Everything posted by EVOthis
My turn for the Head Gasket replacement
EVOthis replied to sussman00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy headgaskets went at around 100k and now i have 190,000 on the car and its still running like a champ.....if nothing was cracked, warped or damaged i would replace the gaskets........
Some Photos from our track day
EVOthis replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 ^.....looks like a great time!
It looks like I need a new CD player
EVOthis replied to RBGERSON's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJunkyard?
stereo upgrade - recommendations?
EVOthis replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmost people i talk to bash sony when it comes to audio equiptment but i have and excellant sony head unit........There not to expensive and a decent brand.....
How to Brakes 2001 Legacy Wagon L
im just puttin this out there..........there is a small possibility that when you depress the caliper without opening the bleeder that the brake fluid will make its way back up into the lines and ruin the check valves for the ABS system........i have done countless brake jobs and have never run into this problem but i have heard of it happening before.......just a tip.....
Baja Engines
EVOthis replied to jeffx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdef. understandable ive run into that multiple times....if you havent already check out..... cars101.com .....wealth of info on all subarus.......
60K tune-up H6 OBW-
EVOthis replied to DubMutant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you dont have it i would pick up the haynes manual or chilton manual.....extremely helpful for anything you want to do to your car......
Baja Engines
EVOthis replied to jeffx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi dont believe so......only 2.5 NA and 2.5 Turbo.......
AC Cooling Fan Problem
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXproblem fixed...thanks for the ideas guys.....i was looking for the cooling fan relays and unbenounced to me subaru put 1 fan relay under the dash above the fuse box..theonly 3 i was checking were in the fuse box in the engine compartment...it turned out there was no relay in the connector under the dash......stupid me...should have read a proper wiring diagram......
1996 legacy L ej22...just wondering if anyone can tell me how exactly the AC cooling fans work.....the problem im having is the only fan that works is the main cooling fan.....isnt the other sub fan supposed to turn on when the AC is turned on?....the cooling fan comes on at the right time (when the engine is up to temp) and shuts off at the right time.......the MAIN FAN also comes on when i hit the AC button on the climate control panel, but isnt the sub fan supposed to turn on when i hit the AC button? i have tested a few things....all 4 relays tested good according to the HAynes manual, i have a good ground at the sub fan, the fuses are all good, but i have NO POWER at the sub fan...if someone could give me a brief overview on how the system works that would be great.......
oring for rear cam cap, passenger side head
EVOthis replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow....i just got done doing this not 4 days ago on my 96 Legacy....yeah the o ring seals a little tough......i took a screw driver and stuck it behind the cap and gave it a few taps with a hammer and it started coming out.....be careful not to nick anything though......
HVAC Controls at night
EVOthis replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes it is possible.....i made that mistake i thought it was all the way in.....so when i would hit the climate control area at night it would light up and hit it again and it would go back off.....i just took it all back apart and now its good.....
dinner can wait - can't get ball joint out!
EVOthis replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive heard of people keeping the pinch bolt in for the ball joint and undoing the balljoint nut and pounding the living hell out of the lower control arm.....ive never done that but apparently it works for some people.......also maybe some PB.....
Need Help...Not Starting....
EVOthis replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah same.....i would def. check your timing one last time...i just did the timing belt on my ej22 for the third time......i guess third time is a charm because the first two times i did it i was a few teeth off each time......i would also check compression.....
Has anyone put a EJ-18 Motor into a Forester
EVOthis replied to tbreaden's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe only thing i can tell ya is that it would be a pretty underpowered Forester....obviously the main thing that is holding all subarus back from getting better fuel economy is the AWD standard im not sure how much you will gain from going from a 2.5 to a 1.8...but when it comes to fuel economy AWD def. isnt the way to go....
EVOthis replied to timstiles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif your speaking about the fan where it says (1 2 3 4) yes it is supposed to light up.....i have a 96' legacy also.......when i acquired my car none of the climate control lights worked at night.......there are 3 small bulbs behind there i believe you can get them at radio shack for pretty cheap (i bought them at subaru) i cant remember the parts numbers off hand but do a search and you might find them (i think i got the PN from someone on the board)....its a pretty simple job........
Performance Brakes - 02 Legacy
EVOthis replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1. im not to sure how it is in other states and countries but here in PA.....its a law that if one set of brakes fail (front or rear) the other is capable of safely stopping the vehicle.... 2. nothing i can think of.....as long as you have done it before it shouldnt be a prob. 3. Usually you can buy tubes/cans of grease that say "caliper grease" on it......i always do it on the brakes i replace because there is a small chance they could get a little noisy if you dont..... 4.if there are anti squeel shims on there when you take the old pads off....i would def. reuse them if not get new ones.....
Wires Under Drivers Seat?
EVOthis replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup seatbelt chime....i almost ripped my wires off when i tugged on the seat to get it out......
Cam seals
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalright got everything back together and it runs just fine...a little rich because the bat. was disconnected and i think the PCM lost its Keep Alive Memory so after a little bit of driving i think it should go back to normal......thanks for all your help fellas...so far the cam seals/ orings are a success....
hub for a 1993 Legacy
as for the hub you could check out your local junkyards.....or browse e-bay you might find something.......as for the stalling issue it could be a number of things....fuel pump, ignition problem....just to name a few.....
2002 Impreza/WRX Service Manuals
EVOthis replied to DTM21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah man...looks like some serious info on there......thanks for the tip......
Subaru rain gutters
EVOthis replied to screwbaru2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe ones for the M/Y 2000 on are here........ http://www.brandsport.com/venwindefsub1.html good luck....
2000 OBW... advice??
EVOthis replied to cobcob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice.......just remember to take her for a good long test drive to be certain the head gaskets are giving you trouble (maybe they have already been done)....also i would check for torque bind..........other than those two things.....looks like a pretty nice car........
Cam seals
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalirighty...what i managed to do was to drill out the hole and retap it......i threw that back in, put the tensioner in, reinstalled the timing belt and started her up for a few sec.....ran like a charm.....now the eay process of reinstalling everything.....thanks for all your help guys....i would have never known that tensioner bracket even existed if i didnt run into this problem...man you always learn something new.......
Subaru rain gutters
EVOthis replied to screwbaru2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi could have sworn i saw them on a JDM legacy wagon which was 2nd gen.....but so far all i can seem to find are rain guards which fit M/Y 2000 and up.....also i dont really see how it is possible because there is no window frame....maybe theres a way around it......
