idosubaru
329
Topics posted by idosubaru
What causes door "sagging": hinge, striker bar, or inside the door mechanisms?
By idosubaru, in Old Gen.: 80's GL/DL/XT/Loyales...
- 10 replies
- 2807 views
Is there an aftermarket exhaust flange to bolt up to the header with donut?
- 2 replies
- 802 views
How badly are trim pieces/clips damaged during windshield replacement?
- 3 replies
- 1929 views
Help - need to remove outer cv from front axle - XT6 stranded
By idosubaru, in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 9 replies
- 1497 views
- 4 replies
- 2093 views
Are 02 EJ axles longer than 90s? Axle so tight cv roll pin hole can’t line up...
- 23 replies
- 2304 views
Rear suspension - one tire rubs the mud guard in front of it, the other side doesn't.
- 9 replies
- 1248 views
Non rebuildable 05-07 legacy/out/tribeca starter solenoids
- 2 replies
- 1599 views
How do you tell if a CVT trans or valve body has failed?
- 4 replies
- 624 views
EJ22 no start, good fuel, cam sensor code
- 7 replies
- 1158 views
Cracked rear diff bushings - refreshing with window weld
- 7 replies
- 1056 views
Anyone know if Land Rovers are actually reliable or not, or both?
By idosubaru, in Non Soob Cars and Bikes Discussion
- 8 replies
- 623 views
2014 OB 4 cylinder Check Engine and Brake light flashing
- 6 replies
- 676 views
9 volts on Tribeca- can a bad battery cause low alt voltage?
- 23 replies
- 1562 views
- 2 replies
- 1661 views
2017 Forester oil dipstick will not go all the way down, oil tube is not bent or deformed - front end deer impact
- 2 replies
- 450 views
How likely for CVT damage on a wrecked 2013 OBW with severed ATF lines?
- 9 replies
- 456 views
10 years old and no one has tried to swap a Forester/Outback CVT transmission?
- 6 replies
- 1063 views
2008 aftermarket radiator has a nipple cover on top passengers side but stock doesn’t?
- 3 replies
- 354 views
06 Tribeca taillights work with parking light but not headlight
- 0 replies
- 237 views
What legacy struts permit 225 60 16 Outback tires?
- 3 replies
- 431 views
Drivers side low beam doesn’t work, new bulb
- 8 replies
- 677 views
Any XTs in Colorado yards - I’ll be there next week
- 0 replies
- 399 views
Feel dumb - how to set starter motor back into brushes
- 4 replies
- 518 views
Tactrix and Romraider to disable codes on 2005+ non turbo Subaru ECU's?
- 20 replies
- 3455 views
