idosubaru
344
value? like to sell, not sure what you're asking? around here I feel like there's a small market for older pre-2005 stuff. rust devalued 90's stuff, now it's devaluing/devalued pre-2005 stuff, so i wouldn't expect the engine you describe to be worth much around here. i have an EJ25, was offered another running one for free, but just not worth my time any more. but in the right area, with the right demand, yes there is value to it - depending what you mean.
Why aren't you following your owners manual? Back up, and start there. You're over thinking this - "Subaru" does not recommend what you're saying, the problem here is that you're giving credence to inappropriate sources. A mechanic, shop, or "service advisor" is generally not even close to the best source for best maintenance approaches. They're bound by one-size-fits all organizational constraints and not vehicle/owner specific goals. You can always beat mechanic/shop maintenance practices if you have a small amount of time and capacity to learn. But even if you don't have any of that - Follow the owners manual, Subaru doesn't make oil so you are correct that their oil offers nothing over other options that meet the owners manual specifications. "recommended" does not mean "required". "recommended" from a salesmen is definitely largely unimportant without some compelling data behind it - which obviously isn't the case here. http://www.cars101.com/subaru/outback/outback2016.html#maintenance Clearly stated 6,000 miles and synthetic oil, like these dealers publically state (though their other intervals and suggestions should all likewise be ignored): http://www.planetsubaru.com/subaru-service-and-maintenance-menu.htm http://www.patriotsubaru.com/subaru-service-schedule---2015-models.htm http://www.stanleysubaru.com/new-subaru-maintenance-intervals.htm Of course a dealer recommends things - do you always follow to the "T" every single product recommendation you buy in the owners manual, on the receipt, on the website, on their tag, on their label, on their documenation....no of course not, you don't even look at or know all that stuff for every gadget, device, appliance, supply, and product in your home.
Sticking brushes like he said. It's 100% repeatable like that every time - comes on after a few minutes or just happened like that one or two times? I've seen some 05-09 models have clogged/linked condensation drainage lines and flood the interior. It's probably not possible for that water to get to the fan and you'd most surely see wet spots in the interior if it did. So I can't foresee that being an issue
- 7 replies
- blower fan
- 2008
(and 1 more)
Tagged with:
Why does it need adjustable? i mean is that a diagnosis, I'm not questioning if you just want them, if that's the case I totally get guys , trying to understand what's happening and why mechanically. Maybe it needs new springs or struts or both of any sort? My OBW would jump sideways when hitting bumps and oscillate ocassinally in the rear. New KYB springs solved that. Current springs are over a decade old with lifted mileage and usage. Baja turbo rear springs are commonly used on OBWs for a little stiffer and slight lift. Isnt it possible to lift it 4" without issues?
A confirmed diagnosis would be good. Who knows what could be possible on a car that sat for two years. Keep an eye on: 1. coolant level/leaks/too much air 2. fans 3. if the radiator might be clogged - I think this is usually repeatable - like it's going to overheat more when it's hot out because the rad can't throw away enough heat, but works fine in cold 4. thermostat is flakey - could it be rusty from sitting? It sat where - in a frigid, muddy, rodent infested hedge row or a pristine heated show room garage?
That's a good pint. Read the Amazon reviews. Probably a great central location for hearing success stories. I get that sometimes it works. Read those reviews with the following in mind. It's not long term high percentage, has risks and may lessen the vehicles value should something go wrong. plenty of the reviews are probably for simple leaks, not necessarily combustion chamber breeches. Just like Phase II external EJ leaks, that's a different story, those are easy. And nonSubarus may seal easier = apples and potatos. also a lot of those reviews are people saying it's fixed and then not long after posting they're probably right back at it again. I can literally find dozens or hundreds of "XYZ fixed my head gasket" then later "oh wait no it didn't" posts on Subaru forums, see it often- people think it's fixed and it's not. Just saw one yesterday. Those same people review on Amazon and don't follow up with "no it didn't" I doubt most people doing that stuff are concerned with 100,000 mile 5 year reliability. How many reports like that do we have - many years and miles? Many are limping basket cases along on pocket change. If that's your goal - sure try it, I get it, I was in college paying my way through once too. Agreed. Sifting through reviews looking for similar situations vehicles and symptoms would be a good check.
How's the gas mileage and performance? P0420 is generally benign unless it's accompanied with bad gas mileage or performance. How much longer do you plan to own the car? Being in good tune is helpful. If it needs air filter, plugs and wires then do those. PCV valve is super easy and cheap. If O2 sensors are ancient those a good try and particularly the front sensor can improve gas mileage a tiny bit (or much) so it can recoupe the replacement cost over the life of the vehicle. So I see things like this as good chances to update important parts. Testing O2 sensors wouldn't be a bad idea or just replace them but you might not want to just replace parts depending how long you're keeping it. But yeah if you don't want to throw parts at it you have some testing to do or throw a catalytic converter at it - that generally fixes it even if it's partially tune/performance related, the new converter may be more forgiving. Used is an option but probably not in CA, some places don't sell them and I doubt CA is easier. I've used aftermarket before without issue, even cheap eBay specials, though I'd guess that's hit or miss. Walker? The catalyst material is expensive so if it's cheap and no compelling reason it's cheap it's probably a low grade unit with limited catalyst materials.
