avk
Everything posted by avk
OBS spoiler
avk replied to wagonlover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Roof spoilers first appeared factory-installed on 1995 LX model, then in 1997 switched to a different design (port-installed or dealer-installed). "Waist" spoilers became an option in 2000 as bratman says. Those spoilers are very expensive brand new, if you can even find them. It's either salvage or aftermarket. -
This is one of the inaccuracies ever present in aftermarket catalogs. The "14 inch" designation means they won't fit 13" wheels found on early Imprezas. They do work with both 14" and 15" factory wheels. The "15 inch" designation in this case means that the caliper actually won't fit under a 14" wheel. It is a two-piston caliper. The second picture shows the hardware that goes with it. None of the above is really necessary though, 'cause you already know which one is correct.
I don't have good tips on extracting the ball joint housing from the knuckle, because I have never done that, but for pushing the tapered stud out of the control arm, an OTC two-jaw tie rod puller worked for me. One has to be careful about positioning it, because the control arm isn't flat, but once you tighten it, it should stay. I believe a correctly sized cup-style remover, one with a slot on the flat top and a screw on the bottom, would work even better.
