Everything posted by stngllhm
interest-O-meter
i think it would be really cool
help on vin codes
another way to tell if it is a 1600 ar 1800 is the position of the starter if it is on the very top it is a 1600 if it is an 1800 it will be off to the driver side on top hope this helps
Any one cut the back off there Subie?
i wanted to do something like that with my 84 wagon but i never got around too it. than i finally gave the car away
visor falls down
you can do that with the ea81 bodies but the ea82 doesn't have a screw to tighten. atleast i haven't found it
visor falls down
on my 87 gl-10 the sun visors are always falling down i got some velcro tabs to hold them up but it is kinda getto looking. i was wondering if there are any tricks to fix this problem
EA82T Masters: Help Me Fix One Small Issue...SOLVED!! read last post
what year of soob did your computer come out of and what color where the wires you switched this sounds like what my car is doing
y'all are nuts sweet rides but you are still nuts<G>
Now what do I do?
what i was trying to say is with the victor rienze you don't need permatex but if you wern't going to use victor rienze you would be better off to use only permatex just use the victor rienze with no permatex and you should have no problems i hope this reply made more sence you will be ok just running straight water for a short period of time some things you need to keep in mind is winter is coming and it could freeze straight water has a lower boiling piont and antifreeze also helps keep your water pump lubed
time to get the snow tires
it's snowing out side!!!!!!!!!!!!!! sweet!!!!!!!!!!!!!!!!!!!!!
*Un* SCORE!!! Hard to beat Free!
man tough blow that is why you always have tow rope and take it as soon as you see it
Generalised spark plug questions
amen to that(i hate my ford why can't subaru build a full size truck)
engine heater??
i don't think they are needed unless you have a desiel. i know my subie starts fine at -20f usally when it is that cold out i try to stay home
Air-Con Prob
that has my vote
Replacing the Clutch Cable.
i can't tell you what the flat rate is. but i changed the cable on my 84 and it wasn't that difficult
fuel system cleaner
i've never had a problem with cleaner messing up the injectors. personally i like BG44k but it is like 15 bucks or more a can
Now what do I do?
you won't need too with those gaskets if you where still going to use the felpro i would say yes. but the directions i would give is thow the felpro C**P as far as possible and use permatex
cv help
most are 36mm doesn't mater which body(ea81-ea82) i have only ran into one that was a 30mm autozone will loan either
Need power steering bracket
if you can't find one i have a bracket and pully you can have for the price of shipping
15 inch wheels
if you are talking about your donut spare the rims are way to skinny
Oil Cooler adapters,permanent avalibility!
i definitly want one just got to wait till i have the money
Swapping Turbo output shafts into dual Range?
instead of opening up the tranny some diffrent ideas where discussed on a thread i started http://www.ultimatesubaru.org/forum/showthread.php?t=23089
a few questions
i've got a set that are beyond redemption but you would have to come get them or pay for shipping which i'm pretty sure you don't want to do so why i'm i writing this will someone tell me please<G> i know i'm a freak
what temp does the t-stat open at never mind last time i read though it didn't say and instead of reading though again i just posted so sorry
Now what do I do?
i had alot of problems with that gasketdon't by felpro every time i have tried to replace that gasket with the felpro it has blown within the month(yes i am a slow learner happened 4 times) since then i have started using victor-rienz(i hope that is how you spell it) from carquest and haven't had a problem
replacing air suspension
it is a little off topic but i have a 2wd 3-door sedan that has xt struts on it can i put them on my 4wd gl-10 wagon
