samo
Everything posted by samo
  1. Well, I guess I'm wrong! Learn something new every day .
  2. Rip out the condensor and turn the compressor into an on-board-air system. Plumb it to a tank with a check valve and some fittings. Then, you can run air tools, air up tires, etc.
  3. Thank you, sir. Crutchfield will include the wiring harness and dash kit with stereos you buy from them, as well as detailed (and generally quite good) instructions on installation. You will, however, pay for the install goodies by paying a higher cost on the stereo and paying for shipping. But, you won't have to fight with the guy at the stereo shop over which dash kit your car really needs. If you feel confident buying online, they're a good resource. My recommendation to those purchasing online, though, is to go to a "real" stereo store first and play with all the stereos until you find one you like, then buy that one online. Crutchfield and other online retailers can't give you the hands-on experience of playing with the stereo, which is very important in purchasing a stereo.
  4. Eh.. Air is lighter than brake fluid, so I'd imagine that if you let it sit overnight, the only thing that would be pushed out, if anything, is the brake fluid. Be safe, bleed 'em right. Your brakes are the most important part of your car, so I wouldn't experiment. ...but that's just me.
  5. ^ Likewise, Castrol 10W30. I do, however use the high mileage variety, due to the large quantity of leaking seals in my engine, and the fact that I never ever plan to replace any of them. The gentleman who 'rebuilt' the engine in my wagon before I owned it didn't replace many of the seals, and thus, they leak quite badly. I've used Purelator One and Bosch filters with much success.
  6. Mine were next to a Peugeot .
  7. Installing a stereo into an EA82 (85-94 DL, GL, GL-10, RX, and Loyale) vehicle seems easy enough on the surface. After all, the stock stereo sure looks the right size, a big leg-up over our EA81 and First-Gen brothers and sisters. The problem is the stock stereo is so very short that an aftermarket stereo just won’t fit without sticking way out! Then there’s the issue of wiring. You see, there are two different ways to wire the speakers in a vehicle. Common ground utilizes a single negative wire for all the speakers in the car. This style of wiring worked great until about the mid Eighties, when floating ground wiring came into style. Floating ground uses a separate negative wire for each speaker, allowing for greater clarity, true stereo sound, and much more power. EA82s, unfortunately, are somewhere in the middle between the two. The wiring is floating ground from left to right, but common ground front to back! If you have a Loyale or a DL, you’re probably in good shape, since it’s likely you only have the two front speakers anyway. GL, GL-10, and RX owners will have to do some wiring, though, if they want their rear speakers to work. Fitting it into the Dash As mentioned above, many new EA82 owners dive into a stereo replacement thinking it will be a piece of cake, only to find that their new stereo sticks out of the dash a couple inches! Now, our more “primitive” brethren may find this to be no big deal, but for me, I want it to look like it belongs there. What we need is something that will attach in place of the stock stereo bezel, but be about 2” thicker: a dash kit. A dash kit or installation kit is a plastic bezel that allows for the installation of an aftermarket stereo in a dashboard not designed for one. Two manufacturers make dash kits for the EA82, Pyramid and Metra. I personally like the Metra kit best. Other kit-makers have re-branded the Metra kit, but don’t worry, it’s the same thing. The Metra part number is 99-8900. You can get these kits at any stereo shop for somewhere in the neighborhood of $15. While you’re there, also get an adaptor harness for your vehicle. Metra’s part number is 70-8900 for the EA82. Make sure you get an EA82 one – many shops confuse the Loyale and the Legacy. Your harness should have one large white plug with most of the wires on it and one small plug with just a yellow wire. Your kit will come with a whole bunch of extra parts, mostly for the EA81 crowd. What you need to fish out of the bag is the large rectangular piece with four screw holes. Notice that the center opening, the one your stereo is supposed to fit in, is blocked by some large mounting tabs for a shaft-style radio. You’ll need to cut these off. A utility knife works well, as does an old hacksaw blade. Lop off the tabs so that you have a nice 2”x7” rectangular opening in the middle. Fish out the four mounting screws from the bag, and if your kit has a 1”x7” hole underneath the stereo hole, find the block-off panel for it and snap it in place. Mounting the Stereo Your new stereo, or headunit, will likewise have a bunch of goodies in the box to dig through. What you’re looking for here is what’s called the DIN cage. It’s a 2”x7” metal sleeve with a whole mess of tabs and holes all over it that the headunit slides into. Sometimes it comes already mounted on the stereo, in which case, remove it. Slide the DIN cage into the dash kit with the flange on the outside. With a small flathead screwdriver, bend all the tabs you can so that it stays firmly in place. If it’s still a little loose, a bit of hot glue works nicely to secure it. You can now pull your shiny new stereo out of its package and slide it into the DIN cage. Slide it in until it clicks and locks in place. Just in case you ever need to remove it, most stereos come with a pair of thin metal stereo keys that you slide in on each side of the headunit to disengage the tabs holding it in place. Also in the box should be a trim ring. This is a hollow rectangle of plastic that snaps around the headunit to cover up the edge of the DIN cage. It may already be snapped to the headunit. If it isn’t, snap it in place. Wiring Also, either in your stereo box or attached to the stereo, should be a wiring harness. If it’s attached to the stereo, remove it. This will be connected to the