Everything posted by SubaruWagon87
Not to threadjack, but do you have any more info about it Phiz?
Thanks
I'm in the middle of a 5-speed swap and I need to know, what viscosity, and how much gear oil do I fill it with? Said trans is out of an '86 wagon.
EA82 heater core
SubaruWagon87 replied to SubaruWagon87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dang. I was hoping it wouldn't take that long. Thanks for the walk-thru tho. Sounds like a project for tomorrow -
Is there a how-to anywhere around here on how to replace a heater core (in an 87 GL wagon)? I have an 86 parts car, would the cores interchange?
I might have a wagon that I'm getting rid of in a few weeks, minus the drivetrain and some interior bits...
Proof: It does get dirty!
SubaruWagon87 replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice! Even in the same spot subarutex wheeled his wagon! -
Rather than start a new thread, I'll bump this one back up. I was going to replace the valve cover gaskets, but when I crawled underneath to check things out, it appears that the driver's side cam seal is what's leaking (I can watch oil drip when the car's running). How hard is it to replace the cam seals?
Very nice! Now you need some pictures of it in action!
What about NW Subarus? Or NW Offroad Subarus?
So, last week I was out working in the canyon that goes from ellensburg to yakima, and I saw a yellow ea82 wagon, with yellow rims, and it was pulling a little camper trailer (also yellow), shaped kinda like a bean, heading from yakima to ellensburg. I remember reading about it somewhere (but I cant remember where). Does anyone have any info on it?
how do i take off this fan?
SubaruWagon87 replied to Markus56's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You should be able to loosen the nuts () with a 10 mm wrench. If you can't hold it from spinning, try sticking the belt back on to hold the pulley. If that doesnt work, a screwdriver or small prybar wedged in between 2 of the bolts should do the trick. I'm not sure what would have caused that, maybe something smacked the timing belt cover causing the pulley to break? I'd say if the cam still spins, you're ok, but I'm sure someone else will chime in. -
Heres a pretty good list of what compressors came in what car: http://www.dakuda.com/jeep/tech/yorkchart.html
I've been doing some reading on using a york for on board air, and it seems to me like the most logical choice. Yeah, stock a/c compressors bolt in, but you have to run another filter to filter out the oil from the air being compressed, but I want a challenge. And from the looks of it, I can build an on board air system for around $100 or less.
I picked up a 2 ton garage jack for $16 the other day, and it seems to work just fine. I was going to pick up a couple sets of jackstands, but for $15 a pair, I'm not sure if I'd trust my life to them. Has anyone had any luck with them? Or is there another cheap-ish brand thats trustworthy?
Ok, so I've decided not to do a reseal, it looks like its only leaking oil thru the valve cover gaskets, which a set came with the car, so I'll be replacing them later today. I made it run a little better by swapping in a carb from my other soob, but it dies if I don't keep giving it gas. It seems like its a vacuum issue. Which brings me to my question, what vacuum lines does the car need to run?
Is there a thread on how to convert an ea82 ac compressor to be an air compressor for on board air? Or is there a write up somewhere? I tried searching, but the search wouldn't look up "on" and "air".
365 Subarus (2010) [dates added]
SubaruWagon87 replied to SubaruWagon87's topic in Products for your Subaru
Here are the dates that have been reserved so far: Jan 18th & 20th Feb 7th Mar 1st July 2nd & 4th Aug 21st, 25th & 31st Sep 12th & 17th Oct 16th, 23rd & 24th Dec 13th & 30th
