Everything posted by ivantruckman
'90 Loyale Coolant Leak (photo)
ivantruckman replied to BANgLE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+ 1 on water pump seals, theres a wheep hole at the bottom of the pump. cheaper to replace the whole pump. i got this one last week, http://cgi.ebay.com/ebaymotors/SUBARU-WATER-PUMP-DL-GL-GL-10-RX-XT-BRAT-1-8L-1985-1991_W0QQcmdZViewItemQQhashZitem3a57b5032cQQitemZ250579583788QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories -
the inner tie rods just unscrew, they have a washer that bends over the joint to keep it from coming loose . its real simple. this thread has pics http://www.ultimatesubaru.org/forum/showthread.php?t=97513
found this thread below
Wheel Bearing Question
ivantruckman replied to SubaruWagon87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
most everything is made in china now anyway, chinas quality is better than it use to be, i buy alot of ebay chinese stuff -
running rough and hicupping or popping
ivantruckman replied to akc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the rotor screw. it may have come loose -
you may have recieved a different splined axle shaft, ?
Wholly Rock Crawler, nice set up, your doing alot of reasurch for when we cant find any loyales or gls to tear up.. thanks man
is your avetar a picture of "che" the cuban revolutionary ?
custom bumpers - 86 gl wagon
ivantruckman replied to Kartier's topic in Old Gen.: 80's GL/DL/XT/Loyales...
they have an awsome post in the off road section, people submit pics of there bumpers, lots of ideas there -
1989 GL Sedan - Dead AT or Diff?
ivantruckman replied to cocheeze's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the differential and transmission are 1 unit, referred as a trans axle, switching from an auto to a manual is a little more involved, you have more parts to swap out, like petal Assembly's, and a few other odds and ends. its not hard, not sure if you can find a 2 wheel drive auto easily. . having owned both , the manual trans is better on gas .and less hi way rpms makes it quieter on freeways. i still run an auto 2 wheel drive wagon, for short city driving , when it blows up ill probably change it to a 5 speed, i have had alot of the auto transmissions fail just like yours did. sorry to confuse you with more opinion. -
Loss of power 86 ea82
ivantruckman replied to groningaj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is this a carburated 86 , 4x4 . fuel injected ? any more info may help to diagnose, -
what do you use to remove decal glue residue?
ivantruckman replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
they work awsome, harbor freight has them too ebay http://cgi.ebay.com/ebaymotors/Pinstrip-Decal-ERASER-REMOVER-Brand-new-in-package_W0QQcmdZViewItemQQhashZitem3a580d1e47QQitemZ250585357895QQptZMotorsQ5fAutomotiveQ5fTools -
Bill & Teds Excellent Subaru
ivantruckman replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
haahaahaa awesome I do that all the time, my wife says "what Subaru" i can identify them by fender, tail light etc. how small of a screen shot,( like just a turn signal in the screen) does it Take to id a Subaru. lol -
Crank pulley...what about a gun?
ivantruckman replied to Loyale93v's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thats allot of disassembly to go thru. you could try to use a screwdriver or punch in the flywheel. and a big breaker bar, you can take the rubber plug off the top of the trans to get access, sometimes there a big problem. someone probably used lock tight on it. they come off all the time -
sexy red wagon. 400 bucks.. righteous
Ive sectioned in 14 Gage sheet metal. it was time consuming, and i did get some flack for it, like junk it and come to Washington state and get a rust free one cheap. there probably right . but i couldn't let her go. the east is very hard on these cars. end result http://www.ultimatesubaru.org/forum/showthread.php?t=98130
Tires for offroad... Hmmm what do I buy?
ivantruckman replied to Scott in Bellingham's topic in Off Road
super swampers rock. good price on a tuff tire ..tsl tires are made in a 27" x 15 for us little 4 inch lift guys http://www.summitracing.com/search/?keyword=ict-ssr-03r&dds=1 -
it sucks for sure , but those picks are awesome
Ive had similar issues with the coolant temp sensor wire corroding. is was worse when it was cold outside
