Everything posted by NoahDL88
So, i'm not 100% sure where this should go, cause its an EJ motor, but an EA wagon, but i just put the MRT equal length header, sans cat on the wagon, with the mid pipe, which just so happens to aim right at my rear CV boot, but i'm working on that as we speak. Anyway, with no cats or mufflers, it sounds like teh SEKTS, absolutely gorgeous, it dosn't have the flat four burble, but man does she sound mean, so a few more days and i'll have the camber adjuster bolts, and she'll hold an alignment, and i'll be able to take her out and about. Sure, i'll get pics up eventually, my cameras borked, so it might be a while.
Brake Issue- PLEASE help me beat this!!!
NoahDL88 replied to RdNkBrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pull off your rear drums, and make sure that everything that should be tight is, and that nothing is leaking, and that they are adjusted, there should be a star wheel near the bottom between the shoes that you can turn one way or another and that will make the drum harder to turn, you don't want it to stop the drum from turning, but you want it tight enough that it is not super easy to turn. after that i'm cashed. -
Non turbo stuff should fit on any other non turbo, as long as its a 15 inch rim. The problems come when you have the turbo models, as they have bigger brakes and require the 16 inch wheels. With those, all will work, except from the STi models which have a slightly larger pattern. FYI, the std subaru wheel pattern, after the 4 lug era is 5x100
I believe some hankooks are made in Japan, but maybe i'm thinking of a different tire.
Front diff interchangeability: The true answer
NoahDL88 replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd say it would be rather helpful, as you're dealing with gear preload, it wouldn't be a bad thing to have a FSM handy. -
Doesn't help the rest of us out kthnksbye -
You're gonna need a home for all those plugs. And i believe the fuel pump is run differently with the MPFI than it is with the SPFI, in regards to the disty telling the pump to turn on in the SPFI.
New Grease For Old Bearings?
NoahDL88 replied to Milemaker13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can also get the 207S bearings, there sealed, so you never have to worry about it again, well at least a little while longer than the non sealed ones. -
I'm in, it'll give me a reason to get the upgraded tranny in the 88
Shoot, that'll buff right out.
You should really use the EA-81 flywheel, the EA-82 holes are bigger and allow for slop, which hasn't been a problem for most people who have done it, but its always nice to remove those untangible variables if you can.
Take the panties out of your butt crack and come back down from Mt Fuji. Its No big deal, don't take him personally. Anyway, manarious, you are wrong too, its also required in the USA to have the ability to have parking lights on with the key out. I wouldn't cut the wires though. This is supposed to be a helpful place, try to play nice.
The threaded and welded is the hardest, but it is the most secure. On mine, i have a set of two threaded rods welded together, theres just the right amount of offset for all the bolt holes to line up. would i do it again this way, not so much.
Yeah, sure whatever:rolleyes: Its been done a bunch of times, at least in motor swaps using the JDM EJ20 turbo motors and the DCCD transmission. I think the USDM would be harder, but they do have aftermarket controlers for the JDM stuff, so i don't see why it wouldn't be possible. Just don't know why you'd want to.
I tried it, you have to get the clutch and pressure plate right, cause if you don't you'll get massive slip. Didn't end up working, but thats cause i had a really custom motor that i couldn't get to work right.