wiring harness you got at the stereo shop to make an adaptor that will cleanly and reversibly connect the stereo to the car’s wiring. Didn’t get a wiring harness at the stereo shop? Go get one. It’s Metra part number 70-8900. There are two schools of thought about wiring. Some people like to solder their connections and some like to splice them with a connector. I’m terrible with a soldering iron, so I choose to use splice connectors. If you’re going to splice, get a decent pair of crimpers. Most people have those crimpers that have the wire stripper in the handle and a bunch of other whizzy stuff. Get rid of those, they’ll never make a good connection. Klein, Stay-Con, and Channel Lock make the very best crimpers, which are essentially a large pair of pliers with a small tab in the jaw to make the crimp. These will make an exceptionally strong crimp that will easily last the lifetime of the vehicle. Also, get the correct splice connectors. They come in three sizes with corresponding colors. For most stereo wiring projects, the blue connectors will be just fine. Whatever you do, the “twist and tape” method is not okay! Those connections will unravel over time and short out, damaging your stereo or starting a fire. Begin by stripping ¼” or so from the ends of all the wires on both the headunit harness and the adaptor harness. You’ll notice that a lot of the colors are the same on both harnesses. For most stereos (the chief exception being older Pioneers) you can simply connect like colors. I like to twist both wires together and connect with just one crimp. This gives a great connection that’s very strong. You'll need to connect: Yellow Red Black White White / Black Grey Grey / Black If you have an amplifier with a remote turn-on wire, it will connect to the blue / white wire. If you have a power antenna, connect the blue wires. Cap off the remaining wires with a splice connector, and secure the wires together with electrical tape or some wire ties. This will let the stereo power the front two speakers. If you have rear speakers, you’ll need to do some more wiring. Wiring the Rear Speakers If you have a GL, GL-10, RX, or have added rear speakers, you’ll need to do some wiring. You’ll want some speaker wire, at least 14GA. You will also need to remove everything necessary to lift the carpet slightly. Most often all that needs to be removed are the door sill clips. Somewhere near the B-pillar will be a small pink connector with two wires going into it. Note the color of each wire. Find a 9V battery and some wire cutters. Start on the driver’s side and clip the wires about three inches on the inside of the pink connector, leaving the connector attached to the wiring going into the door (or side panel for you 3-door folks). Strip a bit of wire and place one lead on the negative of the battery and the other on the positive while watching the speaker. If it moved out of the door, toward you, mark the wires “-“ for the one connected to the negative terminal and “+” for the other. If it moved into the door a bit, do the opposite. Test and mark the wires on the other side of the car as well. Why does this matter so much? Well, the magnet in a speaker can either pull or push depending on which wire is getting power. If current is applied to the negative wire, the speaker will push. If applied to the positive lead, the speaker will pull inward. If one is pushing and one pulling, they will cancel each other out. This is called being out of phase, and it sounds really weird! If all the speakers are pushing together, the speakers are in phase, and that’s where the good sound is to be had. Get your speaker wire out and some splice connectors. Run the wire from the dash down under the carpet to where the speaker wires you just tested are. With most speaker wire, one side will be copper and the other steel or there will be some distinguishing mark on the wire. Make a mental note about which wire will be positive and which negative, and connect them to the speaker wires accordingly. Go get your freshly-made wiring harness and attach the wires as follows: Purple: Left + Purple / Black: Left – Green: Right + Green / Black: Right – Finishing Up Now that you’re wired and ready to go, snap the car’s harnesses and the stereo harnesses together. Grab the stereo and dash kit and hook the wiring to the stereo, along with the antenna wire. Slide the whole mess into the dash, being careful to not pinch or pull any wires along the way. Screw the dash kit into place using the four supplied screws. Congrats, you’re done! Turn the car on and enjoy your new tunes! Glossary Adaptor Harness: A wiring harness designed to connect to the stock stereo wiring of a specific car, allowing a new stereo to be added without having to cut into the car’s wiring. Common Ground: All speakers share a single ground wire. Dash Kit: A bezel or panel designed to accommodate an aftermarket stereo and fit it into a dashboard not designed for one DIN Cage: A steel, aluminum, or copper sleeve that cradles and holds a headunit Floating Ground: All speakers have their own ground wires. Headunit: A stereo unit In Phase: All speakers are moving together. Out of Phase: Some speaker(s) are moving opposite the other(s). Speaker Wire: A pair of wires attached to each other specifically for connecting speakers Stereo Keys: A pair of small metal “keys” that allow the removal of a headunit from its DIN cage. Trim Ring: A small plastic trim piece that covers up the edges of the DIN cage. Common Wiring Colors Yellow: 12VDC+ Constant Red: 12VDC+ Switched Black: Ground Blue: Power antenna Blue / White: Amplifier remote turn-on Grey: Left Front + Grey / Black: Left Front – White: Right Front + White / Black: Right Front – Purple: Left Rear + Purple / Black: Left Rear – Green: Right Rear + Green / Black: Right Rear – Disclaimer This document is provided AS-IS. No guarantee is made regarding its accuracy or usability for any purpose. The author accepts no liability for any damage or injury resulting from the use of this document. Use at your own risk. Use common sense.
