my part. 1) I autox and the ABS in our STI and even in our WRX allowed me to brake later and under more control than in my EA81, especially in the rain, but also on a dry track. 2) If you enjoy rallying or spirited driving on gravel, deactivating ABS will allow you to stop faster. 3) I'm a Vehicle Design major and can tell you that while ABS might be annoying to some drivers, in most cases it is benificial, and isn't going away any time soon, so get used to it guys and gals. 4) Don't follow so closely that you need to slam on your brakes. That is the easist way to a) avoid an accident and to not activate the ABS.
I'm going to be doing the same thing on my hatch soon. Could you give me a lead on where to find those parts you plan on using for the rebuild?
Do yourself a favor and leave the BOV off your list. If you're lucky you can find a used WRX intercooler that still has the BPV on it. The mods you listed should get you close to your power goal.
