Everything posted by nipper
attempting a head gasket job
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Want Legacy Headlight washers
nipper replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSTOP TEMPTING me you heathen nipper- '03 Legacy GT sedan using coolant??
nipper replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave the dealer put in the conditioner, its never too late. Also if it is really tough to find, you may have to let a shop look for it. They can put a dye in the coolant and use a black light to try to find the leak. nipper- Grill/brush guards?
nipper replied to gringorio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXME TOO ME TOO! nipper- Very Stiff Shifter Auto Forester
nipper replied to forester01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmiles people how many miles? Describer hard shift. Does it shift easier with car off, the clutch in, and just running it through the gears? nipper- Engine trouble
nipper replied to outbacklover97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on the car. When the car has an issue directly correlated with a repeated parimeter, look at the sensors. I would suspect the engine temp sensor for the ECU (not the one for the temperiture gauge). Before digging too deep you may want to get the codes scanned to see if you have any. Also if you can rent a scanner, it will tell you the engine temp on the fly. If the sensor has an open, it should show you an open or no temperiture reading when the car stalls. My next two choices would be the few sensors that can make the car die. That would be the cam and crank senors, and i would look at the ignitor. When the car dies, do you have spark? Can you hear the fuel injectors clicking (or using a test light see if they get a signal). nipper- "Brake" light on
nipper replied to Tbird Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually the AWD computer will notice the drastic differnce in speed between the front and rear of the car after 50mph and stop trying to correct for it. Also popping an axle will put no load on the AWD clutch pack, so it wont do any harm. Now if you had too small a tire on that wheel causing drag on the clutch pack, thats a differnt story. The AWD uses speed sensors, one in the tranny, one in the spedometer (if you have a spedo cable), or the vss sensor for the spedo. There are also 4 speed sensors one at each wheel for the ABS. I dont know if the bulb will go out if you yank the fuse for the abs but it is worth a shot. nipper- attempting a head gasket job
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe said its a 98 as i got corrected once on the lifters .. grrr nipper- Need to Test Fuel Pump
nipper replied to LanceGillette's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpark continously? or spark at the apropriate time? Can you hear the fuel injectors operating when the car dies? nipper- Simple Help Q
nipper replied to suby do's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXditto, and cam/main seals. nipper- Wierd clutch problem-91 Legacy
nipper replied to gbrand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is nothing wrong with the hill holder. Weither you have a bad clutch fork, or a throw out bearing problem. COUld be the throw out bearing is cocking and getting stuck. nipper- intermitten overheating with Subaru Forester
nipper replied to lsapp@hotmail.com's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSInce it is happening regularly check the cooling system for bubbles or the presence of exhaust gasses. I think you have a blown HG myself, but removing the cap (when cold) and starting the car, watching for bubles, it should be real obvious. nipper- Need to Test Fuel Pump
nipper replied to LanceGillette's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ignitor when it goes bad can either totally cut out, not start at all, or act like the car is running out of gas. Check for spark the next time the car dies. It may be the ignitor, i doubt its the fuel pump. A fuel pump the car either would not start, or hesitate badly under full throttle or at high speeds. The fuel systems on these cars are fairly robust. They are electric motors with no parts to wear, and motors usually work or they dont. Check the fuel pump relay to make sure it is working right. nipper- spongy brakes 98 Legacy Postal
nipper replied to swi66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFinal drive is an old expression. It can mean high gear (if the seller is over 70), transfer sace, or differnential. In any case it means it needs a tranny. nipper- Persistent squeaking, caliper problem?
nipper replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you lubircate the sliders? Also did you use the little metal shims that go behind the brake pads? nipper- squealing noise.
nipper replied to hikerwa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou should see all the engineering that goes into a drive belt, its scary. Its hard to put a "tread" on a serpitine belt, as both sides of the belt is used. It would be like putting treads on the inside of the tire too. on a V belt all the work is done on the angular side of the belts, and not the flat part. The "treads" in a belt are made to be compresed, not elongated. they would elongate as they went over a reverse pully. nipper- Hazard Flashers Won't Shut Off!!
nipper replied to nu2subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehehe gets them all the time nipper- Intermittent headlights: 02' Legacy GT
nipper replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like you have a loose/dirty connection someplace. Start by checking the fuses and the relays. nipper- Repair Assistance
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBegin by getting the valve cover gasket kit, then remove the spark plug wires, onbolt the valve cover gasket. Do NOT pry the cover off, rap it with a rubber mallot if it wont budge. Make sure all the old gasket is removed. Do not use selant. make sure the valve cover is not warped. remove old o rings. again make sure all surfaces are clean. tighten the bolts in a X pattern, do NOT over tighten as it will leak. Anyone know a torque spec for these bolts that can be put in english (like 1/2 turn past finger tight). I am guessing you dont have a torque wrench. That should be it. nipper- Wind Noise--luggage rack?
nipper replied to Eric Barr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cross peices tell you what direction they go in. nipper- Ignition coil signal...for the smarties
nipper replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt off by a tooth, the car will not start. Why are you so sure it is not the coil pack. I would look at the ignitor (which actually fires the coil) first, then check the cam and crank position sensor. i am not sure, but it should be running off the cam sensor. nipper- spongy brakes 98 Legacy Postal
nipper replied to swi66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaster cylinders leak internally too. First test with the car off pump the brake 10 times. put your foot on the brake pedal. If the pedal goes to the floor, the power booster is fine, and you need a master cylinder. If it doesnt go to the floor you need a booster (and maybe a master cylinder as they both act the same). My gut tells me you need a master cylinder, and probably should have replaced all the brake lines too. nipper- Wind Noise--luggage rack?
nipper replied to Eric Barr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy97 OBW does this, i turn up the stereo. Look to see if the cross beams are installed backwards. They are directional and can make wind noise. Also they do come off it reall does drive you nuts. nipper- Grinding sensation when taking off
nipper replied to shmerham's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the obvious. inspect the cable and its clamps. DO you feel the vibration in the pedal itself, or on the floor at the pedal? nipper- Hazard Flashers Won't Shut Off!!
nipper replied to nu2subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe switch is broken. Where is the switch located (i dont remeber). i would pull the switch and disconnect it, then put the flasher back in and you should have turn signals again nipper - Want Legacy Headlight washers
