Everything posted by EVOthis
Is it the fuel pump?
EVOthis replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes as nipper said make sure you have fuel....after that...do you hear the fuel pump turning on for a few seconds when you turn the key to accessory?
Cylinder order
EVOthis replied to Valijean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is an triangular arrow on the crank sprocket....dont worry about that mark.....when your putting on your timing belt use the mark on the BACKSIDE of the crank sprocket.....DO NOT USE THE ARROW......... http://endwrench.com/images/pdfs/2.2SingleOverWin01.pdf
New ( old ) Subaru with pictures !!
EVOthis replied to PeterD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe interior does look pretty good for the age and mileage of the car..... ill say you got a deal!
Coolant Fans Are Running Contiuously ???
EVOthis replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is a chance this is the default position for a realy....i would check all the cooling fan relays to see if they are stuck in the closed/energized position.....
Dealer Repair Issue
EVOthis replied to BenHosed?'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin my opinion you would have been better off to just swap in a 2.2 liter when the head gaskets blew.....but now that you have put out all that money it would be a waste......the way i figure it if you already spent all that money i would follow through the job until the end and have the rings replaced.......that is ALOT of oil to go through in that amount of time.....are you sure that the rings are the only problem?......do you see any blue smoke coming out of your exhaust? do you notice oil in your coolant or coolant in your oil?......
Once more Subaru rubs our faces in it ...
EVOthis replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook at the bright side....we do have the Legacy GT Spec B.....
Absolutely HILARIOUS commercial
EVOthis replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think somebody put a thread out there a few days ago about this commercial....its pretty funny though.....
how many miles does your Ej22 have??
EVOthis replied to felixwankel88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1996 Legacy L....just hit 192,000 a few days ago....not the original trans but as it sounds the engine is still going along.......and this car has had a very hard life thanks to the previous owner......
Considering 08 Legacy 3.0R... Please share your opinions
EVOthis replied to hades281's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyour kidding! "subaru has taken over toyota as far as reliability is concerned"......i had no idea....thats pretty impressive...
96 Subaru Legacy High-Output Alternator?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno unfortunately i never got around to it.....i ran into other problems that required my attention (i lost 4th gear)....unfortunately i used most of my money on another trans.......i will prob. be posting something if i do decide to do in in the future.....im just about to graduate from school and just landed a job at a Subaru dealership in Delaware so now i actually have time to make some real money......
need legacy turbo help quick
EVOthis replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi might have mentioned this before but to see if the MAF is indeed faulty give her a tap with the butt end of a screwdriver with the engine running....if the cars bogs or stalls than the MAF is faulty......i also had a friend with a problem like this....it turned out to be his coil pack.......
Interesting info that I learned today
EVOthis replied to Oregon_Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi see a fair number around my way....theres also a fair number of dealerships doing some pretty good business (despite gas prices)....
A/C Evaporator. How tough to replace?
EVOthis replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah the post i read a few weeks ago was about i think an 01 or 03 forester and he said he didnt have to remove the dash......as long as the AC system is recovered/discharged by the shop i dont believe its that hard of a job.....i was digging around in mine the other day in my 96 legacy because my water drain was clogged....according to the haynes manual you can get the evaporator out without removing the dash.....its right behind the glove box (at least it is on mine)...if you do happen to tackle the job yourself make sure you install a new reciever/drier.....
EVOthis replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif its just the evaporator and not the heater core.....the dash may NOT have to comeout......what kind of car is it? what year? what engine?.....there was a thread not to long ago about someone who did it on a forester and the dash did NOT have to come out......take a look at the related threads down at the bottom of the page.....
svx questions
thanks for the help guys.....ive tried to do a little reading up on the SVX but i still have questions at the end......
svx questions
really.....i thought the EG33 was dual overhead cam......is the timing cover plastic or metal......sorry for all the questions i have just recently been reading up on the new tribeca motor.....
svx questions
does the SVX have a single timing belt or dual timing belts?.....just wondering because i was reading about the H6 3.0 and 3.6 and they are both dual timing chain...are they not?
Trailing arm bushings, '03 Outback
EVOthis replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe trailing arm is at the rear of the car and is mounted from front to rear.......i believe i need to do mine on my 96 legacy......they arent that difficult to do.....i do believe you need to press them out though.....check out your haynes manual if you have on.....on mine i would say it doesnt looks like a wishbone...more like a regular dog bone....
learned a valuable lesson this morning...
EVOthis replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh wow.....im glad you didnt decide to let them go a few more weeks or months who knows what could have happened......
svx questions
30 mpg! thats pretty impressive for AWD.....
Wheel Bearing?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell i didnt notice any vibration from when i grabbed the spring or strut.....the whole thing is prob. just me being paranoid.... ....thanks for the help though frag
250k
EVOthis replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe EG33 is the engine found in all the SVX's from 92-97 i believe....
so which gen is my 2001 outback?
EVOthis replied to enduro91's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi believe it is a Gen. 2 but i could be wrong.....not sure if they have it or not but you could always check out http://www.cars101.com
svx questions
my knowledge of the SVX is limited but i should also prob. read some on http://www.cars101.com as posted above.....but i know the 3 main things in which SVX's have problems is transmission overheating,wheel bearings going bad, and they have a tendency to warp brake rotors rather quickly.....I also know the SVX was only available in an automatic and there were FWD and AWD versions.....i would say the majority of SVX's ive seen have been pretty good until around 100k than you start developing problems........ again like Jamal said....hit up cars101.com the info in like endless.....
Cam and crank seal question
EVOthis replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreally?...i bought my cam seals and they didnt come with anything on them....i just lubed them up with a little oil before install....
