idosubaru
  1. valve spring compressors are a good thing to be prepared for. i made my own tool. run all thread through a socket and then cut a notch in the side of the socket to pull the keepers/retainers, then run the other side of the all thread through a cam sprocket or crank pulley as a "handle". lean/push on it , remove keepers and out comes the spring. probably not a method that's good for everyone, i've done entire engines with it, but I won't be compressing them by hand when i'm older. and why do i do that? because i don't do enough to warrant an expensive tool and i don't know of any lower end ones that work great. but i've done all EJ25's and older gen stuff, not much EJ22 valve spring stuff, maybe EJ22's are easier? the two valve spring compressors i own/use aren't very good for Subaru's, i can cobble them together and frustratingly maybe sort of make them work on most valves, but on some with little side clearance with the head casting they dont' really work at all or you'd spend about an hour on each valve getting dialed in just right. in general the ones you see when you walk in a store suck for Subarus. a thread started about which ones to use with little concrete or widely available tools referenced: http://www.ultimatesubaru.org/forum/topic/124419-what-valve-spring-compressor-do-you-use/
  2. I'm simply looking at facts here - they've done you right so far, fixed everything for free, and now the person on the phone, who usually isn't a mechanic or technical, won't guarantee a free repair over the phone on a car they can't see with customer diagnosis. Given the facts, this looks like a great dealer. Take it to them, let the cards fall, then worry about it.
  3. Yes voltages across multiple points. Do those have external voltage regulators? EA82 and newer do not.
  4. Alternator failure Crank pulley separation Serpentine belt compromised Battery clamp terminal or cable issues
  5. Wow. How.m bad is it rolled? I can't see it but Why not just plop it back down in there, maybe massage it a little if needed and run it? It just needs to sit there. But yeah - install another head and carefully check the motor like he said.
  6. MAF/MAP - they're not on the engine - did you replace all those? Will these engines run by disconnecting the knock sensor? If so you could disconnect it or jump it with an appropriate resistor as a temporary test of the sensor and circuit. I'd still disconnect the fuel line when it's not running to make sure fuel is flowing. You can install engines and pumps all day long but if nothing is getting through they're all useless.
  7. 1. Swap the MAF. Www.car-part.com or post in parts wanted here. 2. When it does it again pull the fuel hose and crank. If it flows like a hose the pump is fine. If it trickles out you found your issue.
  8. As said rarely do ECUs fail. But they are cheap and easy. Car-part.com and buy the cheapest one in the US. EJ25s work as well. Use one from a manual transmission. But you can't use a 99 Legacy EJ25 or Outback as those are Phase I. So for EJ25s use a 99 Forester, or any 2000-2001 EJ25. And again I think you have to use a manual trans. The one you mentioned should work. There are two different sets of cam/crank triggers in 99+ vehicles and I *think* those triggers vary based on auto and manual. thoae two different triggers are the only variation for 99-2001s you need to worry about. And actually I'm older Subarus they could actually run automatics or manuals, they can *tell* what transmission it is by the pins. Install a manual ECU into an automatic no big deal. But I'm not sure you can do that with Phase II stuff.
  9. Thanks John I added a nibler to my cart, I've wanted one before. Good suggestion. I have a shed roof to replace I can cut too. As for the torch I was just wondering if I could torch out a section way bigger than just the panel - more like the rear 1/4 of the car. But that's pointless I should just rip a panel out, if any damage is worse than that I probably can't fix it.
  10. Haha. By yard do you where you live and sleep or where you work? How does that EJed XT drive? Gas mileage? Mountains I imagine are a breeze?
  11. Anyone here do anything besides keep a parts car sitting on their property? Or am I in a minority since few rust belt folks drive these and others don't have as hard a time getting parts? I have two XT parts cars and would like to reduce to one or none by my house. Parking them in my fields means grown up, rodents and ugly. Cutting out rear quarters, glass, bumpers sounds time consuming but probably what I'll do. I'll probably just pay a window guy to come remove all the glass. How fast can I torch a rear quarter panel or front fender rails off? I could build a pole building maybe and make it big enough for one and my tractor and equipment. Anyone else?
  12. It depends what year 2.2 you have, you didn't tell us. In a 1999 Impreza RS you can only install a 1999-2001 2.2. if that's what you have then just bolt the EJ25 intake manifold onto the EJ22, it's the same bolt pattern. super easy. if you're using a 1998 or earlier 2.2 then that's not the case, this is not a desirable swap. the intake manifold bolt patterns are significantly different and not interchangeable. that's not the ideal swap and you'll be cobbling stuff to get it running and then it's not going to idle. to start - swap the 2.5 harness onto the 2.2 manifold so you can at least run it, then prop the idle open so it idles/runs somewhat because the idle control is a huge difference. then trouble shoot other issues from there.
