25
Everything posted by nipper
Check the engine RPM, the oil level (change it if it hasnt been changed in a while), Alt output before you start chainging parts. Next get a cheap mechainical oil pressure gauge for testing purposes. Make sure it can clearly read the lower range. After that we can start looking at more hideous things. How is the gas mileage?
Transmission is slipping, and there is no cheap fix for that. nipper
Well I am still going to try to fix my seat heaters, but with moms health crisses, my timing is way off. I dont have a garage And blu needs: Fix cancer Road trip (take mom to see her great grandchildren in South Dakota. Mom is 80 and never has seen her Great grandkids) Finish wiring the sports lights Seat heaters. I dont dare do anything to take blu apart untill Mom sees the Dr on the 8th, to make sure is all OK. So I have lost three weeks And winter is going to come hard and fast this year I think. nipper
Option C - they never noticed the torque bind. Well it is an 800.00-900.00 repair or there abouts to rebuild the AWD unit. You may also need a transmission mount (dont be surprised it is possible and reasonable given the cars age) I am assuimng you dont have an owners manual for the car. Look at www.cars101.com to get familiar with the maint for the car. I dont know where the FWD light is on an imp , but its there. nipper
Take a flashlight to the dash, up close. You should see a FWD indicator at the base of one of the gauges, where the other idiot lights are. You have it. Does your tranny oil light flash on startup? the fuse just completes a low power circuit to tell the Duty C solenoid to stay open and deactivate the RWD. I have a feeling someone did this trick long ago, and now the clutch pack itself has fused together. This solenoid is not meant to stay energized everytime you run the car. It can last this way a month or ten years, its just the luck of the draw. This is why the bulb is most likely missing. I dont like the tires not matching, but somone had the smarts to replace two tires and split them up one per axle to keep the revolutions per mile the same (as you saw). Tires can vary even within the same batch. I have a feeling someone had a flat and replaced two tires. The only thing worse then a high mileage car is a low mileage one. Cars are made to be driven, and they dont like sitting around. People think they are getting a great deal, but they usually have a lot of maint to catch up on. Normally if you had a good duty C i would say lets try one other thing, change the tranny fluid. Buy a case of fluid and do a drain-refill-drive around block-repeat thing 4 times. A failed Duty C solenoid code is never a flase positive. If the code says it failed, it failed. Unknown history i dont know what to tell you. usual solutions are replace the solenoid and cross your fingers, rebuild the AWD unit, or replace the transmission with a known good one. Can you find out how long the tranny has been binding, that would help alot. nipper
1st YOU test another 2010 and see if it is normal. It may feel like 2-3 seconds but i have a feeling it is not. Some new GMs' do this to save wear on the transmission, they have a slight delay before they start moving. Have you tried sport or manual mode to see if it does the same thing. And you need to find a better service department. nipper
There should be a FWD light that comes on on the dash. I have a suspicoun that this bulb is missing form the dash to hide the fact the car (at one time) had torque bind. Did the TB go away with the fuse in the holder, as this is important. Cheap way to check the tires. Park the car. With caulk or tape or something mark all tires where they meet the road with a line. With a freind watching, drive the car forward 5 full tire rotations straight. All the marks should end up back at the same place if the tires are the same size. nipper
replace the bushings first. that may be enough to make a huge differnce that you are looking for. nipper
