Everything posted by EVOthis
Need some quick answers....
EVOthis replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfirst check the obvious.......spark, fuel and air.......ive ran across situations were it could be a couple of things.........fuel pump, cam sensor, ignitor, crank sensor,even a loose wire.....etc.......when it doesnt start does it crank at all? how many miles on the car? what kind of engine?
Speaker replacements for 97 Legacy
EVOthis replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi did all my speakers last year in my 96 legacy......the front door speakers are 10xs easier to do than the rears which are located in the deck lid.........i had a heck of a time trying to get the deck lid cover off in one piece....than after i did get it off the kid who had it before me i believe retrofitted 6x9s in there....if i were you if you dont have that much time i would replace the front.......i do def. notice a sound difference with my new speakers.......if your looking at a specific brand may i recommend sony.....every one else i talk to says sony is junk but i have never had a single problem....... 8 out of the 14 speakers in my legacy are sony and it sounds amazing.......
Only 2 hours left......
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthats really cool subaru 360....was it the first subaru in the US?....i was reading something the other day about subaru being formed in like 1954 but they didnt say what year they brought the first subaru into the states.....
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat is nuts.....what is the top speed like 60mph.. still kind of a cute car though....
250k
EVOthis replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice...hopefully i will be as lucky...today actually i just rolled over to 192,000 on my 96 legacy....you said it man "all thanks to the EJ22"......
ej 18 slight rod knock at high rpms
EVOthis replied to subaruguru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim sure its possible that it is stretched......if you have done the t-belt on the ej22 i dont think the ej18 is all that much different if at all.....that is alot of miles......do you have any history on the car in terms of engine work?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah i never got a close up look at one except at the philly auto show and even then there were way to many people around to get a good look......
http://cgi.ebay.com/ebaymotors/Subaru-360_W0QQitemZ190219838354QQcmdZViewItem?hash=item190219838354&
universal o2 sensor
EVOthis replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXperfect example....my o2 sensor got ripped off my 96 legacy (long story) so i just soldered it back in place and it lasted for about another year and than i started getting a CEL with o2 sensor code.....chances are it was the original so i wasnt to hesitant about spending the $125 from subaru for a direct fit one......
Overheating on 90 Legacy, your opinions please
EVOthis replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso did you open the little bleeder on the top of the radiator? or burp the system properly....yes i would do a combustion leak test on it to see if you have exhaust gas getting into your coolant......
p0446
EVOthis replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe entire evap system helps remove vapors in fuel system...i believe the control/purge valve opens and closes the system as necessacary....there is a chance i am slightly wrong though.......
EVOthis replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy aunt has a 89 mustang with the 4 cyl and the same thing is happening (coolant surges from the overflow with the engine running)....i believe her HG has ruptered although she is not burning hardly any coolant......anyways when it comes to cooling system/ overheating problems i have heard of people starting off with the least expensive repair and working there way up until it is fixed (sounds like a shoddy mechanic to me, but also a good idea)...... coolant temp sensor? i am assuming you replace the Radiator cap when you replaced the radiator? which engine is it? Do you notice any external coolant leakage around the cylinder heads? did the cooling system operate correctly before you installed the parts?
Pull the motor or transmission?
EVOthis replied to meddler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXedrach- i realize that... im just wondering what kind of subi you did it on....i was thinking that there may be extra steps i may not know of if it is a different model or year subi.....ive only ever done the clutch on my 96 ej22 legacy.....my apologies if i sounded offensive or arrogant....
EVOthis replied to meddler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXedrach-man what car was that....the first time i did my clutch/flywheel the whole job took me 6 hours.....the second time i did it it took me 4 and the third time i did it took me about 3......and i did it on jackstands in my driveway.....were the bolts like rusted on or somethin?.....
transmission clicks?
EVOthis replied to ILOVESUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi know you say the front end is were you hear the noise.....but you can also get a clunk from bad u joints when you change gears in an automatic........my father had it very bad on his c3 corvette.....
EVOthis replied to meddler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have had the trans out of my 96 lego 3 times and i pulled the trans for all of them......i just unbolted my exhaust system at the heads, unplugged the o2 sensors and undid the hangers and i just pulled the complete exhaust system still together off the car.....i think it is prety amazing on my car almost every nut and bolt with the exception of a few was a 14mm.......and you know every time i did it i improved little by little......the only awkward part for me was tilting the engine so far when i had to put the trans back in to get it in alignment into the pilot bearing......so i would recommend pulling the transmission instead of the engine.....but obviously either will work.....oh when i did my clutch for the first time my subaru had 179,500 miles on it and the flywheel was all heat scored so instead of machining it i just bought a new one off of http://www.autopartwarehouse.com ... the brand was sachs and it was only about i think $80.00..... im sure you know while you have it opened up to do the clutch....replace the pilot bearing release bearing release bearing clips (which hold the bearing onto the fork) rear main seal (though i dont think they are that prone to leaking) rear seperator plate (not to sure if the 2.5 L. have one or not or if its plastic or metal) pressure plate clutch disc machine or purchase new flywheel im sure there is something i missed and someone else will chime in......
Tahoe area mechanic
EVOthis replied to MountHood's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas for a used engine if i does happen to be the head gaskets and something is warped/cracked.....check out the local Junkyards also colorado componant rebuilders and LKQ i just bought a trans from LKQ and it cost me about $600 with a 6 month warranty....its def. worth callin um up.....18003490705
97 Brighton Suspension
EVOthis replied to (goldfish)'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcoil overs! ......no just kidding but i have heard of alot of people using the KYB GR2 struts.......not to sure if they help with handling at all......but you could def. increase your handling if you wanted to lower it a little bit.......i bought these springs called intrax off of http://www.autopartswarehouse.com and they are considered lowering springs but they didnt lower my 96 legacy that much.......they werent to expensive either.....
EVOthis replied to subaruguru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i had that problem with the HLA's a while ago on my 96 ej22 and i just came out started her up and i heard them ticking away like extremely loud fuel injectors (it kind of sounded to me like a valve tap)...took her for a drive and added some marvels mystery oil to the oil filler neck and nothing has come back since.......i do believe the 1.8's have HLA's and if i can remember correctly they are significantly larger than the ones on the 2.2's......
Blown Head Gasket or just nothing to worry about?
EVOthis replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXusually bubbles in the overflow is not a good sign.......how many miles on the car? have the HG's ever been done?
Water Pump Advice wanted...
EVOthis replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah isnt the replacement intervel for the t-belt 105k......i would say you still have some life left out of the water pump......
I Busted the Cat pipe, 97 OBW
EVOthis replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprob. not going to be easy but the junkyard.......
Knocking...well more of a tapping sound, help
EVOthis replied to benc.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is just what is sounds like to me....it could very well be something else.......do a search or look at the bottom of this thread were the "related threads" are located and it should give you a good definition of piston slap as well as other valve train/ engine noises.....in short i believe there is excessive clearance when the engine is cold and makes the piston kind of slap against the clyinder walls....once everything warms up and expands everything seats well and the noise is gone.......
Successful A/C evaporator install in 2003 Forester
EVOthis replied to kamrows's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno the condenser is in front of the radiator......... thats amazing....i always presumed that you would have to pull the dash to replace the evaporator.....thanks for the info.....
EVOthis replied to benc.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds from what you said like it could be a piston slap......its there when its cold and gone when it warms up?......
