25
Everything posted by nipper
Sounds perfectly valid to me. Some compressors have a crankase that hold oil, some have oil in the refrigerant, some have both. No it wouldnt be leaking refrigerant, eventually it will seize up. You can just wait for that to happen if you dont beleive them, but then it would add the cost of a receiver/dryer and to flush out the AC system. nipper
I doubt it, the two are not related. Logic tells me it is a hydraulic issue. When the fluid is cold, its thick. It can transmit more force and not leak as quickly thorugh seals. As it warms up it thins out and losses the ability to transmit force as well and can leak through seals. If the At Temp light is not flashing it is not electrical. Also could you please pick just one thread to walk off of, it gets confusing.
Because there are many different types of ABS systems out there, so many differnt procedures. Some cars have the abs built into the master cylinder, haninging off the master cylinder, a seperate pump, differnt feed back loops etc. Thats like asking why do all cars look different (or used to). You can vac bleed, but you dont have to.
airbag light
nipper replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
22 FR ABS sensor 23 FL ABS 26 RR ABS -
airbag light
Sounds like the car sat a lot, they dont usually get that rusty. May as well check all of them then. -
airbag light
No. Physically inspect the sensors. They heed to be perfectly cylinder shapes. They tend to erode around the edges, then they dont have a good signal and will throw codes. Tonerings dont usually break (it happens) unless they are disturbed (or a big pothole). Even then it would only be one. nipper -
airbag light
I love happy Endings. -
airbag light
Pull the codes. -
airbag light
I think it is a black box under the sotrage pocket ot the center console. You had the entire dash apart? I bet you forgot something. It may be easier to just pull the codes. This should be basically the same as yours http://www.subaruoutback.org/forums/showthread.php?s=&threadid=21193 nipper -
airbag light
Did you by chance unplug or disturb the G sensor? I thik it is in the console in the center of the car. (I may be wrong). nipper -
Power steering doesn't work
nipper replied to Dr. Fresh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the rack isnt binding or leaking, lets blame the pump. they are cheap enough, and they do go bad. You could drain the fluid through a coffee filter and look for metal. I have never heard of a rack loosing its boost and not having leaks or binding, but I have heard of pumps (age) giving up the ghost. Otherwise we have to get a pressure gauge and some hose and tee fittings. Since there are only 4 parts to this system (2 hoses rack and pump) I suggest the pump. nipper
