Markus56
Everything posted by Markus56
  1. I think so. front driver side
  2. something with the valves. they are backwards
  3. why does this head look weird to me? i cant figure it out. its off of an EA-81 motor. Also , three of the pistons have a small hole bored in the center and one doesn't. I have never seen that before. i will post some pictures after this evening.
  4. I've hit the stall on the torque converter on my legacy on hills that my wagon was able to crawl up. That and TORQUE BIND!!!!!
  5. stainless steel hose clamps. works everytime.
  6. Some of the bolts probably backed out on your lift. Get under there and make sure everything is tight
  7. On a kind of related note, how much taller can you make the strut block over body blocks when you have outback struts?
  8. sorry for not being specific with the details:-p i do have a tranny cooler, mounted to the front bumper in front of the radiatior. this one : i doesnt seem to have the power to go up hills like my 85 wagon does, and when i am driving around town, i dont like how it shifts. also it has started slipping in reverse, and doesn't engage gears as quickly as the first transmission did. my thinking is that the big tires don't go well with the shift pattern designed to run the stock tires. also, it torque binds like crazy no matter what i do. the top two reasons are torque bind, and the dirt tracks that go up really steep longs hills that are everywhere around Havre. Back home, in Washington, my 85 wagon just climbs its way across Walker Valley ORV park, which is WAY more intense wheeling than the Montana plains can offer. but mainly torque bind
  9. Aww, thanks guys!
  10. Roll around another six months, and my transmission blew up while i was ramming my car through a snow drift on my way home from work. so that had to get replaced. thankfully, my boss let me use the shop where i work. While i was at it, i decided to put a 4" lift kit on it, because why not we've got a plasma cam and machine shop as well so it was very easy to make my own kit. Things were going great until i got two flat tires in one day, and said to hell with it! i'm buying new tires! That brings us to how Lucy currently sits! For the future, i have a 5 speed D/R transmission that i am going to transplant. more to come when that happens!
  11. Well i figured i had better do one of these threads for my 4th subaru, Lucy I bought her in 2010 for 275 bucks off craigslist. She had a blown headgasket and had sat in a puddle for the last year or so. The very first thing i did was add off road lights. So i eventually replaced the headgaskets on her because the XT i was driving at the time was falling apart faster than i could fix it. Of course i wasn't satisfied with low Lucy looked so i added more headlights and an LSI grill. As time wore on, more fun things happened like bigger tires and outback struts, and a 4WD switch for the automatic Then i decided to advertise our cause and put stickers everywhere :cool: So now we jump ahead a year, i and had moved from Washington to Montana. Before i left, i had gotten even bigger tires, broken out the low hanging lights, 15" rims, build a roof rack, put roof lights on it, inherited a trunk rack, added HID headlights, and installed CB equipment.
  12. my complaint is automatics suck with big tires I've already cooked one tranny in this car, and the replacement is starting to go tits up heres a picture of the car btw
  13. Shift linkages and tranny crossmember pictures would be sweet
  14. Yes, it has the lock switch. and it has 4.11 gears
  15. sweet! thank you! also, i didnt mention that this car is currently an automatic...
  16. I'm gonna argue with you on that one. The D/R is a much better trans for wheeling. my 85 wagon is MUCH more capable than my legacy right now. they have the same lift and the GL has bigger tires. Now, having a D/R automatic would be a cool idea...
  17. did you check BOTH the belts. it takes fifteen minutes.
  18. the bosch 3310 and 3312 are the same filter, only the 3312 has an antidrainback valve. the other does not
  19. well sweet! are there any pictures of the modified trans cross member? and would i have to get one from a manual or can i use the automatic crossmember?
  20. its a 91 legacy. should make it a bit easier then.
  21. so having a complete 86 gl parts car makes life easy then? how easy does a gl rear end attach onto a legacy?
  22. hey guys i'm having a heck of a time finding the info to put an ea82 d/r in my legacy. the search is not working for me, i guess i don't know the right key words to use. anyone know if there is a sticky or definitive thread anywhere? i've given it the treatment of a four inch lift kit with obs struts. now that i have 215/75/r15 bfg km2s, im having a heck of a time with steep hills. seems to me the next step is a d/r i have a complete 86 gl parts car all the other things i would need to get would be a clutch pedal assembly, dash gauge, adapter kit, from another legacy. i'm sure there is something that i am forgetting.
  23. Where i live there are no recycling facilities anywhere for anything. no cardboard, plastic, glass, nothing. used motor oil is used for oil burning heaters in the winter, not even the parts stores will take it. we are to far out of the way for it to be picked up. i pour antifreeze down the sink myself. everyone else waters their lawn with it.
