stngllhm
Everything posted by stngllhm
  1. i think it would be really cool
  2. another way to tell if it is a 1600 ar 1800 is the position of the starter if it is on the very top it is a 1600 if it is an 1800 it will be off to the driver side on top hope this helps
  3. i wanted to do something like that with my 84 wagon but i never got around too it. than i finally gave the car away
  4. you can do that with the ea81 bodies but the ea82 doesn't have a screw to tighten. atleast i haven't found it
  5. on my 87 gl-10 the sun visors are always falling down i got some velcro tabs to hold them up but it is kinda getto looking. i was wondering if there are any tricks to fix this problem
  6. what year of soob did your computer come out of and what color where the wires you switched this sounds like what my car is doing
  7. y'all are nuts sweet rides but you are still nuts<G>
  8. what i was trying to say is with the victor rienze you don't need permatex but if you wern't going to use victor rienze you would be better off to use only permatex just use the victor rienze with no permatex and you should have no problems i hope this reply made more sence you will be ok just running straight water for a short period of time some things you need to keep in mind is winter is coming and it could freeze straight water has a lower boiling piont and antifreeze also helps keep your water pump lubed
  9. it's snowing out side!!!!!!!!!!!!!! sweet!!!!!!!!!!!!!!!!!!!!!
  10. man tough blow that is why you always have tow rope and take it as soon as you see it
  11. amen to that(i hate my ford why can't subaru build a full size truck)
  12. i don't think they are needed unless you have a desiel. i know my subie starts fine at -20f usally when it is that cold out i try to stay home
  13. i can't tell you what the flat rate is. but i changed the cable on my 84 and it wasn't that difficult
  14. i've never had a problem with cleaner messing up the injectors. personally i like BG44k but it is like 15 bucks or more a can
  15. you won't need too with those gaskets if you where still going to use the felpro i would say yes. but the directions i would give is thow the felpro C**P as far as possible and use permatex
  16. most are 36mm doesn't mater which body(ea81-ea82) i have only ran into one that was a 30mm autozone will loan either
  17. if you can't find one i have a bracket and pully you can have for the price of shipping
  18. if you are talking about your donut spare the rims are way to skinny
  19. i definitly want one just got to wait till i have the money
  20. instead of opening up the tranny some diffrent ideas where discussed on a thread i started http://www.ultimatesubaru.org/forum/showthread.php?t=23089
  21. i've got a set that are beyond redemption but you would have to come get them or pay for shipping which i'm pretty sure you don't want to do so why i'm i writing this will someone tell me please<G> i know i'm a freak
  22. what temp does the t-stat open at never mind last time i read though it didn't say and instead of reading though again i just posted so sorry
  23. i had alot of problems with that gasketdon't by felpro every time i have tried to replace that gasket with the felpro it has blown within the month(yes i am a slow learner happened 4 times) since then i have started using victor-rienz(i hope that is how you spell it) from carquest and haven't had a problem
  24. it is a little off topic but i have a 2wd 3-door sedan that has xt struts on it can i put them on my 4wd gl-10 wagon
