Everything posted by nipper
Legacy tranny - How many miles B4 failure?
nipper replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn this entire list I remember maybe 6 trannies being replaced, two of which didnt need it, as it was just TB and not a tranny failure. nipper
$315 CV Boot Cover Replacement for Legacy???
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIve never used one on an inner. Ive used them on outers and had it fail. Maybe on an inner it will work better. nipper
Failed Inspection Help
nipper replied to RedRum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have an exhaust leak and a dead cat, nothing will help you pass. My feeling is at that mileage they are probably two in the same. Look at the exhaust system yourself. A leaking exhaust us dangerous, espeically if it fairly forward in ther car. Hit the cat with hour hand when the cat is cold. If it rattles, the cat is scrap. nipper
nipper replied to daehttub2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um ... Just replace the axle, it should be cheaper. I had the dealer replace an inner boot on Blu ( just torn, car was there for the awd clutchpack). It cost me about 220.00 to have it done. I need the other now, I am replacing the axle, its cheaper. nipper
Synthetic or Regular Flush or Drain and Fill?
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou cant tell the condition of a timing belt by just looking at it. It may look brand new but be at the end of its life. Its ina happy safe place so it doesnt get dirty. Seals are: Cam Crank Oil Pump Also you change the tensioner and idlers at the same time. Do this once and your good for 106,000 trouble free miles, skimpo and you can end up with a very expensive engine repair. Dino = Dead dinosaurs (oil) Transmission fluid can just be any name brand. nipper
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX200,000 KM is that like 120,000 miles or there abouts? When was the last time the timing belt was changed? Personally, if it was my car, i would stick with dino and flush the tranny. If a timing belt hasnt been done, I would do it, change the seals, then switch to synthetic. My logic is, I hate oil dripping on the exhaust of a subaru. Synthetic is awfully expensive to leak. Others will disagree with me i am sure. The tranny should be flushed really once every 30,000 miles. You can do it yourself at home with a set of ramps. The AWD will love you for giving it a flush. I am going to switch to synthetic soon, but my new engine has 10,000 miles on it, so I am not worried about my seals. nipper PS - Having synthetic is not an excuse to not open the hood and check the level at least once a month (though it should be once a week). Subarus may use 1 qt every dino oil change cycle and be considered normal. that can translate to two qts every synthetic change.
nipper replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX205,000 miles on the original tranny. 185,000 miles the clutch pack was replaced. New computer controlled trannies (on almost all cars) now last the life of the car if they are built right and properly maintained. nipper
fuel pump noise
nipper replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a noisey fuel pump once. It never affected the car. You may want to throw a fuel pressure gauge on the car just to check the pump. Are you sure your not hearing air bubbles in the heater core? How does one hear air bubbles in a fuel system? nipper
nipper replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnswer me this first, when was the last time your cam and main selas were done? Do you have any reason to suspect they are weeping. I ask this because synthetic oil does not cause leaks, but it will make a seal thats leaking leak more. If you Feel your seals are good, go ahead and change. There are a few ways to do the tranny. 1- For the next three oil changes (dino) do a drain and fill of the tranny. 2- Do a drain and fill three times (drain fill drive around block repeat). 3- Do a complete flush. A simple drain and fill is basically useless as it only gets about 1/3 the fluid out. nipper
Another Ticking Question
nipper replied to Equalizer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on this? 2 qts in 500 miles, if your burning it thats a ton of smoke out the back of the exhaust. If your leaking it, why werent the seals replaced with the timing belt. Also if the oil pump wasnt resealed, you can be loosing pressure. You need to do a compression check and have somone who knows how to read a vacume gauge throw it on and see what it says. When was the last time the pcv valve was replaced? nipper
Rumbling rear on 97 Legacy
nipper replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan be as simple as a cupped tire, can be a bad strut, or as major as a rear wheel bearing. First thing to do is to rotate the tires and see what happens. nipper
Engine misfires going from high rpm to idle
nipper replied to halyva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOE plug wires
Help troubleshooting cltuch
nipper replied to Leg93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is nothing to it or the slave cylinder. Its still a peice of cast metal with a steel piston and some rubber parts. Just goog;r whoever you buy from to make sure its OK. nipper
nipper replied to halyva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel filter too
nipper replied to Leg93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually i replace both the master and the slave at the same time, since they both operate the same. If your shifting fine, no slipping no odd noises then usually its the Hyd clutch parts. Remember the Hyd clutch sees up to ten times more work the hyd brakes do. nipper
nipper replied to halyva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlmost sounds like a fuel injector issue. When was the last time this thing had a tuneup? ALso have the codes pulled. nipper
nipper replied to Leg93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust use the hose Luke, use the hose..... It is on the transmission near the top of the bell housing about 2 oclock. nipper
nipper replied to Leg93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk then im going for a bad slave (which is affected by heat) or master cylinder. nipper
Break the timing belt covers?
Ask yourself how much deep snow do you drive through. The covers keep the belts from jumping off. It protects them from getting packed with snow. If it was florida i would say go ahead. nipper
1990 Legacy Transaxle
nipper replied to jowens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIm confused. First off what is shift lock. Secondly how many miles. I hate to say it but those two questions may be moot as you need a tranny. The clutches are slipping. That band adsjustment is for 2nd gear and pretty much really is useless for an after the fatc thing. Once an auro starts slipping the damage is done. nipper
nipper replied to halyva's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles ? nipper
misfire po303, tried the usuals.. now what.
nipper replied to bustedbolt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmystery drive vibration? Have you checked the fuel injector? nipper
The muffler question
nipper replied to madkow007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI always do them myself, and i get Walker parts. Go the neighboorhood autoparts store, you may be pleasantly surprised on price. Don't listen to fnlyfnd, as he speaks blasphamy (heheheh). nipper
Road trip reading, radio, waterpump? others?
Quick way to find out, remove the drive belts and see if it goes away. Usually its the ALT or ac compressore clutch that makes noise. Can also be the drive belt tensioner (i dont remember if this has one or not) nipper
nipper replied to Leg93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a hydraulic clutch, so nothing to adjust (technically). I wonder if something happened to your clutch fork. The springy part has me curious. I would check the clutch fluid and see if its all there, and what condition its in. Since it is there all the time, i dont think its a failing slave cylinder, but i wouldnt rule it out. The Throw Out Bearing is held on by two clips, I wonder if you lost one of those. Is that hiccup a hiccup or a clutch slip? nipper
