86subaru
Everything posted by 86subaru
Ok,Where is all the "Eastern" get togethers?
86subaru replied to Baysurfin's topic in Meet n' Greet. Your USMB Welcome Center
labor day last year ,we all meet in columbus,ohio, then went to southern ,ohio , for some great off roading, aleast2-3 times a year we all try and get togather in columbus,ohio and hit the junk yards -
we also get togather 1 time ayear , + go junking -
that is where i found them , for my 88 turbo full time 4wd inner / outter,
parts bin has sealed bearings , + any order over 50 bucks is free shipping ,should have them in 2 -3 days , but it may not the front bearings
around here , aleast western ohio, maybe alittle higher price, because brats are no more , still can find mid-80s ,but those are getting harder to find
my 88 turbo a/t full time 4wd wagon, 111,000mi gets 23 mpg city about 24 hi way. 88 dl d/r 192,000mi gets 24 city 28 hi way , 84 brat not real sure , because i am not going to drive her on the salty ohio roads
New thermostat, still overcooling
86subaru replied to TROGDOR!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
after 2 weeks of a after market one, mine did the same thing , i took it out put it into a pan of boiling water to see if it would open up and it did not , got a oem from the dealer -
no new drive axles were put on either side , because they were good when i sold the car , or wheel bearings either , they also were good,parts bin is good place to get subaru parts,
Getting more performance out of an EA82
86subaru replied to fbh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
kn air filter , 2in or larger exhaust from cat back, ngk plugs, good wires, keep carb cleaned out , -
first EA82T head gasket job
86subaru replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
alum foil wrap type if i remember around the coolant line , -
turbo + coolant lines under the turbo , -
on a gl there should be a oil pressuse gauge , everyone has there choice of oil , but after trying mmo, tranny fluid, use a wix, oem, napa gold, mobile 1, oil filters, . in my opinion 5w-30 is to thin , in the summer i have used 20w-50 , winter 10w-40 , i just started using wal-mart brand full synthetic 10w-30 , in my 88 turbo a/t full time 4wd wagon, [111,000,mi] , 12.67 5qt jug, , now in my 88 gl d/r 5sp wagon with 192,000mi i am using amsoil 10w-40 , aleast 5-10lb more oil pressure and drips less ,but while trying tranny fluid or mmo for a few day , go to wal-mart and get there regular brand 1.16 qt , [ like 20w-50 ] + add tranny fluid or mmo
underneith the turbo there are 2 lines 1 for coolant 1for oil, both mine were leaking ,
welcome we are pretty close , keep in touch , a few times a year we all get togather around here ,
ok, when miles fox was here last time, he had to put in a bigger stud on one side and the stock one on the other side ,both are tight , but the stock side is the one leaking
changed the exhaust gasket on my 88 turbo a/t full time 4wd wagon [ from napa] passanger side, 1 month later went out again ,some told me to use honda gaskets on the exhaust , i have several exhaust gaskets that will fit , both studs are tight , i have all the tools needed + time etc.. to do it , but just do not want to screw it up worse , what i mean is the studs may not go back in and strip out , it is not loud ,but noticeable , i am sure it will affect mpg , hp , any comments ????? thanks
did you replace the coolant + oil lines going to the turbo ? because they can go bad , i replaced both lines because they were leaking oil+ coolant
welcome
My red 90 4wd wgn no rust
86subaru replied to pkennedybluewrx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is it for sale -
Newbie! Just got a 2006 spec.b (Akron OH)
86subaru replied to hyteck9's topic in Meet n' Greet. Your USMB Welcome Center
welcomew -
i tell them to kiss my butt ,around here not alot of subaru's , but more all the time ,
there is 1 in my home town also, never meet the owner , seen it 2-3 times
this may not be a real fix, but it does work, run 20-w50 or 15-40 oil, + a good filter
the strange thing is , there is no sweet smell or taste , talked to a shop, they said that they may be making there own mix , alcohol , because animals like the sweet smell etc....
