Everything posted by Snowman
86 carbed swap into a 88 SPFI??
Snowman replied to JLDT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The cam profiles are slightly different, but you probably won't even notice. Cams are timed via the same procedure, and your SPFI disty will drop right in. You might experiment with advancing it a couple degrees beyond the stock setting (is it 20 degrees on SPFI engines?) to compensate for the lower compression. -
Ditto. I've put together EA82 engines from various combinations of carb and SPFI engine parts. The carbed engine has slightly lower compression, but it's not a big deal. I made up some AIS block-off plates from an old street sign I had lying around, and they worked fine. -
What kind of tires are you running? (I suppose there are class-specific restrictions).
So, this is in case you need to pull out a stuck Hummer?
DUDE!!!! I will seriously help sponsor a USMB-er entering this event. (I'm not kidding. PM me if you're seriously interested.) I would love to do it, but I'm just too far away.
Have you checked to make sure that the disty rotor isn't loose because of a missing screw? I've had them do all sorts of weird stuff when that happens.
Yup. I've seen pics of Aussie Soobs with very large flaps on there, designed to prevent the boot from getting hit with stuff.
Wouldn't the larger jet size be giving more fuel, causing rich running and poor fuel economy?
Yeah, that's what I was going to do, but I ended up junking the car for other reasons before I had a chance to. It should be easy to find an FI tank for an EA82 car, but getting one for an EA81 might be kinda difficult.
Well, I just dropped $70 on one of these fuel filters for the 92 Legacy: Of course, I won't be able to install it until I get back from vacation in three weeks, but I'll let you know how it works. In case you're curious, it's got: -A spin-on 10 micron filter element (I'm looking to see if I can get a 2-micron replacement) -"aquablock" water separating coating on the element, so water beads up and collects in that blue bowl on the bottom, where you can drain it off:headbang: -rated for WAY more power than my EJ22 could dream of:headbang:
Subaru SANBAR hot dog stand!?!?!?!
Snowman replied to Frank B's topic in Historic Subaru Forum: 50's thru 70's
Dude! That's so cool! In high school I did a couple of fundraisers selling hot dogs and soda out of my EA82 wagon with a cooler and a coleman stove...wish I had one of those things back then. -
I figured it was something like that...different spline count on those or something? Manual looks good overall. I wish I'd had it when I was doing my swap:D .
I think the fuel surge tank may be necessary on any car that was originally carbed. I did my conversion on a carbed EA82 car, and I DID have fuel starvation issues when cornering or at extreme angles with a nearly empty tank. I have also been told that the FI EA82 gas tanks have some sort of baffle setup inside the tank that keeps a constant supply of fuel available, essentially like a surge tank. I'm also curious about what you said regarding swapping the entire EJ drivetrain. I used the 5MT from a 90-ish legacy, and my axles went right on the rear diff without any problems.
