Everything posted by stngllhm
Stereo Install- Can I cut this?
stngllhm replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the first stereo i put in my 84 i just left it hanging out a bit and you had to be carefull shifting into third. when i took it into get the tires replaced i told them that it is hard to get it into reverse and when they get to that point have me come and pull it out. well they didn't and in the prosess of fighting with the shifter ended up trashing my radio. i was pissed and they wouldn't do any thing about it. thankfully it was a cheap tape deck. the secound deck i put in there was around $400 and i put it at a slight angle so that it was in the console all the way. the next time i ad tires put on i told the people installing the tires about last time. and warned them that if they hurt it they would be buying me a new one. it was amazing they called me back to back the car out. -
88 3 Door gl E-Brake not working
stngllhm replied to N8NQU's topic in Old Gen.: 80's GL/DL/XT/Loyales...
how worn are your front pads. i have noticed that the closer they get to worn out the more you have to pull up on the e-brake handle -
EA82 Caliper questions
stngllhm replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
auto zone will lone you the tool for a $30 deposit that you get back when you return the tool -
Am I dumb??? What am I doing wrong??
stngllhm replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
build a spanner wrench. what i did was take a piece of metal about an inch wide and 2 foot long drilled two holes in it to catch two of the four holes on the cam pulley and put a 1/4 bolt and nut to hold the bolt to my wrench. \ i found that you want to go for two holes right next to each other i wasn't thinking right when i drilled them the first time and i made it to across the pully . kinda hard to get the wrench on there to get the pullys off. the wrench will also help when you go reinstall the timing belts. if you don't want to make a tool. just get an impact wrench. and since these are non interference moters you don't need to worry about bending valves -
get rid of the stock air box and put a k&n cone filter in, get 8mm spark plug wires, and open up the exhaust some
http://www.ultimatesubaru.org/forum/showthread.php?t=23610 http://www.ultimatesubaru.org/forum/showthread.php?t=23763 check out these threads i have 2.5 exhaust on my turbo and a noticed a big deferance in power and the turbo spooled alot faster. and i already had a gutted cat before i put the 2.5 on
Can i tow an XT6 with a tow bar?
stngllhm replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks for the info. i was going off what my parents found out when we where trying to decide what car to tow behind our moter home my 84 gl wagon or my sisters 87 gl-10 wagon<which is my baby now> and we were told you couldn't tow the 85 and newer on a tow bar. it is good to know i can -
i know you can't tow the 85 and newer wagons on a tow bar cuz the steering won't track right i bet you will find the same problem with the xt. i believe we called the subaru dealer to find out. -
get a piece of cardboard and try blocking off some of the air flow to the radiator.
tranny has a hole in it. (WHAT TO DO, WHAT NOT TO DO)
stngllhm replied to s'ko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i'd say time for a new tranny. hey just put a 5-sp dual range in -
Sure glad I had an old 4WD Subaru today!
stngllhm replied to MorganM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that is because they are too under powered to brake the tires loose in 4wd even on ice.<J/K> -
? for those with pyrometers
stngllhm replied to stngllhm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
btw that is my gauge -
The probe is about in inch behind the turbo. i know it is suppose to be before the turbo right off the engine. but right behind the turbo is a lot easier to get too. My mods are 2.5 inch exhaust, spider intake, and wrx tmic, oh and a two row radiator i also have a air fuel gauge and the car always runs on the rich side unless i'm idleing -
i am curious what my exhaust temp should be running at. At light throttle just cruzzing I run between 800 to 1000 degrees. If i'm pushing it hard staying at full boost it runs around 1400 degrees. I'm just running stock boost. I'm was wondering if these temps are normal
Ignition/fuel cut...on stock boost
stngllhm replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if the tps turns out to be bad i may have an extra one comeing into my hands that i could let you have -
next he's going to tell us it was snowin and he was bare foot too<G>
in gen 3 car the brat is a gen 2
Does anyone tow with a 1.8L FWD wagon?
stngllhm replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you have trailer brakes and like going slow you could do it. i did tow my 57' chevy truck on a car dolly behind my 84 wagon but i wouldn't recommend it. i was going less than a mile. the brakes where the main problem. the car is so light that the truck would over power them -
i can't answer all your questions but for the power stearing i believe 80-84 wagons, 80 and up hatches, and 80 and up brats. if i am wrong someone please correct me
computer is under neath the stearing wheel
Thanksgiving Weekend Projects
stngllhm replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what ever happened to not moddind the rx -
absulatly nothing and it feels so good<g>
