Everything posted by 86subaru
Cargo cover repair -Loyale
how much $$ do you want for them + shipping to 45365
Blowing white smoke
check the heater hoses mine did the same thing i had a bad heater core and hose , just something easy to check
Another Accell super coil Dead
10,000mi running great , on a turbo a/t full time 4wd 88 wagon
fan, blower not working
well the lines are all good , because when i recharged the ac i had to release all old free-on and there was plenty in there , when i have time i will fix the electric fan to come on like it should , i think i will take it to my shop and have them use a vacuum ,and get all the junk out of the lines and start over , all my fuses were good
went out after work and the fan on the dash 1-4 works now but no ac , ?? even afer running 10min , but hey aleast the fan on the dash works for the winter time etc...
ok, should i test right at the switch for power ? , i have 1 spare switch for an 86 , which is on the dash , all 4 speeds were working fine also
it is a 86 spfi a/t sedan fwd
i changed my compressor today ,charged my ac ,eveything was fine until the fan quit working , i checked the fuses all good , everything else works fine , dash lights, lights, radio, cigar lighter, dome, map, power locks, , what else should i check ? blower motor?
I'll be travelling from IA to FL and back in July (home now...)
100 miles north of cincinnati ,OH,
i am not sure what route your taking back , give me a private message and i will give you directions , i live along i- 75 , EXIT 99 , anna, ohio, easy to find
wtb baja topper
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks alot ,
wtb baja topper
my brother in arkansas bought a 2004 baja and ask me where to buy a topper fairly close to him , he may just go back to the dealer and ask , but he asked me first
Dead Horn
you can retune them , a mechanic that i know did mine
2x4 to 4x4???
you will need a carrier bearing mount , it hold the drive line , are you going to go from a a/t to manual ? if so pedal box , the exhaust will be different from a 2wd to a 4wd , i had a donor 4wd manual gl wagon and i put 4wd into a dl wagon , a few things i added was oil pressure gauge + a 4wd light , and found real nice blue gl-10 seats front and back ,
Changed fuel/air filters.now car wont run!
86subaru replied to kahoona's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you put the fuel filter on right, ? did you knock any hoses off ? i knocked off a main hose when i changed mine a while ago
Loyale Hesitation
i have the same problem 88 dl manual 4wd wagon, new acell coil, 8mm wires, ngk plugs gaped at .45 ,
which accord springs?
i used xt springs and it looks great
att, skip i am going to be in pa sunday
please edit
alt question
here is something strange , went to work this morning with my dl manual 4wd wagon , no dash lights , both my turbo wagon + dl have 8mm wires and acell coil ngk plugs , would the acell coil cause this ??
alt question
i took it off a running gl wagon, so it does WORK , just not kicking on
Greetings and Please Help
86subaru replied to Drummer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsell it to me , i am 2hrs from you
alt question
ok checked alt today with a meter , the alt is not working or kicking on ,the alt is good, i also checked the fuse it is good , is there something else to check ?
Hey Miles!
then after a week at alleyboys , come back over here for a few more days and help me figure the alt problem on my turbo wagon ,and pull the motor tranny from my xt
ea82 performance increase
by doing all this on my turbo full time 4wd a/t wagon it get 23-24 mpg city, 28-29 hi way , but the hp increase was great , and the motor runs cooler
ngk plugs, acell coil, cut out bottom of air box and run a k-n filter , gap your plugs at at .45 , 2 inch pipe from the cat back ,turbo muffler , no center cat , if you have a turbo motor , i call it the big football cat cut it out and run 2 in pipe back , there might be a few more like bumping up your timming ,
