Everything posted by bratman18
Installing clutch
bratman18 replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never seen this before but I also haven't read any directions! I have always just put the clutch onto the dowel pins on the flywheel and tightened to specs! I spec thats tight enough:lol: But I've NEVER had one not work or fail and I have replaced many!
"new" 94 Legacy!
I had an Impreza auto and the only time I put the fuse in was when I want to burn off a set of tires! That's the only power difference, it was able to burn out really good. As far as acceleration and what not it was no different or not noticeably different! Yeah I love the old ones too you should keep an eye out for another!
"new" 94 Legacy!
Only the autos came with the fuse holder under the hood and you have to put a fuse in to make it fwd. Some people say that it does increase gas mileage but I found it doesn't! You are still turning all the same drive gear there is just no power to it! But I'm sure that someone will have a different opinion. If its in the shape you say it is hopefully you didn't pay much for it!
ea81 - ea82 5sp conversion, flywheel?
I can't remember exactly what I did but I had mine machined!
My '92 Loyale Wagon Beach Buggy Project
Well sand is a very dense material and "sucks" up a lot of a vehicles power. So you probably wanna go with a fairly conservative size. Probably something that measures 26-27 inches will work okay But I definately wouldn't go any bigger than that! You are going to notice quite a difference in power with those already so If you are able to measure anything and maybe even mock up than that might work.
What size lift are you using? Those are pretty big! You want to remember that it is just a little subaru with like 90 horse! So you want to have enough power to turn them! But I have 205/75/14 on my brat with a 3" lift I could go an inch or so bigger with no mod but I don't have a lot of power! Those measured 26 and 1/4 inches new.
Awesome well make sure you post some pics when you get it done!!! What are you using for tires I know you purchased some pugs. That thing is gonna be sweet when you get the tranny, lift and wheels and tires on it!
Sweet You are gonna love the 5 spd d/r! I remember my first swap, what a difference! Keep us posted on your progress! When are you getting the lift?
'83 GL wagon
buy it I wish I was closer! You guys get all the rust free good deals!! Jump on it its an easy fix!!
'83 GL wagon
Yeah what he said!
'83 GL wagon
most likely
Upgrading on the cheap
Where can you get and who makes a torque chip for an ej non turbo motor??
Mismatched Front/Rear Diffs?
bratman18 replied to mulletkill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced the tranny in my old impreza once and we accidently put a 3.9 tranny in and it had a 4.11 rearend and it felt really weird but didn't bind much just drove and steered funny so that could be it!
Brat keeps stalling after adding motor oil
I very much doubt that the oil had anything to do with your problem I have run my subarus with little oil before with out any problems! Its weird a subaru with an oil leak! But yeah I would go with the vac line or something, not the oil!
Fixing the AA 4" lift camber issue.
No prob!
$135 for the ea81 and $145 for the ea82 just looked!
I have lifted all of my subarus past and present the same way that sjr does and never had any serious camber issues or much tire wear so I never really saw the need to alter the strut block:-\
Some pics of the hatch. 56k go get another... Coke.
Pics!
OB struts on gen 1 legacy...axle problems?
I know that visually the joints are much bigger looking as well, so good luck!
Is there a demand for bolt pattern adaptors?
I would also be interested in an adapter to put 5 by 100 on my brat!!!
Legacy tranny swap
bratman18 replied to glh1975's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes its possible to swap the d/r into the legacy but there is quite a few things that need to be done but someone else will know more and where to look for more info!
I and many of my friends have used the new ones from NAPA and I haven't seen any fail yet so hopefully its the same for you!!! I just wish they would make new ones for my brat!
Ea81 power
oh you so funny! Send a few my way!
Poll: 86 GL Wagon or 92 Loyale Wagon???
No prob and good decision!
Yeah sounds like parts to me! Too rusty, its hard to patch gthe frame rails so that they will last! But it is an ea82 car. I would put the tranny in your loyale but if you can get the whole car thats the way to go, that way you have any and all parts you would need when putting the d/r in your car. It isn't worth that much in that condition I paid 175 for a similar car but make an offer and see what he says.
