8
Everything posted by ShawnW
There's a paperclip symbol/button next to the Smiley face control.
Weber air cleaner alternative?
ShawnW replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Besides, how cold is it in May anyway? I think hes asking a valid question but until October or so you might not have any idea. I don't see how it would harm though. -
i i i c c cant drive 55 (in fourth)
ShawnW replied to kayoteq's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Lots of ways to narrow it down. You mentioned 4 speed and this is the 80's forum so I assume EA81 body car. I start with tires usually. Rotate front to rear. Old tires, or old steel "wagon" wheels both are known for being culprits in the vibration battle at times. The Alloy wheels can be a little hard for some shops to balance-the wagon wheels are often bent. I have seen people running the wrong lug nuts and such with strange vibrations. Driveshaft-mentioned-very common for a u joint to get dry on these. Check to see if they have grease zerks on them. If they do-grease and road test along with inspect them for play of course. If you have a spare driveshaft thats easy to swap out with 4 bolts. I assume you have tried going past 55 and taking it out of gear to see if it really does vibrate only at that exact speed. -
My new 1986 Subaru GL Hatchback
ShawnW replied to ibbki's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the old one is still under the car have it repaired. Radiator repair shops usually can do this for less than the cost of a tank either new or used plus shipping typically goes past repair cost. -
which engine for my brat ea81,weber,spfi,ej22??????
ShawnW replied to lostbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All 3 are good, its about budget, timeframe and how you want it to look. The 2.2 swap is more expensive than it looks and takes a lot longer than it seems. -
Brat thermo switch / cooling system question.
ShawnW replied to skapickle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also make sure the ground wire on the edge of the radiator support is screwed into the radiator itself too. These break very often on the 80-84 and I bet a 78 has them too. -
HELP ME!!!! Timing or something else
ShawnW replied to lilredjusty88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you meant to say its not 180 out. 360 out is "spot on". Essentially I think its 90 degrees off and the timing is all the way retarded or advanced to have it there and run the way you describe. You didn't remove the spark plug wires from the cap (incorrect firing order)? I would just start over. Pull the front passenger spark plug (1) and turn the engine over until you feel compression and the piston reaches TDC. Look at where the rotor is pointed and verify that its pointed at the #1 spark plug wires spot inside the cap. Then verify the firing order of 1,3,2,4 going around, and set the timing (pull vac line). -
You are right, it shouldn't go that high at all. Sounds like the fan isn't kicking on and staying on when it needs to. -
How to remove Rear Seat and Dash (EA81 Wagon)
ShawnW replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The fuel lines can be done with dash in. I would only remove the dash if its cracked or a DL type that you want to upgrade. -
Debating options after an overheat
ShawnW replied to man on the moon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could do an EA81 swap like McBrat just did on a wagon, only keep the SPFI. About the same cost but should be pretty solid. I have one here (ea81) that should be fine. -
Why are you looking at the main relay (orange/brown 2m) when the fuel pump relay is the silver one with the green plug in? In the hundreds of fuel related diagnostics I have done on Subaru vehicles-old, new, etc. Almost 0 failure rate of the actual relay unless its in a converted car (Ej22 swap, Vanagon conversion, etc). Almost 99 percent failure of the fuel pump itself. Maybe 1 percent is the fuel filter is completely clogged. Mostly old cars ---with a carburetor. If the pump is bad-replace the strainer on the pump (usually required to keep the warranty from the manufacturer) and the fuel filter.
Did you ask a parts store if they have the seal install kit as a loan a tool? I push them in by hand myself. Make sure there isn't a ton of corrosion that is holding you up. Maybe use the old seal and tap the new seal in with it as a cushion. Frankly, risk it...if you mess up the seal get another. Pretty cheap anyway.
I had a 2009 Wagon. I miss it a lot. I worked at the dealer when they came out and could have had an 08 for 6,000 less and opted for an 09. I would do the same today. There are a lot of interior and exterior revisions done. The auto climate control works better on 09. The seats have WRX stitched into them and red edging. Ground Effects kit added No factory mudflaps available on 09 but 08 uses standard Impreza ones. No loss to me but its a difference. The power is huge. Turbo is changed, maps changed. The mileage on the 08 is better. If you plan on making a lot of changes and mods to the car the 08 isn't a bad choice. If you want to keep it stock the 09 is much smarter. Its got a lot more to it, doesn't cost much more, and in stock form is pretty fun as is. I have an access port I used on mine if you buy one and want to grab a nice used AP PM me an offer on it. I flashed about 3 different times and reverted back to stock and unmarried it when I sold the car. I don't think the shortblock in either year is better. I would try to find one with record of having it replaced though, as the rod/main bearings were weak and after the change are usually sound again. I drove mine out to LA and I gotta say the most fun I ever had with the car was there. Getting onto the freeways there with the power at sea level was amazing fun.
Subaru Brat Hotwheel in the works?
ShawnW replied to Kostamojen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Moved thread to Old Gen. Almost put it in Historic. -
Metal Pieces in my Bell Housing
ShawnW replied to rdweninger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree with GLoyale, he's nailed it. -
Look pretty good to me. I think the Mattracks are going to be much more expensive and make the truck almost useless other than around the house/farm/property.
