Now that the old wagon is a mini armored tank...
I'm going to go against the grain here..... get a toyota and join a yota forum GD
EA-82 IDLE Problems
CTS is the coolant temp sensor. It's on the front left of the thermostat housing. I remove the solenoid and soak the IAC in carb cleaner overnight - works very nicely and looks new again. Sounds like the TPS is the major problem though - the idle switch isn't reporting to the ECU that your throttle is closed. The
Oh Noooooo!
Sure sounds like HG's to me. They aren't that bad - I've done half a dozen of them now - takes about a day. GD
heater core ID!!!
That be an EA81 core fo-sho mate. No worky on the EA82. No rubbery bits on the EA82 core's - they have tubes snaking all the way to the firewall. The EA81 is done that way because there is a "control valve" that goes between the core and the supply tubes that can shut off the coolant flow to the core. The EA82 accomplishes the same thing by re-routing airflow instead thus allowing the core to remain in the coolant loop at all times. Also eliminates the valve which occasionally fails, and makes it much easier to bleed the air out of the core so they don't "gurggle" like the EA81 cores often due from trapped air. GD
EA-82 IDLE Problems
Verify the operation of the IAC, and CLEAN it so it moves smoothly. Your symptoms are totally classic for IAC failure. Also verify the operation of the CTS. Code 42 indicates the TPS is shot or out of adjustment - you need to either adjust the TPS so the idle switch is working, or get another one. Something is definately wrong with the idle switch in it tho. GD
No Accelleration Power + Engine Sputters in 2nd gear (auto)
It's quite possibly the control valve assembly in the tranny. Tune up the carb and see if it helps, and definately check the modulator. If neither helps, then the control valve assembly in the tranny needs to be serviced. This requires dropping the pan and removing the entire assembly - taking it all apart, etc. Best done by a transmission shop that knows about such things. They are not for beginners. GD
Proper RPM ranges
Yeah - that's normal. The 3AT's suck with a passion. GD
I plugged EGR on Carb model ...
You see what I mean now right?? GD
EA81 SPFI Conversion Manual ready for preview
Yeah - runs great. I just took a load of "loyale" to the scrap man. Along with the van, and my Brat I got $31.20 for almost the entire body of a 91 Loyale minus the doors and hood. I cut it into about 15 peices GD
The EGR system *should* be introducing inert exhaust on a properly tuned carb. There will of course be trace amounts of both even on a near perfect system, and even more on badly tuned engines. It doesn't really cause a "runability" problem when the engine vacuum is low (off-idle). The problem comes in when you open it at idle and it allows engine vacuum to by-pass the carb and not pull in any fuel and fresh air. This is why it gets "delayed ported" vacuum that is exposed to the intake just shortly after the port for the distributor advance. O2 is introduced (on the carb models) by the air suction valve system (passive "smog pump" basically) for the catalyst to perform at peak. That's a completely unrelated emmissions device. You are correct that it's for emmissions only, and does not harm the engine life, performance, or econemy when it's operating properly. By removing it you are simply adding to the pollution problem. But that's enough of a reason to keep it in my opinion. This is all academic though - not to mention it's been discussed to DEATH many times before on here. I was simply pointing out that BDG's methods and REASONS for removing it are unfounded, and simply absurd. GD
how to make a carb reliable and what kind of soob is this?
