Everything posted by EVOthis
Rocker Panel?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The rust spot is extremely small.....not even the size of a small cell phone......i do understand were you are coming from.....it is just an eyesore to me.....and i want to take care of it before it does become a safety concern. -
Rocker Panel?
thanks alot JT95 i am working up to be a mechanic not a body guy so every bit of body knowledge helps.....that does seem pretty easy.....its a hole about the size of a cell phone so its not that bad but i want to take care of it before it gets worse......whenever i have the time i will give it a shot...... -
oh in that case......thank you very much WA...i was just thinking becuase i did the clutch and flywheel not 6 months ago....and nothing was happening than.....the car has a hard 186,000 miles so i really dont want to put a new trans in it.....i will have to research and get money before i attempt but thanks again for info. OH just one last question.....Is it just time and wear that makes the viscous coupler go bad? ....if im backing up making a turn and the noise comes on....i have to like floor it to move the slightest inch.
well the thing that is weird is that it only occurs in the last half of a complete turn....(if i turn slightly it doesnt happen) I have checked the ball joints and they are both ok.......I do need trailing arm bushings rear sway bar links and bushings and a rear drivers side axle shaft (torn boot) do you think any of these things could contribute?
ok i have a 96' legacy 2.2 with a 5 spd and for the past few weeks i have been getting a pretty nasty vibration when i turn that makes its way all around the car ( can feel it in the seats). i know what a CV joint sounds like and it definately is not that....even though i do have a torn inboard rear boot....but anyways i also noticed that sometimes i have a screaching of the tires when i go around corners when i get the noise.....My first and actually only thought is the rear differential.....the car has 186,000 miles.....anyone else ever have these symptoms?
Rocker Panel?
thanks for the info. fellas! I just need to do something it is getting worse pretty quick.... -
I gotta get me one of them!
