Everything posted by True2Blue
turboing a non turbo ea82
True2Blue replied to True2Blue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and ej swap is looking distant right now... now that i cleared up my court BS they slap me with a $450 fee and said good bye. i just spent $715 on my tires $60 on a set of rims i now have for sale $100 on the clutch $500 on a ruger sr9 (with goodies, i got attacked by a dog in my own yard the other day and (i sold my 45 and i carry everyday) and its a good tweeker b gone) paid 3 months rent $1950 and finally paid off last months bail from jail cause i missed court witch was $750 plus $200 for impound fees. so im absolutely strapped for cash ill take your word and let the setup go its own way -
ive never dealt with a turbo swap. i know there is a compression difference, what else would make the swap hard? i found a turbo setup.. and was wondering if it was worth the trouble (would be going on my stock 87 wagon ea82 engine with 5 speed)
ive never done machine work. what is the flywheel step?
good info too late. i ordered a clutch from partsgeek.com and they sent me a 200mm disk.. ************!! now my tranny is sittin on a bench doin jack************. im goin to napa in the morning to see if they have what i need. now that i know i need a 225mm disk.... ill never be left waiting again... **** that sucks. i need to hit the books:rolleyes: speaking of i got my G.I. Bill im goin to college to get some papers that say im a mechanic (goin to olympic college for mechanics) you know the subaru will be in the shop 24/7:grin: other than that what is the absolute best 225 disk that will fit the 5speed d/r?
yepp.. ill be returning to see pics:grin:
voltage jumping to 18v?
thanks don if you search that site for alt's youll see bigger for the same price and with adapter brackets:grin: -
got cha.. the camp thing with 2 batteries...... OKAY i wont be bass'n it up. camping usually lasts a weekend.. i dont wanna run my car every 2 hours to recharge the battery.. just because its not blasting music doesnt mean it wont die.. i have a 600watt power inverter on it as well... im not going to buy another battery maybe another cap at most. as for the red top input.. good info on ur part about the discharge and charge rate.. im not always bumpin my subs (i feel that i have to make this clear for some reason) the videos of it flexing to roof are to show its limitations thats not how i always listen to it.. and i dont go camping around a ton of people once in a great while ill go somewhere where ill have to pay to stay other than that 'kiss my rump roast' its noon and im crankin up the tunes. (almost no bass).. ive never had a complaint. down on white river people actually came over to hang out for the night (my suby was cranked up by a crate fire) id like to stry away from "if you came to my area with your music playin like that you wouldnt be happy" talk im not in your area and if i was really disturbing someone id leave, if mr macho has more to say faster than i can leave.. im sure the SR9 will take care of it all.. lets stay on track. 140-180amp is what im looking at as of now another cap for the 2 smaller amps. ill leave the big cap for the big amp after that it should be okay -
i found this http://www.qualitypowerauto.com/catalog.php?category=21 HELPFUL:) -
Wrong the red top is one step up from an everyday battery. the yellow top is the deep cycle made for boats and stereos. i did my research on that one in iraq. we use red tops on our generators. i know. but my amps pull ALOT, plus another 320w is goin in and i have 6 extra lights. those day lighters pull alot i can see the voltmeter drop when i turn them on. you got it.. Camping.............. its sittin around 12 right now. like 11.4 or so might have been cause the door was open i know i said up to 320 gimme some credit.. i was thinkin 180 so i dont burn stuff up but still get that charge.. i worked with the 24v 280amp alternator systems ALOT in iraq.. never seen an alt. charge more than it was designed for.. Obviously if your car doesn't run/move then you should fix that first, then worry about the alt tomorrow is hammer time -
i have the optima yellow top.. the red top is "better"? i can run dual yellow tops and napa said they make custom alternators up to 320amp ill see how this goes.. im focusing on the clutch tomorrow then alternator.. money is runnin thin now.. -
thank you! ill check that out tomorrow before i drop the tranny. im still gettin a new alt... -
the subaru is parked. has been till the clutch arrives.. ^ you should quit breathing i dont need more info to tell that its cooked.. GD what would cause this? too much draw? cause i dont bump the stereo all the time -
reads 14.3 at idle and goes up with the rpm's stops at 17.6-18 -
sorry yes thats what i mean -
dash check lights stay on. 'brake fluid' 'brake light' and 'battery/charge' they were flashing on and off today but the ru was running fine. the rpm's had no effect on the the flashing. everything i can think of seems tight. id rather not rip the dash out, but if i have to.... anyone have a semi pinpoint idea? ill volt meter it in the morning and see whats up... it does charge at 13-14 volts nothing else was on while it was doing this...
Tranny is coming out doin a "rebuild" on it, new shift linkage bushings are gettin installed. and maybe some internal bearings and syncros depending on how bad it is.. and the clutch WHILE the tranny is out ill be adding 2" of lift to the struts 1" to the engine and tranny lift blocks i know i have to extend the steering linkage as well. also dropping my rear 'swing arms' down 2" to help level everything out and push the wheel away from the fender (next to the door) (don't know when depends on how long the rest takes)
cleaned the rims up good today nice and bright:) washed and waxed the body:lol: its goin to a local mud pit once i install the clutch which hasn't arrived yet.....
the subaru doesnt do to bad actually
tires are 235/75R15 rims are 15x8 the tires still bubble over the lip:grin:.. the off-set is a little more than id like but hey they were free from a local auto shop (family owned)
what cha think?