I agree - no problem with point/condensor other than the extra maintenance interval. Pretty good record. I've had floats stick (not fun), I've clogged the crap out of the primary and idle circuits to where I had to remove the top of the Weber and blow the passages out - that's happened several times. Better air filtration would probably have prevented that though. I was still able to fix it in the field - borrowed a can of carb cleaner and 20 minutes later it was all good again. Feedbacks are just nasty - don't ever get one. I had the oxygen sensor actually fail in my EA81 feedback hitachi and the engine just died at a stop light. I pulled the O2 plug and was able to drive it that way for a while. What a mess. But really, you can't say that you wouldn't have had the same good luck with FI - and generally speaking for "john public" the SPFI cars are the ones in the EA82 family generally considered the most "maintenance free", and "trouble free". Cars (and especially subarus) are designed to be as trouble free as possible, and that includes both carbs and FI systems. Just because it's got electronics doesn't make it more or less reliable than a system without. You still need good design principles. The carb has 100 years of this to draw on - they have come a long way to be sure. FI drew on all that experience, and brought new ideas and possibilities to the table. It definately is capable of better mileage at the same or better power than any carb ever devised. Even the feedback couldn't match the SPFI for economy or performance, and just look at the mess they created trying.... The SPFI has the performance of a Weber, more econemy than a feedback Hitachi, and is more simple and more reliable than either. Strickly speaking if you want total reliabilty - get a horse. This is an extreme example, and it's neither economical or performance minded (it also frequently sucks, and smells bad), but it illustrates my point. There's trade-offs to be made, and in the case of carbs the problem is that development has moved on. The difference in econemy and performance is small enough to be overlooked for now, but sadly I don't think that's going to be the case much longer. If the next few years brings even higher oil prices I think we are all going to be looking at either a Justy, or some form of fuel cell or something. The big win for FI for what I do is angle, and altitude compensation. There are of course carbs that could do both, but not that are easily and readily adapatable to the subaru. Plus for my daily the econemy and power is very handy. And I enjoy messing with things like MegaSquirt and such. Besides - who's going to help all those hapless SPFI owners if some of us don't learn how it works GD
I hate reman axles!!!
I knew autozone couldn't be right about them being discontinued . That just makes no sense - if they were going to do that for old cars they would have discontinued the EA81 axles I've been buying long ago. Well that does suck - maybe just get some boot's for now and a couple tubes of grease. Here - read my write up on axles. Give you a good idea of how to replace those boots. It's actually quite easy: http://home.comcast.net/~trilinear/axle_rebuilding.html BTW - what does it take to establish an account with them? GD
That's cool - but carbs are very simple. It would take only a few minutes and a couple diagrams to get the idea. It's just a venturi (speeds up the airflow) and a tube leading to a bucket of fuel. The engine vacuum and the low pressure caused by the venturi effect of speeding the air up "sucks" fuel into the air stream like you are sucking it out of a gas tank. The tube has a special sized hole in the bucket end called a "jet" and that limits how much fuel can be sucked thus "tuning" the carb is a matter of picking the right sized jet. Everything on the carb is about this principle. You have one jet for each barrel, and then you generelly have an "idle" jet that's only used for idling. The rest of the parts are largely ancillerary to the engine actually running - like FI there is a cold enrichment. The plates at the top of the carb block air flow - less air = more fuel sucked out of the "bucket". The accelerator pump smoothes out the transistion from one "bucket hose" (jet) to the next by squirting fuel anytime the throttle is depressed, and the float maintains the correct fuel level in the "bucket" (float chamber). You have a couple vacuum ports that run the EGR and the Distributor advance on the front. Really that about covers it for basic carb theory. Simple. It can be a real biotch to troubleshoot at times, but hey - that's what WE are here for right? GD
I understand, but the only "electronics" in the FI are the ECU, coil ignitor, and the optical pickup in the disty. All are extremely rugged, and personally I've only ever heard of the ignitors failing occasionally. They are small and you can easily carry a spare. Besides that, you HAVE an ignitor in your carb disty unless you are running points and condensor from an EA71 which I doubt. So really you aren't losing any reliability there. The disty's suffer from shaft bushing failure occasionally, but then so do the carb models, and it's less common on the SPFI as the disty has pin bearings on the shaft. The SPFI disty is also easily dissasembled and the bearings replaced - the carb model has the be pressed apart as the reluctor is press fit onto the shaft. The ECU is amazingly rugged - I've never heard of one failing. The one exception is they will be immediately destroyed if you hook up the battery in reverse. But you aren't going to do that now are you? And the point is that if any of these things fail you can carry spares and swap them out just as easily as a carb. Easier in fact in most cases. If the ignitor on your carb goes you have to replace the disty pickup - on the SPFI it's the coil bracket so a lot easier to swap out. If your disty shaft bushings fail swapping that is the same as the carb but easier since you don't have to mess with any vacuum pots. And if the ECU goes.... well that would be pretty obvious too for a lot of reasons. The O2 monitor lamp on the side of it probably wouldn't give you a model code - it would just act "dead". So what do you carry for spares in a carb model (fuel and ignition)? Here would be my list: Disty Coil Carb stuff (cleaner, adjustment tools, etc) SPFI: Disty Coil+Bracket ECU MAF TPS And of those I would expect to need only the ignitor, and *maybe* the TPS, but likely if the TPS developed a flat spot I would just drive it home anyway. But of course I like to be prepared, so I carry all the spares I could need - in case lightning strikes my ECU or something The reality is that the carb has more moving parts, and parts that move fail a lot more often than solid-state electronics. Plus learning how to check the codes for the FI is easy, and the ECU will TELL you what's wrong. How much easier can it be?? 10's of thousands of Loyale owners can't be *that* wrong. The first SPFI conversion setup I got came from a 90 Loyale with 248,000 miles on it. Car was wrecked and the engine was run without oil or coolant till it basically seized (radiator split, and the oil filter was gashed open - they rallied it around his property till it stopped running). The SPFI system ran fine from it once transplanted into my Brat - even abused with high mileage it started right up with just a few cranks. GD
That sucks - did they say when they might be able to help you? GD
No Start.....Ideas?
