Everything posted by ivans imports
Of my timing belt, pulleys, and Orbach's
ivans imports replied to The Chad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat timing kitt cost me 285$ at my local parts stores boy you guys get cheap parts down there.
2.2 in 2.5 outback agian
it came back in with 440 like gd said so i removed the under hood carbon can and used the outback 2.5 purge soiliniod and hoses. And found the thermostat had stuck open fixed that and all good thanks gd for the help with 440.
Relays & heavy wire to upgrade headlights
ivans imports replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsubaru used left and right headlight wireing every one else used high and low curcits i take the signal from one headlight to turn on my realays to turn on headlights and wire the power feed right off the post on alt gives me 100amps at 14.50 volts to my 4 100 watt headlights works spanky
96 Outback Auto Tranny Problems
ivans imports replied to ensoniq's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds like a blown planetary is locked up and running direct drive check the planetarys havent blown up is in the dead center of trans
EJ18 Question
ivans imports replied to Diablo9420's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe lifters tick because the front crank seal is dryed up and pulls air into the oil pump change the front crank seal first
starting a full time business NEED your inputs and ideas
Better bumper side mounting for all plastic bumper cars and rad support protectors to prevent tow truck damage have had many with rad support pushed up by tow trucks causes unseen but bad damage
ivans imports replied to The Chad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have 150 used coged idlers just from the last 6 months and have bought out all of the stock on them in western canada cant get them as fast as i use them
EJ25 crank wobble
ivans imports replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne thing iv'e leaned is the heavyer the crank pully the more tourque the engine makes i add wheight to mine to make it heavyer. And is why the 2.5 use's a heavy pully and the 2.2 use's a light pully. A lighter pully will increase hp but reduce toruque.
ea82 valve train question
when you grind cams you need to plane the cam caier down the same amount have seen thiss before
Buggy
took the buggy out to the beach agian was able to get it to hydroplane across water was going over a 100 ft of water without touching bottom. Hit the pond at 110 kms and from every direction.Thiss was a new experince for me. And had the high stall tourque coverter works so good and water methanol put 3 tanks of feul and two 4l of washer fluid and no engine problems or breakdowns
Works good no check engine light but random high idle somtimes not shure why mabee cause the outback was auto and the brighton ecu was a standard
Car ran very good and 0 check engine light
Good place to buy a stock carb?
put Tbi on it of a 86-94 ea82
Power steering pressure valve
love it if to mutch preshure will just colapse the spring back down agian I will try thiss on the fishing car. as the power stearing is had with the 235 75 mud terains was hard to stear over the rocks and hill climbs.
School me on EA81 DUAL-CARB engines
never a deul carb but just built a strong ea 81 for a hovercraft. we reground the cam used the bigger heads from a 87 chaser on the 81 solid lifter engine and put on a carb and intake from a 86 ea82 simplfyed down thiss engine worked realy good and i think the ea82 carb whould out pull the deul carb setup. we were shooting for 120 hp and i think we are realy close to that. was the snapyest ea81 iv'e seen even better than my TBI ea81.
EJ25 crank wobble
ivans imports replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake the reluctor gear see the two holes in it use a 8-125 tap and tap those two holes and then you can use a standard puller on it to remove it. When the crank gets worn i peen the end slightly to make it so the pully is tight on crank agian is arkaic but works also i peen the keyway slot to make key a tight fitt agian. And titen the poop outa it with some locktite also while your there check the thrust berring in crank have had a few with bad thrust lately worse on standard cars
Just a EJ22 thought and request.
ivans imports replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont know if anyone caught thiss or not the 95-96 25d is not the same as the 96and up 25d it uses hydrolic lifters and grafite head gaskets and bigger pistons. And go's 250000-350000 kms with no headgasket problems have one here 380000kms origanal headgaskets and no leaks. I tryed to buy the grafite gaskets but unavalabe to be had. Anyway thiss engine was the good 2.5d not to be mixed up with the crapy steel headgasket 96 and up 2.5d with the pain in the --- addjustable bukets.
New Orleans Brat!
i think if i had a choice thats the car i whould drive across the contry nice truck !
Thiss swap was different when i put in the 2.2 witch was from a 97 legacy L into a 97 outback 2.5d. I used the engine harness from the 97 2.2 and the ecu from the 97 2.2 and no check engine light ran good and still no check engine light. So ? is thiss 2.2 legacy L or brighton model a canaidian only model. Is that why thiss worked or is thiss just the way the swap should work is the first one without a check engine light. With egr codes the 2.2 brightons never had a egr and the 2.2 ecu plugs right into out back. Did the 2.2 usa legacys L and the brightons come with egr in the usa ? or a diferent emistions programing or standards ?
EJ25 crank wobble
ivans imports replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave fixed many with thiss problem got realy good at it in car pully key reluctor and time
ivans imports replied to The Chad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome make noise but most dont its a berring when it fails it fails thiss year i caught 4 in time were the berring was failed but not seized sounded like a rod knock. But most lock up and shear the bolt and bang ! Thiss outback had less than 50000kms on subaru rebuild xx 0.25 block. Dealer put the old idler back on and ruined the new engine. Have had five of theese xx 0.25 blocks all same deal new engine old idler bent valves. So i asked the dealer why reuse a old ?able part there answer { only needs to make it past waranty } I can tell you every one of my ej motors have a new coged idler. And will not install a ej motor without a new one used motor or new motor even if new idler i change it anyway
1990 Legacy -- jumping idle
i see this problem when is low on coolant the temp senser gets above the coolant level and dosent read properly check coolant level or icv or somone has addjusted the tb hard stop
ivans imports replied to The Chad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave a 98 outback wth 16 bent valves 220000kms seized coged idler pully in one year over 40 seized coged idler pullys and buckets of bent valves that guy listened to the dealer { you dont have to change that part if its not bad yet ] cost 3000$ coged idler is 45$ need i say more
Howbout do it your self subaru speacalty tools have some realy good homade subaru tools and diagnostic tools
Help Needed... Wont crank over
put a bar on engine make shure cranks by hand and put a battery in it allready check the main power feed comes off the + battery termanal and gos to fuseabble link box
