3
Everything posted by tizzle
RX type fastaR
I think that one on craigslist is just a tuned WRX setup
Here's my Legacy with a 95 STI Ver2 RA drivetrain. Don't forget the goodies such as the 5th injector
cut out at speed and idle problems
tizzle replied to chazmataz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Throttle position sensor? -
Stubborn oil pan gaskets!!
tizzle replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Gasket remover spray, and a razorblade -
I want a better rear sway bar, anybody want to hook me up with one?
They should be done with both wheels on the ground
Ok what the heck did I do wrong?????
tizzle replied to Slagathor1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK, can I compare this to my problem? I changed the drivers side head. Car Idles beautifully, but when I try to get on the gas, the power is just not there. I REALLY don't want to take that cam case off again, just thinking about it...ugh -
Ignition tune-up...now a little sputter-sputter
tizzle replied to Steven Romero's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There should be a screw on the rotor, on the side I think. A problem I have with my wires is the inside of them like to pull up in the boot, so I have be careful to make sure they are seated properly -
Wha? Its ALIVE!!! MWAHAHAHAHAHA!!!!
tizzle replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
YAy! -
How would you build the perfect sleeper?
tizzle replied to Jack in Norfolk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would get a 96 legacy, and put a complete 95 STI Ver2 RA drivetrain in it, and top it off with some suspension work;) -
Seeking rally service crew...
tizzle replied to XSNRG's topic in Meet n' Greet. Your USMB Welcome Center
I'll help by taking lots of pictures. -Todd -
Cool website with RX stuff...even Safari Rally SRX!
tizzle replied to XSNRG's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cool, it even has video's. Noticed the possum borne car did the 86 Olympus rally, here in WA. -
heater hose for pcv hose
tizzle replied to dave valiant's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do yourself a favor, and replace as many of the pcv/oil/cooling hoses as possible, now, while you're in there. seriously -
there was a long discussion about this already http://www.ultimatesubaru.org/forum/showthread.php?t=12239&highlight=torque+head+gasket
Cutting out at 4500rpm? updated and SORTED!
tizzle replied to Johnnyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a similar problem. I just installed a brand new head. The car ideals beautifully, but when I go to drive it, i does not want to accellerate. I think it has to do with all the electrical connections I messed with at the same time (applying dialectric grease) I have a possible crank angle sensor code. Maybee I messed something up with the timing belt even though I was pretty meticulous about that. --also the plug wires just do not want to sit snug and happy on the distributor or coil, so I might change those ( year old ) --Todd -
If I had the budget right now, I would throw a wrx or sti setup in my RX for sure, but my funds are still deminished from doing that to my legacy, ..he he
What color should wagon wheels be?
tizzle replied to blownbimer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rusty white? -
what to do with the a/c system? opinions?
tizzle replied to rllywgn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, I expect a writeup on that. ---I have also thought of yanking my ac, less stuff to work around, don't know if it works or not. It's never gotten hot enough for me to use. -
incredibly high idle in the rx
tizzle replied to subyrally's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you adjust the idle speed screw, facing up on the throttle body, it will definitely effect the idle, there is a smaller screw on the side for fast idle(ie with accessories on) and that will make little to no noticeable difference. I would definitely give that a try -
Are you adjusting the screw on the top, not the one on the side, just want to make sure -
If it idles at 1700 warm, I would adjust the idle screw -
I'm in skagit county, but am up in b-ham pretty often
rx runs bad on 105 octane
tizzle replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My RX runs better on plus, than on supreme. I can imagin that it would run much worse on 105