SPFI uses an optical distributor that only the ECU will understand. The ECU signal to the ignitor might drive the GM HEI unit, but I'm not sure.... The ignitors are tough - they rarely fail unless overheated. GD
Dual park brakes
Heh - yeah good luck ETC is usually a function of the ABS controller. In fact I don't know of any system that isn't a function of the ABS controller. Since the ABS has the ability to apply the brakes, it only made sense to add another chip for ETC. You need wheel speed sensors, and the biasing in the sofware.... you would have to customize it or you would have to find a vehicle with similar sized brakes, and with similar weight distribution. GD
and so it begins
Yeah - there's no rotor screw for the EA81 disty. Definately could be a vac leak or something. Those will make it real shaky like that. Spray around the bay with carb cleaner till you find the leak. GD
I used to think that . But there's definate advantages to FI, and just like a *simple* carb, you can also have simple injection. The SPFI is quite simple, and dead reliable - more reliable than any carb, near impossible to clog from random particulates (single high pressure injector with no air bleeds, jets, passages, seals, gaskets, etc, etc), and runs at ANY angle - even upside down if you wanted to install a dry sump. Plus the parts for it are extremely cheap (cheaper than a new Weber by at least 50%), and if you have a failure, each and every part is simple to replace and easily accessed. Additionally, the SPFI ECU is capable of running with only the MAF, TPS and CAS sensors (and the ECU itself of course). The rest can be non-operational but the system will run well enough to get you home. Plus it will tell you what's wrong with it. I can easily carry a MAF, TPS, Disty, and ECU in a small bag under the seat and replace them quicker than anyone could troubleshoot a carb. Just like a carb you still have to understand how it works, and how to fix it. If you don't understand a carb, it make little difference if it's "easy to repair" or not. Same with FI. Once you understand it, the advantages are clear, and no logical individual would say it's less dependable or harder to repair. Ignorant statements to be sure. You people can say what you want, but frankly it's all from FEAR. Those who proclaim from every rooftop that they HATE carbs, and those that do likewise with FI rarely have equal exprience or knowledge of both. Speaking from a perspective of having worked fairly extensively with BOTH (rebuilt, adapted, modified, COMPLETELY UNDERSTAND the theory behind, etc), I can say that I prefer a simple throttle body single injector setup (prefereable with MS) to any carb, and additionally I prefer a non-street legal simplified carb (such as the DGV) to an emissions modified unit like the Hitachi 2 barrel. I have no problems running or repairing any of them, but the carbs as a whole are DEFINATELY more work and head banging than a simple self-diagnostic FI system. Most of the old-timers that fear injection are afraid of one thing - "Computers". They don't understand them, and refuse to learn. Same with nascar - good-ol-boys that don't want to understand. Drink beer, and watch people go around an oval track in decades old technology - *hoping* for someone to crash into the stands for a little excitement. Only some of the early EA81's (never used on an EA71 as far as I know). I think 83 was the last year for the C/W. They have a feedback version of it to, which I've never actually seen. MOST ea81's were Hitachi's. 80-82 the C/W was more common, but you will rarely find it after that. GD
That makes very little sense. Their web site shows them in the catalog. I would call GCK and get the low-down on the situation: 310-532-9222 GD
Where can I buy a Hitachi distributor for a Brat?
