Everything posted by avk
ID Wiper control switch - 00 OBW
avk replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne switch has adjustable delay, the other does not. They interchange. The Limited model probably has the adjustable kind.
timing belt components - cheap kit or OEM?
avk replied to cjd160's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs far as I can tell, aftermarket idlers come from OE suppliers, NTN and Koyo. The only "catch" is that the smooth rollers are obsolete compared to current OE parts. They come with a single-row bearing vs. OE double-row. But it hardly matters if the parts are replaced at every timing belt change.
97 Legacy Outback air bag, cabin air filter
avk replied to spud's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the airbag warning light comes on as you turn the key, and then comes off and stays off, the dealer likely won't find anything wrong. There's no cabin filter or a provision to install one on this model.
Another timing belt changeout crisis
avk replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's right, I know it's hard to tell when you look at it. In fact, on some early engines with a new-style tensioner, the bracket can be swapped to install the better old-style unit instead.
avk replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://opposedforces.com/parts/legacy/us_b11/type_7/engine/camshaft_and_timing_belt/illustration_2/
Hatchback strut removal for replacement
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I was helping a friend change a lift support on a 2000 Outback, the new part did come with a new stud.
what size are the air bag torx head bolts?
avk replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXT30 if memory serves.
CV Axle tools
avk replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnbolting the control arm from its forward mount on the crossmember gives enough play to slide the inner joint off the stub shaft. The sway bar also has to be disconnected from the arm. It's an easy method, except that the suspension needs to be loaded when tightening those bolts during re-assembly.
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt looks like the ball stud would be very hard to pop out of the socket because the wire retainer spreads out and wedges itself between the two. You have to remove the stud somehow, it's replaceable.
midpipe bolts?
avk replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can use regular bolts with the old springs and double nuts, even stainless if you like.
Cleaning sludge from coolant resevoir
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, unless there were DOHC versions in Japan, but probably there weren't. They did produce 2.0 engines with DOHC heads.
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a 1995 2.2 l. The 2.5 looks like it was a market-driven redesign.
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might want to find out why it is there. I am not seeing any sludge on a 14-y.o. car.
Removing front crank seal from oil pump housing
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsing an old seal helps to drive the new one in squarely, although such high accuracy may not be guaranteed.
avk replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSandwich your old seal between the driving tool (such as PVC plumbing fitting) and the new seal. You will feel it when the old seal bottoms out in the chamfer. For the crank seal, it's not even an issue because the seal sits at the bottom of the bore.
Out! Out! Darn Bolt!!! SVX Rear Hub Removal Trouble
avk replied to NorthWet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEither the flange will crack with the main body, or it will not. I used a splitter on a nut with a captive washer, not quite the same, but the washer didn't stop the nut from cracking.
avk replied to NorthWet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe splitter shouldn't damage the bolt, it just causes the nut to crack all the way through, at least when it's big enough, like in this case.
avk replied to NorthWet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you fit a nut splitter in there?
Small Exhaust Leak @Spring Joint w/New Gasket?!
avk replied to Anon.II's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, the bolt holes in the contacts are 8 mm, so if you need extra washers, in a pinch...
avk replied to Anon.II's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, same contacts as I changed in the minivan some weeks ago. They should have stayed with Mitsubishi starters.
avk replied to Anon.II's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEdit: what he said.
95 Legacy L Wagon coolant leak
avk replied to bdstack7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are also small hoses to circulate coolant through the throttle body and IAC valve, and the temperature sensor in the coolant crossover pipe. I understand the pipe itself has been checked.
crank pulley wobbling?!?! and some strange noise
avk replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf memory serves, there are two different part numbers for the crank bolt although they may look the same. We do know there are two different pulleys. Maybe one bolt is stronger and can be tightened to a higher torque than the other. FSM for my 2.2 says something like 67-76 lb*ft but people say it's incorrect so I tightened to 90, using a new bolt, and keep checking from time to time.
avk replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe the bolt is stretched or something. If in doubt, replace the bolt and also the key. I think they should be replaced when doing the timing belt. The cost is small compared to the other parts involved.
Tail Shaft in transmission? Haynes Manuel no can find what shop talking about
avk replied to SubeRider93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy "tailshaft", in this case they probably mean the AWD transfer clutch inside the extension housing, sometimes called "tailshaft housing". What happens is that the transfer clutch begins to bind or shudder. This clutch is like other clutch packs in your auto transmission but is constantly controlled by TCU through a solenoid which modulates the fluid pressure. Do a search on "torque bind". Sometimes the problem is cured by adding a friction modifier such as GM LSD additive, or similar generic product.