  8. I'm really glad you're happy with the car. It was quite a good car to me, glad it's being a good car to you, and I'm definately glad it went to a good home.
  9. Jamie at Chaplin's, definately. I would always prefer to buy my parts from a community member and a fellow enthusiast, myself.
  10. Didn't the one Tcat sold have Toyota wheels? This one looked like it had the stock steelies.
  11. Saw a camo EA82 on I-405 S just before the I-90 turnoff in Hell-vue today, circa... um... early afternoon. Looked like camo tape or something of the sort, as it was the "tree" camo. I think I've seen the same wagon parked on Northrup somewhere around the BMW dealership - maybe across the street from Auto Connections(?). Belong to anyone on here?
  12. This was... um... Friday, I think. Saw a grey EA82 wagon at BAR with 15" Pug alloys and some stickers. Who does this belong do? Looked like a nice little wagon. If you work there, next time the Chaplin's delivery guy comes around, say hi, okay?
  13. Those fellas are going to be little tiny LEDs microsoldered onto a lighting board behind the face panel. The likelyhood of successfully soldering new LEDs in place, if in fact yours are dead is pretty low. Best bet is to just learn to control it by feel or get a new unit. You'd have to be a SWEET solderer to do a decent job on those tiny connections.
  14. You guys... no, wait... you guys really, like... no, I - I'm finnnnnneeee, I can... I'm not drunk ... New Foresters will have those wheels.
  15. Ehh... I'd have to go look at them, and they're in a pile down in the garage. Me thinks they're oval holed.
  16. I've got a Yakima rack that I've modified to carry a spare tire. I added two pieces of extruded iron pipe running front to back, some tiedown brackets, and of course, a mess of lights. This is the best picture I could find showing the rack:
  17. There are 14x6" steels, but they're not common. The only reason I know is because I have a set .
  18. We got 2 feet in the last 48 hours at Snoqualmie Pass. It's nice, light fluffy powder, but there's enough slick stuff underneath to making driving fun. If any of you feel like coming up to play, I know a few really good trails, and I'm pretty much up there most of the time these days.
  19. I would have definately put up a fight about that... anyway, I won't hijack the thread with my ranting. My wiring, to answer the question above, runs out the stock antenna hole, up to the rack, and back to the rear lights and replacement antenna. It works wonderfully.
  20. Thanks! I love all the stickers on her.
  21. I've got a set on mine. They're Pilot Navigator fogs, 55w each, mounted to the roof rack. Love 'em. Haven't used them yet in traffic, but usually I'm the one tailgating.
  22. Here and Craigslist are both great resources. If you're really interested in serious offroading, most would argue that the EA81 is the best platform to start with, particularly the Hatch models. They don't have as much power as an EA82 and they're (almost) all carbed, but they're smaller, lighter, and have better approach angles, with a more reliable engine. If you're going to fall in love with an EA82, you'll still have a potent platform. The '87-'89 SPFI GLs are probably your best bet, as they have more power than the carbed models, and have the lovely dual-range transmission. Sounds like you've got a decent plan for building your Subaru, once you get it. Search around, there's tons of information on here about all aspects of Subarudom. And welcome to the board!
  23. Haha... thanks again! They look fantastic on the car.
  24. Thanks ! Sadly, it is true. You gotta admit, from a distance, an EA82 does look kinda like a Cherokee, at least from behind. No confusion now, though!
