Everything posted by nipper
HELP/cooling issue, weird, 99 OB, 2.5, Water Pump?/Head Gasket?
nipper replied to Mikldom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXactually it sounds good. If the liners shifted she wouldnt have been able to drive it 50 miles. You should be repaired then good for 200,000 miles. nipper
nipper replied to Mikldom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you should be set with a new timing belt water pump cam and main seal, reseal the oil pump. Wires are up to you. The determening factor on weather the engine is good or not is if it was driven with the temp gauge pegged. If it was, this is what is called cooking the engine. The block gets so hot that the cylinder liners shift or come loose. At this point the engine is scrap. You should also have an oil change, as the oil does get stressed when the engine overheats or runs hot. Its just extra insurance. Try contacting subaru directly and see what they say, they may make a deal. nipper
voltage question
nipper replied to rpl3000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX:eek: do you feel it go into gear, see the engine RPM drop, or does it feel like its in neutral? Did you try all the gears? nipper
What would it take?
And a tailwind. nipper
Another 1986 GL Sedan question-door locks
You know hes just going to lock himself out now nipper
Here is my definition of TOAST
nipper replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnderhood fires i can rationalize. Fires from the rear (gas tank ) are distrubing. nipper
Couple of issues.....Please help out.
nipper replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually its a very simple fix (for a shop), and thats an excellent price. It will get worse and cause more damage with time (sooner then later). nipper
nipper replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell that can be causing everything your feeling. Also the binding can do damage to the carrier bearing, the universal joints, the tires, and make the car handle oddly in the wet. nipper
nipper replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike skip says, broken belts and bent rims are really easy to see. Another way is to slowly drive away from a freind in forward and reverse while he watches each end of the car. He may see a wobble. Better question, hit any huge potholes or curbs lately? nipper
nipper replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk first thing first, it is CRITICAL that all the tires match and are worn equally. You may have torque bind, which your just not describing properly. Torque bind can destroy your AWD unit. Is this a manual or an automatic. Make sure all the tires match and are inflated properly. Go out to a parking lot. Make a tight circle, and see if the car will do it under its own power smoothly, with no or very little gas DO this first, so we can rule it out. If this is an automatic put a fuse in the FWD holder under the right side of the hood, near the firewall. See if the issue goes away. We can help diagnose after we rule this out. nipper
nipper replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnotice how its fire engine red, or is that burnt red nipper
voltage question
nipper replied to rpl3000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats optimistic. I had one last three months, another last 2 before i said the hell with it and got one from subaru. nipper
nipper replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhowdy i had the same thing happen to me. A very slight vibration before a mechanic changed an axle, then a heavy vibration afterwards which they didnt even nostice grrrrr it will get worse with time if its a wheel bearing. get it checked out. nipper
towing
Well there are a lot less people there to hit, and that entire upside down thing makes the trailers lighter :-p nipper
Rear wheel Bearings..
I have noticed Blu is getting louder in the rear. At 210,000 miles he is allowed. I am pretty sure its not the rear diff, so I think in the spring I will get Blu new rear wheel bearings. Looking at the FSM, it looks doable in the driveway, if i can snag the tool. AM i underestimating this, or should i let a machine shop deal with the bearing part of it. nipper (and yes im bored so i am thinking about spring work)
voltage question
nipper replied to rpl3000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2500 RPM is the check point for all altenators (that I know of). nipper
nipper replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi wouldnt touch anything infront of the driveshaft you think a headgasket is bad? this is a little worse hehehehe im sure there is a lightbulb someplace that may be good To paraphrase smokey the bear (hey no groaning till i say it) "Only you can prevenet Forester fires" ok groan nipper
Low Fuel Light Doesn't Work?? 98 Obw
nipper replied to blaze's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, if you watch the bulb, it doesnt turn on. it glows slowly. nipper
2003 Outback H6 Timing Chain Tensioners Question
nipper replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo step one, remove radiator? good news about something like this the avg owner only needs to do it once, maybe twice. nipper
nipper replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell we need to get people to drive the hell out fo them some more. i would get one on the next sooby if i can be convinced it will go way over 200K . Of course if i start buying parts now ... hrmmmm i wonder if the timing on the chains is easier to set then the belt. Otherwise it looks like a straight forward can be done all day in the driveway kind of thing. just dont loose any bolts. Imagine if they are all differnt sizes? Personally i would chaneg a chain anyday over a belt, but thats just me. At least they didnt bury it in th the back of the engine. nipper
Puff of smoke question
nipper replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee subarus are almost human. Us humans carry over some parts from way back when, so do subarus nipper
voltage question
nipper replied to rpl3000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need an altenator. Yes low voltage is like running out of gas, car wont go and will do odd things. Also check your battery, as it may be due too. look at 1st subaru or another one of the online dealers. You may be able to get a good deal. I find buying them from subaru better, as there is some real crap out there, and they sometimes sell imprezza alt's for outbakcs. They look the same, they are way more money, but have lower output. nipper
nipper replied to suban00b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes the wheel bearings dont surive a axle change, depending upon how you got the axle out of its happy home in the hub. Also check to make sure the lug nuts are tight, as well as the axle nut. Compare left side to right and make sure one sides match the untouched side. Next is rotate the tires on one side of the car and see if it moves. nipper
electrical hemorhoids
nipper replied to RU OK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know if this year has one, but by any chance while you were fiddling did you smell a little smoke? Its possible, if you have one, that you burned out the illumiination controler. Fuel gauge, check it at the tank, i bet its dead. Very rare the gauge itself goes bad, if never. nipper
nipper replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHEY bacak away from that wreck, let some of us who want to do a retrofit get a chance. Looking at the drawings on 1stsubaru alot of those guides are friction guides, so they take a beating. The idlers may not be bad, as they are in a lubricated area. nipper