  13. can someone post the pictures here and then a mod could just put a link to this thread in that one - or attach the pictures to that write up? maybe i'm wrong but i'm baffled why anyone thinks hosting 3rd party is better than just attaching the image locally particularly with a write up.
  14. listen to GD or Gloyale on this one. but i generally replace valve stem seals, and i'm admittedly uncertain on whether seals or guides are a concern during bent valves incidents. Subaru or Fel Pro are great fits for an EJ22, but let them chime in on other brands as I haven't had to pay attention for years since EJ22's have all rusted away around here.
  15. as FT said OEM stuff can fail prematurely, timing belt failures have occurred on stock Subaru's with untouched timing gear before 100,000 miles. not sure of anyway to prove either one, but a tensioner needing recompressed even during an initial install is not shocking and probably higher odds:
  16. right on, i wasn't denying it. my question to him offline was "make sure you don't have an oil issue that caused this", but for me it's more a guess than you guys. thanks again GD and GLoyale.
  17. Thanks. I'm just asking to learn, this is out of my experiences. scarred surface - could be smoothed down and avoid damaging the rotor, But I realize we're taking about the block so you can't just hack at that.
  18. What he said. Normal just carefully move it back. If you're reusing the tensioner compress it very slowly. Compress a little - go get a drink. Compress a little - make lunch. Compress a little - watch game of thrones. Wash rinse repeat. I'm exaggerating but follow the FSM directions and don't do it too fast. They do ocassonalky fail and excessive compression speed is specified as bad.
  19. Grease - use Sil glyde. Shops I know use the purple permatex (not that green stuff, that's awfully low grade at least around here) and I'd run it bass on their recommendation. Sil Glyde is so good I don't bother trying anything else. I wouldn't call tight or loose calipers a diagnosis of anything, I'm not sure what makes one worse than another to turn but I've never seen it correlate with future issues so I'd hesitate to suggest that alone means anything. they usually seem tight to me to get in. I have the special tool and it often slips off due to being tight. Its not indicative of a specific issue though. If I had to guess maybe it's more of a function of the bore seal and fluid movement within a closed/semi-closed system. It's been a couple years but I feel like the ones I rebuild off the vehicle go in with less effort as they're not pushing against any fluids or system components. I've left torn boots for years without issues, may depend how much northeast salt it sees and gets in it.
  20. Can you edit the thread title still and add "XT6" for easier future reference/searching since these are different from EA timing gear?
  21. What makes you think it won't have the marks? Use the marks on the cam sprockets and the mark on the rear lip, not the front face, of the crank sprocket. Google for pictures to clarify the marks if you need it.
  22. I've been driving XT6's for over 20 years so that's the reason I'm familiar with this. Aftermarket timing pulleys for EJ engines have a higher failure rate than OEM. Theres a good chance this holds true for older and more obscure parts as well. I doubt old parts with little demand command high design and materials and assembly sourcing costs from suppliers. Last I checked earlier this year you could get all the pulleys or bearings for them except one of those drivers side idlers was not available nor could the bearings be sourced. That's the only tricky one. A machine should be able to easily fit a replaceable bearing to it for probably less than an hour labor if you didn't want to wade through that yourself. I'm busy now but could organize this info a little more clearly when I'm not traveling and on my phone, if you're confused on how many pulleys/bearings there are.
  23. Great write up particularly that evaporator work, nice! I'll be looking this up if I come across a contaminated system in the future. Another option is replace with all used parts. pulling a vacuum isn't required on Subarus. The normal HVAC conceptual talk about moisture is true but far from reality. Ive charged gobs of Subarus now for a decade and 100,000+ miles without one issue, there's clearly some missing information. I also started a couple threads years ago which now have many successful follow ups doing the same thing. Zero issues. If I charged money to work on cars or lived down south I'd dig out my vacuum puller with 10 years of dust or buy a commercial one.
  24. fix the known brake issue first and check both sides for that same issue. Wheel bearings routinely fail without play or temp symptoms on Subarus. Really annoying to diagnose sometimes. Noise under toque/load is usually an inner axle joint issue but yours doesn't seem like this Nia the case being a "squeak" and always making the noise.
  25. Are you guys assuming something caused this rather than the pump simply failing? I think that's what you're getting at which was my initial thought as well. If Someone recently worked on this vehicle - is there any damage they could have done to cause the pump to fail? When you were removing the pump were there any signs of someone mangling the sprocket, shaft nut, pump or improper sealant or bolt installation?
