86subaru
Everything posted by 86subaru
thats why the 86 wagon blew a hg , it smells like lemnade ,i have 1/2 gal left , and i have a receipt , i bought 3 gal and used 2 1/2 gal , i wonder how many more jugs are left on the shelf ????? but how can i prove it ?? i found another empty jug that i used
i bought some antifreeze form a local store [3 ga] , did a head gasket on a 86 , and it blew again, WAS LOOKING THIS MORNING ,THE ANTIFREEZE IS LEMON JUICE not even antifreeze , i changed a hose on the 88 turbo wagon and added some also , so beware when buying antifreeze
how often should you change the oil ? using redline , going to try it in the turbo wagon next oil change
Leaking ATF Tranny fluid
86subaru replied to EA82Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the hoses that go from the tranny to the radiator ,2 lines , they can get old and may need replaced -
a few months ago some one said a ford fuel pump for a f-150 works ,but something about needing a hose kit, i had the same problem here awhile back on a 88 spfi wagon it was the hose and regulator at the fuel pump
private message sent
Subaru Owners in the KY Area?
86subaru replied to coylethebarbarian's topic in Meet n' Greet. Your USMB Welcome Center
there are a few try the xt board, 3 that i know of -
Pneumatic Height Control???
86subaru replied to KNIGHTRIDER's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i took mine out also , put in adjustable front struts from a 85 wagon, took awhile to find some , , [ manual ] , i have been working on a 86 wagon and saw that it has rear manual adjustable struts also -
Timing Belt kits for EA82Ts?
86subaru replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
got mine on ebay , 74 bucks shipped all 3 pullies + belts -
my guess exhaust gaskets, my 88 turbo needs aleast 1 gasket passanger, and you get alittle fumes and sounds like leak in the front
Loosening stubborn oil drain plug...
86subaru replied to leej323's topic in Old Gen.: 80's GL/DL/XT/Loyales...
does your subaru have a skid plate ,if so remove it first ,much easier to gey to plug, i found that out -
air filter , 88 turbo a/t full 4wd wagon question
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so it might be better if i am going to do it , spend more $ for a better set up ,thanks -
yes just like that, saw the things at auto- zone, cone filter 24, plate 3-4 bucks ,30 bucks -
i have a 88 turbo a/t full time 4wd wagon, 109,000mi running good, 22-23 mpg city 25 hi, 2 -1/2 pipe from cat back [ no cat] air box cut out k-n filter, my question is it worth the extra cost to run a cone filter and do away with the air box , looks like cost will be around 25 bucks total , any hp gain etc.....
88 turbo a/t full time 4wd wagon ,question
they measure the tire with a gauge ,it was a 6out of 10 , only 7,000mi on the tire , everything is real nice now, but the flat tire on my 84 brat ,which they fixed 3 times , is no good , big bubble on side wall , i did not buy the tires from them that are on the brat, lucky i have 4 other tires and rims for my brat ., aleast i can move it around while working on other subaru's , -
heavy duty fuel line is what i used, got it at napa
they are sold in a store in just about every town , bud -
Hard starting issues with Weber?
86subaru replied to Mykeys Toy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mine did the same thing ,84 brat with a weber , in fact is was never hook up at all , it came from the deep south, tom from hills dale MI spent 15 mins and hooked it all up , maybe he will response to this post -
found problem, rear tire belt broken , tire is junk , not even 7,000mi on tire , called place they will give me a new tire -
bump ????????? -
yes all 4 tires the same , would the adjustable struts i have on the front might cause this ??? -
having problems with my pc , sooooooo one of these days i may not be able to dial up
trying to send private message, about thanksgiving weekend , sunday nov 27th from noon on i will be busy , any day before that would be good , friday nov 25th i am off work