You modified an EA82 carb disty for your EA81?!?! Cool - I just didn't expect you would actually DO it. I've done it with SPFI disty's and the process is the same, and theoretically it should work as stock. Glad you got it fixed anyway. GD
Dual park brakes
You could do it on the rear too with some nissan rear disc calipers. GD
not idiling right
Almost sounds like a dirty MAF but I thought we cleaned that. :-\ Might need to clean the IAC too or adjust it. GD
That old saying "a little knowledge is a dangerous thing" applies perfectly here. If you want to render a USEFUL opinion, you should go to college, complete at least an engineering degree, and learn about the fundamentals of research and data collection (such as what constitutes valid conclusions, what constitutes unsubstantiated assumptions that can't be backed up with hard data, what constitutes statistically significant data versus random variation or coincidence, what constitutes real hard data versus unverified "impressions", what constitutes research bias and how to avoid it, etc.). After completing such an education, you probably won't be thinking the same way anymore... but if you still want to maintain the same opinion, then at least you can do so intelligently and may seek some hard data to back up your point of view. Science, at its essence, is a set of rules designed to force us to reason logically, to remove or minimize personal bias, inaccurate assumptions, and all the other things that the average person usually does wrong when trying to think about a problem. *Most* people simply aren't logical or rational to the degree that science demands, unless trained extensively to think that way... so incorrect conclusions are commonplace, often based on little or no evidence other than what that person wants to think is important. You have fallen into this trap, and I personally am sick of it. GD
MAKE SURE it's not a feedback model. If it's got an ECU under the dash RUN, don't walk, to the next soob. I hate to be the voice of doom here, but.... The EA82 Hitachi's have some really bad problem areas. YES, they can be rebuilt, but the cost to do it right is *probably* going to be more than an SPFI swap. Here's the problems in the order of most to least severe: #1. The choke spring on the EA82 Hitachi is almost always broken or about to break at the hook that operates the choke plate. I've searched the land far and wide on the two occasions that I needed one and found one in good shape and another only partially worn through in about 30 carbed models at 3 different yards. They are a pain in the rear to find, and it takes 10-15 minutes to get the thing off to even see if it's broken. The number of dissapointing times I've had to knock out those stupid rivets only to find a broken spring is probably 10 hours of my life I'll never get back. #2. This is for all the Hitachi's - EA81 and EA82. The float's like to stick. The rebuild kits that are commonly availible are crap, and the needle valve's in the stick closed. Very hard to troubleshoot - I had one that would do it like once every couple months. Just when I thought it was fixed it would stick again. Very annoying. #3. The ones with high mileage suffer from primary throttle shaft wear. They will still run, but they often refuse to return to a decent idle speed. The wear is such that the plates will stick and not allow the shaft to return to it's correct idle spot. This tends to change with temp, so that they will stick either when warm or when cold, etc but not the opposite. It also creates a vacuum leak around the shaft and even with the plate fully closed the idle quality will be poor. This is not easy to correct, as it requires the shaft to be re-bushed, and isn't addressed by a rebuild kit. #4. The feedback models of the EA82 Hitachi are ghastly. Unlike the EA81 feedback (which is pretty simple) they attempted to improve upon it even more and in doing so added a manifold pressure sensor that ALWAYS fails, and costs over $300. Without it you get less than steller mileage, and a constant "ECS" lamp on the dash Personally, I would find a different soob, or find a Holley/Weber 5200 from a ford and rebuild that. At least that's a DFV Weber and should be easy and cheap to rebuild. But it probably wouldn't be a whole lot less than an SPFI swap unless you find one really cheap. I have a bunch of parts for those things - I somehow ended up with like three of them but they are not complete and there's some bits missing. You can have them for shipping if you can find one for parts on the cheap. I think one is a DFV, and the others are 5200's. As for "hating carbs", they can actually be VERY nice and simple. The Weber DGV, and the DFV are good examples. Carbs got a really bad wrap in the 80's when many companies started messing with basic carb design to try and make them meet increasingly difficult emmissions requirements. A BASIC carb is a really beutiful thing. The principle of operation is extremely simple. The Weber we all love is sadly illegal for street use. It's no a DOT approved device, and most of us are breaking the law to use it. This makes it a commodity of sorts because you can't pick them up off anything stock. You are FORCED to buy them from the aftermarket, and we have to compete with the jeep and VW community (etc) for the used ones. The 5200 is less known, but is a licensed copy of the DFV (mirror image of the DGV), and is DOT approved from the late 70's Ford Pinto days, etc. GD
