Everything posted by subyrally
Subaru Impreza... Diagnosis problem?!!
subyrally replied to JitLee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy friend that works at the dealer said soemthing to he tune of that meaning that the cats are bad, he said that the o2 sensors dont usually go bad. my y2k impreza pops the cat below threshhold code avery few months, i bought a scanner and just clear it. usually when the light is flashing, it means that there is iminant danger to the engine, like a dead misfire, or excessive knock, ect.... good luck.
Advice on redoing wheels
i used the duplicolor wheel paint, looks hot and holds up.
Has anyone used a blaster coil & MSD6A?
the coil is universal, you can get it for like $35 at advance auto parts.
Torched Subie carnage pics
i almost got sick at the sight of that.
Simple question
dude?!?, how far is that from frederick, md?? $30 for atranny, i want to get another for future use.
didnt gap the plugs, just took em outta my other engine cause they were new and bolted em in on the new one. i made sure they werent smashed or broken, i also checked to see if the were uniform, but i didnt have the gap specs or a gapping tool with me when i put em in.
front mount intercooler progress. I/C piping.(DUW)
i wanna see this once you have it done.
Advantages of RX over other models?
mine doesnt have a center diff, i have the older style dual range. looks like it has two output shafts, one goes to the output for the drive shaft and the other goes to the front diff. at least thats what the trans diagram looked like when i was studying it a while back. also, doesnt the rx have stiffer suspension than the gl-10? the way i think of the rx vs. the gl-10 is like looking at he wrx vs. the sti. might be slightly exagerated but thats just how i think of it.
you might be able to get a rubber elbow from home depot that would fit your needs, just look in the plumbing section, i made an entire intake outta parts i got there.
the rx doesnt have tortion bars, it has coil overs all around, and four wheel disk brakes, turbo, rear limited slipp diff, 3.7 final drive ratio, folding rear seats in mine, it also has a rear swaybar. i might have left some off though, correct me if i slipped.
i have a blaster II coil now, it was great. made a noticeable improvement and the engine ran smoother
use a 90* silicone intake hose for hte throttle body connection and then get a reducer from home depot. you could also just use ashort pvc peice to connect the elbow and the reducer. i havent had any issues with my home depot intake.
highbeam problem
yeah the screw in the bottom of the column is what was causing mine to freak out, just removed it and the problem went away.
the gl-10 rx wagon goes CRUNCH
found a guy that wants to sell his loyale, just found out its a sedan though. but it looks to be in great condition. http://www.ultimatesubaru.org/forum/showthread.php?p=254574#post254574 there is the link to his thread, until this morning, i though he had a wagon, but turns out its a sedan, but looks cherry. if i find any nice wagons, ikll let you know.
agh turbo problems again
that happened to me when i was getting on the hiway, not the most fun ive had.
Columbus, Oh meet???
hopefully, i will have a brat by then. if i do, i will so be there with it. i cant wait.
Time to build a killer motor
shadow, you are absolutly amazing. once again, i get new ideas everytime i see this thread, especially when shadow is posting. i need ms and edis. i want em soo bad now.
O2 sensor placement???
after the cat, the o2 sensor would be worthless to the ecu for tuning the air/ fuel ratio, the only reason they put sensors behind the cats on newer cars is for emissions control, basically to make sure that the cats are working, not to control the engine.
What it should of looked like.
i really like the yellow one, thats the hottness. i think that when i get money and time, ill make one of my own.
Brat curb weight??
im pretty sure that is weighs in less than the rx sedan i have, i remember seeing somewhere that the sedan was like 2400, my guess is that its hovering around a ton, just my guess though. i do know that they are light weight.
yae or nae?
i want to find clear lights for both of the subies i have. corners and turn signals, i think hat would be hotness, now if only i could find the jdm sti tails for my y2k impreza, ooooohhhh yeah.
EA82Ts with custom MAF adapter, where did you get?
im going to run up to pepboys today to check out he adaptors. i try for a part number and price.
ive been looking into getting my first ea82 built up into a monster, im getting more ideas every time i check this thread. thanks everyone.
ummm, need to go talk to the machine shop thats storeing my first engine from the rx. that might be a good idea for what i want to do.
i like that idea. i wnder if that will work on an aluminum block
