Everything posted by baccaruda
"Trimming air box"
My "data" is one run up the east (steep) face of the pass at Vantage, WA with my turbowagon, pre-chopped, wherein I maxed the car out in 4th gear at like 55mph.... then I had occasion to take the same route later that year, similar weather conditions, post-chop, wherein I was pulling 90 in 5th and could have pushed the car harder. That, and 45 felt like 30 for a short bit whilst bombing around town. Whoops.
"Trimming air box"
it improves performance for turbos quite noticeably. for all other engines the increase is negligible but the noise isn't
Brake reaction rod mod---Now Pics added to the thread!!
well look at you being all sensible and seeing if he'd been logged in recently
Caliper Removal
do you just need to change the pads or to actually remove the entire caliper?
Milage Machine. Ideas
lots 'o good advice here... don't forget to keep the car clean and waxed!
your keys
that looks to be from an 1874 Subaru "Horseless" Coupe.. IIRC those had wooden pistons for N/A and petrified wooden pistons for turbo...
Solo, could you please resurrect the pics for this thread and update us (me ) as to how they're holding up? I'm looking at heim-ing my wagon's strut rods but I was going to put the heims at the forward end instead... thanks! Andy
EA82 seats into an EA81
I've never been able to get a straight answer on this. It does mean "EA81 series" but I have no idea where "MY" comes from.
Spare wheel storage for Hatch??
Subarino's on the right track - Mike W once told me that he wouldn't have mounted the side carrier the same way if he could do it again, because the upper mount is weird to configure to the car.
Bizarre XT6 power steering issues
You could bypass the stock power steering wiring harness if you had to. Make an intermediate harness. It might be less of a pain than disassembling the car...
Why I think tire size calculators are for the birds.
http://www.miata.net/garage/tirecalc.html ? Zap, what kind are those in the middle?
EJ Swap write-up final
ok. you might throw a copy of the HTKYSA.pdf up there too....
I'll host a copy as well?
ea-ej exhaust ...
that's cool to know... but some earlier EJ22 motors came with dual exhaust ports in the heads instead of single... FYI
regarding 5 lug swap
- L Series Workshop Manual pdf ?
(please right click & save to conserve bandwidth!) http://www.worldwidecm.com/HTKYSA.pdf is that what you're after? or are you after an FSM?- Wide tire thread: 245 and growing....
changed my mind, I want the 5-lug swap back.- Poll- best subaru colors
all of them http://www.ultimatesubaru.org/Literature/brochures/brochures-80-89.html- New tires for the OBS
don't you lol at me, sucker. I thought they looked swamperish but the sidewalls strongly reminded me of the snow tires I've got on my coupe now..- New tires for the OBS
what kind are they?- EA82 5sp into GL-10
Hey Chux, have you tried MMO or ATF in the trans? My RX trans in the wagon shifted a little reluctantly from what I remember (it's been off the road for a couple of years ) and I appreciate the tip about the Rislone. I used it in my Barracuda with every oil change and I think it helped... Are you using it as a conditioner or as a cleaner (to be changed out after a while)?- Flushing the Heater Core
this shot is taken from the driver's side of the car - note the starter for reference. My car has a 4" lift (the engine is dropped 4") which is why the hoses are at funny angles.. but it should help you!- Pick my car
the EA81T is a great motor but parts are hard to find. I have the dubious distinction of having bought the last OEM waterpump in the country, from what i can tell. If parts were plentiful, I'd say hot rod it all you want.. but don't.- Can I make my subaru safe?
keep the brakes in top shape or give yourself extra room if they need work, as I'm doing now with my car- Split motor mounts on an EJ22>Loyale swap
https://www.subarugenuineparts.com/product_info.php?products_id=657 - L Series Workshop Manual pdf ?
