Everything posted by nipper
Radio Feedback with lights/brakes
nipper replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk then i vote for checking the Alt, laso how old are your iginiton wires?
nipper replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFactory or aftermarket radio
AWD Fears/Concerns
nipper replied to Tapil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook on the bright side, if he keeps doing clutch dumps, someone here can sell him a transmission (even new subaru manual transmissions do not like this). nipper
I joined the stuck caliper club
nipper replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes calipers are safe to buy from anywhere. nipper
Legacy w/ ABS brake fluid bleed
nipper replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClosest wheel first to the.... Hrmmmm Good question. Passenger side front is the closest wheel because it has the shortest brake lines. http://endwrench.com/images/pdfs/BrakeSystemWin01.pdf Surprisingly (learn something new every day) it is right Frt, Left Rr, Left Fr, Right Rr.
nipper replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust start at the closest wheel first. Go to www.endwrench.com for specifics. nipper
Engine cutting out - where would you look?
nipper replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAN analog multimeter can test the crank sensor. Its an ac signal it puts out, a simple hall effect sensor. ANother is the coils, or the ignitor. And igniotr can drive you batty. nipper
disabling the abs
nipper replied to beatupsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree. Maybe he screwed up the sensors. Usually ABS stops working, it doesnt become hypersensative UNLESS a tone ring is not truning with the axle. Maybe it is loose and free-wheeling. nipper
disabling the abs
nipper replied to beatupsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just put the car in neutral and it stops fine.
AC leaking oil, screeching drive belts...?
nipper replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds perfectly valid to me. Some compressors have a crankase that hold oil, some have oil in the refrigerant, some have both. No it wouldnt be leaking refrigerant, eventually it will seize up. You can just wait for that to happen if you dont beleive them, but then it would add the cost of a receiver/dryer and to flush out the AC system. nipper
nipper replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWater is a lubricant. If the noise disapears then you either have a loose belt or a bad belt. nipper
Check engine light-vacume
nipper replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet the code, otherwise our suggestions are just scattershot. nipper
My AWD Does Not Work, Sort Of
nipper replied to U R A BUS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm bowing out of this one. KNowing very well how the 4eat works and the AWD if you wish to chase things down knock yourself out. Goodluck.
nipper replied to U R A BUS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI doubt it, the two are not related. Logic tells me it is a hydraulic issue. When the fluid is cold, its thick. It can transmit more force and not leak as quickly thorugh seals. As it warms up it thins out and losses the ability to transmit force as well and can leak through seals. If the At Temp light is not flashing it is not electrical. Also could you please pick just one thread to walk off of, it gets confusing.
2002 Forester squirting tranny fluid
nipper replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXewwwwwwwwwww brand new with a blown seal? I wonder what it really was internally. Maybe a line pressure seal? nipper
1996 Outback brake probs
nipper replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBecause there are many different types of ABS systems out there, so many differnt procedures. Some cars have the abs built into the master cylinder, haninging off the master cylinder, a seperate pump, differnt feed back loops etc. Thats like asking why do all cars look different (or used to). You can vac bleed, but you dont have to.
nipper replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe level is supposed to be checkes with the car running and transmission hot after goingthorugh all the gears. Fluid squirting out is not normal. I wonder why the PO did that on your car with the vent tubes. The tranny is always tough to fill on a car, overfilling is not unusual. nipper
nipper replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn some cars yes, but most cars no. Subaru is not one of them, but you do have to bleed from the closest wheel first. nipper
How to test VSS Vehicle Speed Sensor
nipper replied to U R A BUS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX184K is high enough for it to be a tired clutch pack.
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX22 FR ABS sensor 23 FL ABS 26 RR ABS
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the car sat a lot, they dont usually get that rusty. May as well check all of them then.
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo. Physically inspect the sensors. They heed to be perfectly cylinder shapes. They tend to erode around the edges, then they dont have a good signal and will throw codes. Tonerings dont usually break (it happens) unless they are disturbed (or a big pothole). Even then it would only be one. nipper
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI love happy Endings.
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the codes.
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it is a black box under the sotrage pocket ot the center console. You had the entire dash apart? I bet you forgot something. It may be easier to just pull the codes. This should be basically the same as yours http://www.subaruoutback.org/forums/showthread.php?s=&threadid=21193 nipper
