nipper
    25
Everything posted by nipper
  1. The 2nd cat rarely needs replacement, usually its the front one. nipper
  2. Pull up the floor, you will notice two metal plates on either side of the car behind the seat. Unbolt those plates and you will have access to the lines. nipper
  3. It depends upon the state they live in. Some states actually examin the exhaust system to make sure all the parts are there. Some people reinstall a federal exhaust system for inspection. in some states you can still use some more in$pired methods. On a modern engine its just dumb to remove the cats, as they do thier job very well, unlike the cats from the 70-80's. nipper
  4. There is much more to a spark plug wire then conducting spark. They have to contain 100,000 volts or more. They must be shielded from induced voltages from other wires (not a big issue on a sooby). They must deal with engine oil and under hood temps of 300 degrees or higher. They also must assist in keeping ingnition noise from showing up over the radio. Wires are made of silicon insulation. Poor quality silicon (read cheap wires) will quickly break down under the stress of high voltage and engine temps and allow for voltage leakage. Wire trees are used to keep wires from inducing spark in its neighboor wires. http://www.generalcable.com/NR/rdonlyres/F3629AA7-1B9E-40E6-A74B-4D3949CD1B9B/0/AUT_0060_1002.pdf Skip the part where they are saying thier product is the best but thier points are valid in wire construction.
  5. Tektronics is one of the best names out there, they will have a manual for it. nipper
  6. I swear driving in SF is like 4wheeling only the trails are paved. Last time i was there i stopped at a 4 way stop, i was pointed up. The angle was so steep i couldnt see the cross traffic at all, so after a 2 count I just went. And I thought NYC grid was crazy at time, i imagine if these same people built a city in the Andes there would be a grid along the sides of Mt Everest. nipper
  7. Didnt say there was any mud in the car, just that mud is very abresive, like a very fine wet sanndpper which can damage sensors. You say you replaced 2 due to wiring issues, but you really need to look at the faces and make sure they are cylindrical in shape with nice sharp clean corners, otherwise the puter doesnt get a clean squarewave signal. nipper
  8. When the car is cold, bang the cataytic converter with your hand. If it rattles your converter is shot. Otherwise get under the car and shake all the heat shields. I am sure you have one or more that is loose. Thats what makes a subaru a subaru nipper
  9. Two questions. Are all the tone rings in one peice. Secondly are all the sensors a perfect cylindrical shape at thier faces? They can not have any erosion otherwise they get confused and can throw a light or activate the ABS. nipper
  10. Well the true test for torquebind (as hard steering can be either) is that the car should be able to move in a tight circle at idle or with very little throttle. If it can, its the PS pump. Another thing to try is (again in a parking lot) Remove the PS pump and see if the issue goes away. A binding rack will still bind, but a bad PS pump the problem will go away (but be hard to turn the wheel). nipper
  11. Can just be the rack is shut. Explain to us un greater detail waht you mean by binding. nipper
  12. Last i checked subarus do not have inertia switches. Maybe just a fluke? Maybe you have a loose alt connection? dont know. nipper
  13. The really arent that hard to use. It's easier to show you unfortunitly then tell you since there are some variations between models as to actual controls. Did it come with wires? What make and model is it.
  14. http://www.cars101.com/subaru/outback/outback2010.html Much better pics, and i think maybe I could like this car nipper
  15. Plug #3 is still a pg-13 (as opposed to X ) rated plug, but all the other ones are simple. The engine drops below the frame rails with the lift kit. nipper
  16. heheh Gross, i found one HUGE plus to the liftkit, sparkplugs are EASY! nipper
  17. Use lock-ease, as it is made especially for locks, including ignition locks. nipper
  18. Take it to a shop, as you dont have any idea what you are doing. 1- Car needs to be running 2- The cycling will decrease as the pressure increases 3- you NEED REAL GAUGES, as we need to see both low and high side pressures. DO NOT USE REGULAR GAUGES. 4- AC if you dont have a clue can seriously hurt you. The only other systems under the car that are just as dangerous is a hot raditaot or accidently shorting out a battery. Everything else can just mame you.
  19. any idea what year the engine is? nipper
  20. Those gauges on those cans are pure junk and shouldnt even be sold with them (for all the good they do). You need a real set of gauges and a thermometer to tell us how cold it is blowing, along with letting us know ambiant air temp. All those things factor into what the answer would be. nipper
  21. Gte the kit from subaru. The valve cover gaskets from Felpro are fine, but your also going to replace the spark plug bucket gromits at the same time (thats not an option here, you will do it ), and aftermarket for those have been lousy, they do not last. You can easily do it in your driveway. Thaink about chaning the plug wires and plugs as long as you are there too. Make sure no one under 16 is within earshot. nipper
  22. I had a key made last year, I just showed them the reggy to the car (for the vin number) and they made the key. I dont know if they would do it if you just walked in with a scrap of paper or the vin memorized nipper