EA82 oil pump problems
idosubaru replied to Mustakrakesh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
all it's going to do is leak oil, i'd be willing to try it with a missing bolt. EZ outs suck, don't even have one in the garage. anything that comes out with an EZ out will come out with some other better method. EZ outs are supposed to grab the remaining bolt and back it out. they are strong but brittle (like concrete blocks). so they are prone to breaking with any kind of impact, even though they can take huge loads. they're great in a perfect machine shop with excellent tooling. they suck for DIY stuff like this. break one of those off - and you're in for a 100x harder problem than you current have. left handed drill bits can help back the bolt out sometimes. start with the smallest bit you can - as a sort of pilot hole, then move up in size from there. try an abrasive to get the surface smooth so you can get the drilling started in the center rather than off center. on a really bad water pump bolt i had once i drilled a hole adjacent to the stuck bolt and wailed on the bolt until it "tilted" into that adjacent hole so to speak. then helicoil it. but you can't really do that unless you have a spare block to drill into to verify you're not going to hit an important cavity or passage where you drill. i had extra blocks and could just drill huge holes to test before i did it on the engine at hand. -
for that matter - just drop it in the vehicle you're going to install it in and "test" run it with the bare miminums hooked up? And don't buy craigslist, cheap specials. every EJ engine i've bought from a junk yard or helped someone with has been great. the cheap craigslist specials that i've seen other people buy....knock, don't run, melted inner timing covers...surprise, surprise. i know it's not that simple but with yards it's sometimes possible to tell the car was rear ended, has a blown trans, tested by the yard, etc - things that nearly guarantee the engine was fine.
the fixes in a bottle *might* limp the car along for some unknown amount of time with severe downsides mentioned by caboob. they're like band aids - they're not long term, reliable solutions...if they help at all, they are going to come undone at some point in the future. It makes sense - ICE's are high temperature, pressures and cycling - 1,000+ degrees, 200 psi - roughly equivalent to woman in 1,000+ degree high heels stepping on your face. this isn't a simple, benign fluid loss situation, and it's almost comical to think it's an idea with excellent success rates. are they worth a shot in some situations? maybe in a rust rotted north east special with no chance of living more than 6 months. are they worth a shot in a financially desitute situation....i doubt it. a financially struggling person, IMO, needs to start making great long term financial decisions and quit thinking short term, and a solid car that can last another few years reliably is better than limping along, getting stranded again in 6 months, and needing some other cheap craigslist special that's going to cost more to maintain/fix repair than they can afford as well. there is a specific Subaru engine that responds well, in certain situations, to a Subaru Coolant Conditioner - that's a very specific engine, and even a very specific failure mode of that engine. It is by no means applicable to any other engines or failures modes. that boils down to physics and facts - not opinions. yours is not one of those engines nor one of those failure modes. you can include links to "readings" you find and we can address those more specifically though i imagine you're talking about the Subaru Coolant Conditioner or Blue Devil.
1. Subaru headgaskets (fel pro seem to be highly touted as reasonable replacements by folks on here in the past, i haven't used them) 2. resurface the heads - find the post on here and you can easily do it yourself. it's so simple 3. get the Subaru FSM - they're all over the internet for free those heads are really easy to replace - the headbolts are external and the easiest ones Subaru has ever made. remove timing belt unbolt power steering pump and a/c compressor and swing them both to the side of the engine bay (no need to disconnect the lines) unbolt exhaust manifold remove intake manifold - disconnect fuel lines, throttle cable, spark plugs, engine wiring harness connector, and alternator wiring, and ancillary grounds, etc. unbolt heads you can even do it in the vehicle - just unbolt the top pitch mount (one nut/bolt) and remove the two lower 14mm engine mount nuts - and jack the engine up a few inches.
thanks for posting that - probably helpful to someone in the future. i think i'm accustomed to seeing one posters too and i've seen mostly 87+ EA/ER engines. so it looks like there's an 86 and earlier variant and 87+ probably? slap the part numbers up here if it's easy. you want me to check for a used one?
they probably used low grade gaskets. or they didn't clean/prep the surfaces very well or used a poor torque procedure (if they used one at all). i can almost view this two different ways: A. it was such a poorly maintained car, it's probably got some damage somewhere that will creep up later in the form of bearing woes. or B. the repair was so bad that the car wasn't even drivable to the extent that it caused any damage so you've got a great long block to properly reseal?! seems like it may have had a minimal leak, poorly attempted repair - and not driven much? which do you see?
bearings aren't cheap, machine shop work isn't cheap, checking clearances, over or undersizing - it just gets labor, parts, and $$$ intensive. main bearings, rod bearings, piston rings, honing. people do it, it's not necessarily difficult, typical bolts and engine stuff, nothing complicated or abnormal. I've always wondered why can't you take a nominal block with no current issues, otherwise unknown, and install new rod and main bearings?.
