Olnick
10
Everything posted by Olnick
I took an '05 Outback. 2.5L with AT, for a test drive. Beautiful car, clean as a whistle and no dents or rust, available at a good price. But it drove like an overweight pig! After 30 years of driving peppy 1.8 and 2.2L wagons I was really disappointed. Found a parking lot and tried a torque bind test--turned the steering wheel full R and the car would not move at idle, Had to give it some gas to force it to go, same thing to the L. No bucking or jerking. Later tried to back into the seller's driveway and at idle it stalled the engine. Was that torque bind? Some other transmission problem? I'd consider buying the car if it's just the transfer clutch behind the tranny--but I don't want to buy big problems! Thanks for any input.
If you want to try the radiator idea, block the airflow through it with sheet metal or something. You might even glop a lot of flat black paint or driveway sealant on the fins.
As heartless said, only NGK or OEM wires are acceptable. Off the rack parts store wires are inferior--no matter how fancy the name!
Just a thought--do you have a proper Subaru t-stat or a cheapie parts store one? Have you tested it in a pot of boiling water?
- 41 replies
- thermostat
- sensor
(and 8 more)
Tagged with:
Welcome to the USMB. Yup, hard to beat a Subie!
Welcome aboard, L5. You're gonna love this place--just like we do!
Welcome to the USMB. Suggest you post your questions in the Older Gen forum.
Welcome to the USMB. You should post your question in the New Generation forum.
Just joined! 2.6.2018
Olnick replied to HawaiiBrat's topic in Meet n' Greet. Your USMB Welcome Center
That's an odd statement, Subasaurus. I can't think of a better place to have a Brat!!! (Okay, I'm prejudiced.) -
Hi,My first time here, hope I do this right.
Olnick replied to peter droz's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB, peter--you're gonna love it here! I'd suggest you start a thread in the Newer Generation forum--you'll get more responses there. It's probably not the gas tank--more likely the gas filler tube. And that can be replaced in the car. Good luck! -
Hey,bruceme777--any luck with your starter problem?
- 24 replies
Try a search here on USMB or Google for "Subaru Starter Contacts." Lots of info out there, even some Youtube videos. Then if you're still stuck come back on this thread and ask for help! (I'll try to remember the steps!)
- 24 replies
Do you hear the solenoid click each time you turn the key to start? It's most likely burned & pitted copper contacts inside the solenoid. they provide the heavy current to the starter motor. Relatively easy DIY fix and new contacts should be less than $20.
- 24 replies
- 1
Are you sure it's the ignition lock assembly that's bad? What happens when you turn the key?
- 24 replies
