Everything posted by EVOthis
You said it threw a code for reduced cat. conv. efficiency..P0420? I would be taking the car back to the dealer for a warranty repair for that one...Those cats are warrantied for something like 8 yrs/80k miles, Or if your vehicle is an 06' It might still be under the manufacturers warranty of 3 yrs/ 36k miles....This is what I would be checking into first.... I do have a Tactrix cable for my WRX which is obviously tuned by Romraider OS..I'm all the way over by Philadelphia PA though..
You could always pirate the ECU with Romraider..Thats what I've done on the WRX, however it takes a lot of knowledge to properly tune..lol..I'm still learning..
NICE! I love the forester XT's...What other mods are you planning? Are you tuned?
I'm just throwing this out there...You are aware when you disconnect the battery or clear the codes in these newer Subarus. the first time you attempt to start the car it wont start...its a feature of the system...however on the second or third attempt it should turn over and start. I'm assuming you've tried to start the car multiple times with the wire attached?
There are either 2 or 3 screws holding on the door panel...do you see the black plastic plate when you pull the handle back ( the handle where the lock is)..I use a small pick and pull that out, there is a screw behind it...Also...the door handle itself there are either one or two screws there..trim removal tools come in handy here..you have to pry up the handle itself and it will reveal the screws.....Ive removed dozens of them on 09's.....If you snap a pic Ill be able to describe it better for you...
Ive done both of the things you mentioned before..Its quite easy to do especially when your installing a tranny in these cars without the use of a lift.....Those clips are a PITA. Does the car move at all when you put it in gear and let off the clutch? I will say this..you would have never gotten the bellhousing to engine bolts/nuts in/on if you didnt get the input shaft in the pilot bearing.....Im assuming youve used a new pilot bearing/clutch kit here?
a/c problem
EVOthis replied to fixit72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
+1^..Whoever decides to charge it I would have them add some dye to the system also...just to be prepared should the system ever develop a leak... -
I dont believe a ground goes there ( I could be wrong)...That kind of looks like the place the EGR should be, im thinking maybe someone used a little plate and bolt to block it off... OF course im sure your aware there is a ground that the upper starter bolt goes threw...Im sure someone else will chime in...
