CNY_Dave
5
Everything posted by CNY_Dave
On one of mine, the handle felt like the cable was not attached, and it was the locking mechanism keeping it 'disengaged'. Try cycling the lock about 10 times. Is there a small removable panel on the inside to access the latch? I have had to pull off the internal panels from below the window to get to a stuck latch. Broken bits usually result, trick is to be as gentle as possible.
That pushes-coolant-out-after-a-hard-drive was my first sign of an internal head gasket problem. You can drive on it for a long time that way, only real reason I stopped driving mine was that it needed a fair bit of work to pass inspection, and I wasn't willing to do all that work on a car with a bad head gasket with a rough body, when the car needed 4 struts, all brakes, all the rubber suspension bushings, etc etc. But mine actually never overheated, even after driving on the leaking head gasket for awhile.
My '05 forester has the same fuel-fill tube problem. I made the diagnosis 100% sure by gutting an old gas cap, affixing a piece of hose to it, put it on the car, and blew smoke from a cigar (from my mouth) into the hose, and watched where the smoke came out. Just keep the cigar/cigarette etc well away from the car... get a mouthfull from away a bit then go to the car.
If you put a 2000 trans into a 2004, the transfer solenoid may function backwards. Not sure if this is H6 cars only or H4s as well. On mine: I put a '04 trans into an '03 and the AWD only kicked in when the fronts spun a lot, then it banged in. 03 trans, +12V to solenoid releases the rears, 0V locks the AWD. 04 trans, +12V to solenoid locks the AWD, 0V releases the rears. If this is the case on yours, for low lockup the TCU will be sending out short pulses that average out to a low voltage, which the older trans will see as signal for a lot of lockup. For high lockup it will be disengaging the AWD. If you put in the FWD fuse and the AWD is locked you know it's reversed. On mine, I had to swap the solenoid and solenoid valve (and the valve plate) in the tail section.
I work with a guy that used to work in a literal salt mine, underground, salt in air and high humidity. He said all the fancy crap they would use on electrical connections sucked compared to dielectric grease, so I'm giving it a try when a convenient test case comes along. I wouldn't say use it where actual lubrication is required, but if something just has to sit there and look pretty I'll give it a shot!
You might have to swap the '05 AWD transfer solenoid and valve over, and there might be a worse incompatability between the trans and the TCU. For outbacks I know starting in '04 on those the transfer solenoid valve/tcu worked backwards (12v locked vs the 12v slipping of '03 and earlier). In '05 didn't they start putting the transfer solenoid and valve in the pan area?
I have used, to good effect: Aluminum duct tape backed by hose clamps (just make sure the clamp forms a 'heat sink' over the hole) small holes plugged with the white hardening sealant 1/2 sections of pipe (or bent sheet metal) over a blob of the sealant, held in place by hose clamps The small holes I've dealt with have usually been from a welded-on hanger ripping out. Good pipe around a rusty strip or hole the size of a dime or so.
Anything in the rear section can be done with trans in place, but looking at mileage plus price of parts vs jdm trans, jdm trans looks pretty good.
- 10 replies
- torque bind
- transmission
(and 3 more)
Tagged with:
