Everything posted by avk
2009 Tribeca whiney transmission
avk replied to 3beca's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be that the differential backlash or some other tolerances were not set properly by the re-manufacturer, but that's only a speculation.
Cam cap doesn't turn?
avk replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBe careful using force on the cam support. The tolerances are close because this piece contains a cam bearing. So it's tight both on the outside (against the bore in the head) and on the inside (against the camshaft). You don't want to distort it, or score the bearing surface with the edge of the journal.
Shift cable
avk replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subarupartswebsite.com/OEMParts/subaru-153/3/35151AC030.html Not bad for a critical part like this one.
Shift cable
avk replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ebay.com/itm/1999-99-SUBARU-LEGACY-GT-AUTOMATIC-TRANSMISSION-SHIFTER-CABLE-OEM-OE-USED-CABEL-/200708222624 Do check the price for a new one, though.
question 95 impreza crank bolt
avk replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe older torque specification may have been too low, but, if memory serves, there have been no cases of a factory-installed bolt loosening up. If true, this leads me to believe that replacing the $5 bolt would be a very reasonable precaution.
adding cruise control to a 2002 TS
avk replied to kyle234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee if you can find the plug for the actuator. If present, it would be taped to one of the harnesses around the engine, maybe by the firewall. My feeling is it's not there, because the wiring was eliminated on 2000-01 models, except when c.c. was installed at the factory.
trunk lift strut bolt broke
avk replied to wagonryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ebay.com/itm/M6X1-0-m-m-LFK-Steel-Rivet-Nut-Rivnut-Insert-Nutsert-/370309716699?pt=LH_DefaultDomain_0&hash=item56382ddadb
avk replied to wagonryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere might be access to the other side after removing the trim. Another option could be to install a rivet-nut.
Welcome me to the Gen2 H6 head gasket club
avk replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is adjustable on EZ engines. There have been threads about adjusting the valves, but it's not clear if anyone has actually done it as a maintenance procedure and not when doing a re-build.
08 outback Lighter plug always hot?
avk replied to jchipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was thinking of the schematics for Tribeca, which has two accessory relays. If there's one for everything, that idea may not sound promising.
99 OBW, cig lighter problem
avk replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to clarify: the thermal fuse, if present, would be a part of the socket, and a new socket would solve the problem if the fuse is open. But in this case, something else seems to be going on.
avk replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou people scare me. Looks like valve adjustments on the 6-cyl. engine must be regular maintenance.
avk replied to jchipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo do that on a Chrysler vehicle, one can buy a dummy accessory relay which is essentially a jumper. Of course, you can make your own, and it will be a really clean and reversible modification.
2005 ...
avk replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe FSM, of course, only shows how to do it with a dealer scanner. Since the communication protocol is standardized, maybe aftermarket professional-level tools will work as well, but I'm afraid you'd have to pay one way or another. On the upside, you can run both the instrument cluster and the HVAC control through really neat self-diagnostic sequences without a scanner, just turning the key and pushing some buttons.
avk replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a true lighter socket, as a 1999 car would have, it might have a one-time thermal fuse, to prevent a fire in case the lighter doesn't disengage. Although, since there is a mention of a new socket not working, that might have been already ruled out. There may also be an SBF covering that circuit, but it shouldn't blow before the fuse does. Lastly, if there is an accessory relay, make sure it didn't get cooked. Sorry, the only wiring diagram I can see right now is for Tribeca.
List your problems from use of the Subaru coolant additive
avk replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am sorry I'm not up to speed on this. Has it indeed been established that the Subaru additive is RadWeld?
turn signal and cluster wtf
avk replied to experience780's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it was on one side only, I would suspect that a wrong bulb could have been installed at one corner, causing a connection between the two circuits. Now it looks unlikely, unless someone replaced all 4 bulbs with wrong type. If it's a bad ground connection, could be one for the cluster. In that case, when turn signals are off, there will be a ground path through the turn indicator bulbs. The current drawn by the cluster is small and so would be the voltage drop at the bulbs.
Wiper Problem Solved
avk replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPeople do it on GD/GG Imprezas, so this must mean that Legacy bushings are quite different.
Digital Torque Wrench - Holiday Special
I like it a lot, but now have a Tribeca and the torque for axle nuts is 177 lb-ft.
avk replied to experience780's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes this happen when you use a turn signal on either side, both left and right?
avk replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck NASIOC, people long found a way to use aftermarket bushings for other makes sold under Dorman/Help! brand.
2000 Power Steering into a 98?
avk replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes someone make a conversion kit for this purpose? Never heard of it. What are the components?
Blu is gone, long live ....
avk replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://legacygt.com/forums/showthread.php/official-dual-hvac-double-din-jdm-kit-thread-113589.html?p=2496140 Don't want to know how much.
TSB from AU/NZ concerning Gates timing belt installlation
avk replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's what I remember too. So it took the aftermarket something like 10-15 years to catch up.
when was it built???
avk replied to mojoman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe build date used to be on the VIN plate and a 1997 should have it. At some point, they stopped putting it on the plate.
