25
Everything posted by nipper
Mine got soaked with oil when the engine blew. But in retrospect, it was giving out signs it was going. My aftermarket self diming mirror was flaking out. I couldnt figure out why. Once the alt was replaced it stoped doing it. At the dealer they said there was a lot of noise in the altenator (which they said drive it and the oil will burn off). That noise was the brushes being shot. So i am convinced it was just time at 198,000 miles. Thats a respectable number nipper
I'm home...
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
ooooooooo .. but i did notice the car felt more twitchuer , that explains it ... nipper -
I'm home...
technically one engine (HUGE hole in the side of the crancase where the engine temp sensor for the ecu is) and one altenator (explains why my little black boxes were angry at me) But even after payinhg a premium for the engine, it uses zero oil in 300 miles, no leaks, plenty of power, cruise control is much happier, transmission doesnt hunt anymore, and six 1000.00 payments is far cheaper then 300 a month for 60 months (or whatever 30,000.00 over 5 years is). I basically told them if i am going to do an engine, i don't want to open that hood for anything besides fluid changes for 8 years, make it happen. I had an 06 Outback for nine days. I liked mu 1997 better. It seemed more responsive (dual cams) and there was not a single thing in the new car that made it better then mine. In fact the awd seemed very FWD biased. When i took it mountain climbing the front wheels would throw rocks before the rear wheels hooked up with a learch. My 1997 (new AWD unit) feels seemless. ALso the inside of my 1997 feels bigger then the 2006. Gas mileage was the same. The 2006 had a really high and hard brake pedal. I will say that the cruise control is still to aggressive, and downshifts too far when a squeeze of the gas would suffice. Thats actually when my engine blew, the cruise decided to stomp on the gas, shifted down too far and BOOM. That and the previous owners habit of chainging the oil once a year weather it needed it or not didnt help. nipper -
The rule of compression tests is not so much the actual nymbers, but the difference between the cylinders. 200 lbs is high. A compression test needs to be done with all the plugs out at once and both wet and dry, with the throttle wide open. Actually better off with a clean engine, since you can see all the leaks, a dirty one can hide them. nipper
Er....... um .... boy i dont pay attention to this board for a day and someone gets into all sorts of mischief. I think this is the first i've seen somone pull a slushbox apart. i hope your keeping really really good track of things. An autobox is not for the timid to pull apart. There are rebuild kits that you can get, but usually one tries to secure the kit first when doing it themselves. There were a few steps that were skipped here, like a proer diagnostics. If we could time the delay, we could have gotten a better idea where the problems was, along with a few other diagnostic steps. The pump has to be measured with a feeler gauge for wear, and i dont know what the specs are. You really cant always tell things by looking at them, you need more diagnostics to know where to look. Its possible that you may still have the problem or worse, since this seems a little extreeme, nipper
I'm home...
but the headgaskets were still good .... nipper -
I'm home...
5 weeks 9,000 miles isnt enough? nipper -
Well Blue and I are home. New engine hasnt used a drop of oil in 3000 miles. Blu will get an oil change this week. Now one more problem, im just too tired to fiddle with it, but i think i need a battery, the one in the car is of undetermined age. 1997 OBW 198000/3000 miles The car fires right up, but the battery voltage is low (11.8) right after start, and doesnt build back up for a block or two (which really angers the black boxes in the car). When the car runs, the new alt puts out 13.5-14 volts, even with a full load. Since the car was run down to nothing once on the trip, and the battery was showing signs of wear, I am guessing its time for a new battery. I was thinking there may be a slow draw on the battery overnight, but the car cranks too well in the morning, so i dont think thats it. Oddly i noticed if the ABS light and brake light comes on, it means a bad alt, if the battery light and brake light comes on, its a low battery. Go Figure. nipper
Cruise control
nipper replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
its not a simple system, but it is very robust. It can be a failed relay, bad brake and or clutch switch bad speed control unit. nipper
