Everything posted by bratman18
Subaru to the rescue, this time a Dodge Ram and a trailer
Says that link doesn't work
13 vs 14 inch jackman wheels
It has everything to do with tire size and nothing to do with the wheel. They are quite rare and very hard to find, so good luck on your search! But they would be a sweet find.
1979 Wagon - 56K miles
^And this ^This
Lift 98 Legacy GT Sedan
The thing is, your 90 had different style springs then what is on the newer Legacy's, for the rear anyway. So I wonder if that's why my experience is different.
Rear Diff - LSD or not?
Chances are unless it's a turbo, it's not an LSD. You can check by jacking up and spinning one wheel. If it's an LSD then both rear tires will spin in the same direction. If it's not, they will spin opposite.
It's all good man. I still say the springs are different, and that's from my own personal experience, but I guess I'd have to check it out again. I wonder if the spring rates are different between the 2, which could make a difference on strut longevity as well.
Yet you made the clear distinction between Outback and Forester struts......If you're going to give info, give the full and correct info about the topic. You made it sound as though Outback and Forester struts were different when in fact only certain years really were. I just wanted to clarify. Sorry if I'm coming across as an rump roast, been a bad night.
That info about the Forester struts is only for the 98-02. The 03-08 Forester strut is almost the same as the Outback strut, the spring perch is higher like the Outback.
HELP: Cant compress calipers
My guess is dual range 5spd manual transmission. Hope our advice helped with the brakes!
You'll notice there are indentations on the piston. There is a tool for it, but you can just use a pair of pliers, just put the tips in the indentations, and screw them in.
You have to screw the front pistons in.
You don't need a new head, or even removing the one that's in there. You can get a kit to re thread the spark plug hole and add an insert, then thread the plug back in. I had to do this on an old car I had, worked great.
Here is another pic after I had installed an Outback front bumper
It was done to a 99 Legacy L sedan that my girlfriend had. Just swapped in used Outback strut assemblies. Here is a pic
7th Subaru - 05 STi
Oooh shiny! I really need to do this to mine, seems like time is so hard to come by though! But it looks great man, nice job.
Ok, just speaking from experience, so feel free to try it yourself.
Forester XT and WRX interchange-ability?
bratman18 replied to zooandsubis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will also add to NOT use the ebay header! They are cheaply made with thin metal, and the flex section for the one piece header/up pipes are junk! They will break apart and suck up into your turbo.........ask me how I know.
bratman18 replied to zooandsubis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell you do get what you pay for. But, most of the ebay exhausts will hold up pretty good. As for the down pipe, if you want a catted one, don't cheap out. You can get a used one cheaper that will do just fine, along with the rest of the exhaust as well. Make sure the Accessport you get is the right model for whichever car you are using it for. Also, while WRX/STi exhausts will fit on the Forester XT, the tip will not stick out as far on the rear bumper, so at times it causes the rear bumper to melt a little, and you will most likely have to use longer exhaust hangers to have it hang down at the right height.
Pretty sure that Outback strut assemblies give more than 1.5" of lift, but regardless, if you use spacers on top if them, you don't really want to have more than 2" over stock. Your cv axles will wear much faster if you do. And I hope you're using Outback springs too. If you use Legacy springs on the Outback struts, your struts will wear out quite fast.
Introducing the Subercoupe Now with 50% more cyl’s and 100% more RWD!
We need more pics and stats on this!!
Plastic parts made
^reported
04 fxt
Thanks guys. Definitely been a lot of work put into them, and still more to go.
bratman18 replied to zooandsubis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShort ram intakes should fit both, cold air won't. And if they have any heat shield for the intake, those will be different as well.
The Desert Fox. My `84 DL Wagon
I have front wheel bearings and seals that will fit that I'd let go pretty cheap. PM me if you are interested. Pretty sure I have both sides.
04 fxt
I agree. I have seen many painted and powder coated ones, and it seems the factory powder coated STi intake manifolds have their own look. And it's so much cleaner under the hood!
