25
Everything posted by nipper
This is my only pet peeve i have had, i think subaru seat belts hate me. The drivers side seat belt does not fully retract, i have a 97OBW, but my legacy, even my 88 and 84 Gl did it. This is annoying, especially when its rainng and you get a nice wet seatbelt in your lap. ( i only wegh 200 lbs and built like a linebacker so lets not blame over extension ) How do i fix this before i dig into the car. nipper
its easy. first off is the car tracking strraight, or is it fightiing against ruts and seems in the road. thats the first flag that something is up. Make sure the lug nuts are tight. Jack up the wheel of the car (pick one) remove the wheel cover. You may need a freind to help. grab the tire at 3-9 postion and shake it. listen and feel to see if there is any play at the center of the wheel (bearing). Next do this and look at the tie rod end, there is to be zero play. Next take a 2x4 or pipe and pry the tire up and down. Again there should be zero play Also during this tim look at the lower control arm bushing, it should not be moving aside from up and down. Look at the sway bar bushings. If you have done all this and still feel something loose, i would suspect the wheel bearing (its hard sometimes to diagnise if you never done it before, and its just starting to go). Repeat on the other side. Also while the tier is up in the air, spin it. Make sure it is round and true, look for dimples in the sidewalls. nipper
You ned to take it to a tranny shop, a dealer will want your first born male child and child to be named later. The shift linkage has a single shift rod that not only selects 1-2 but also moves it to 3-4 and 5-r. Other shifters use two rods, one for the front back motion and on to move from 1-2 to 3-4 5-r. It looks like the 1-2 3-4 5-r shift forks are internal to the transmission. The onl thing i can relate this to is olf rwd VW. They used one rod. The rod would select the forks to move, with the movement of the lever. The forks on the VW had two notches on them , where a sping loaded check ball lock the fork in place untill moved. When this fork wore out, the car would pop out of gear. My feeling is that what ever method is used to select which fork to choose is worn. Its been ages since ive worked on a manual tranny on a car, but if i recal this does not require a rebuild. The forks can (used to be) servicable. i dont know about subarus. The good news is the shifter doesnt seem to be part of the tranny. If it was, then game over. nipper PS i need a voilunteer proof reader untill i get my back surgery, damn the first draft of this looked bad.. but the pain meds are fun:drunk:
OK its a stick. For some reason the shift forks inside the transmission are engagin two sets of gear at the same time. This is the only way you can lock up the transmission. I woudl have somone inspect the shifter and linkage, and motor mounts. its possible that there is sometrhing wrong with all three that you are just barly grabing the two sets of gears, then the physical movement of geting the car on the tow, getting it off, is disengagin what ever two sets of gears (1-2, 3-4 or 1-2 and 2-r, not sure about 5) This is going to be a tough one to diagnose, since even the act of jacking the car up may be enough to unstick the transmission. It is poossible its a bad shift fork. Have you noticed and slack in the shifter? nipper
have your parking brake inspected to make sure it works. Porper way to park a car (which no one does including me unelss ...) on a hill. Stop the car with the brake pedal (hey on im back drugs so stop giggling), apply the paking brake fully, THEN put the car in park. a manual same thing but put the car in reverse. If you are on a steep enough hill, the load on the parking pawl (its just a rod in the tranny) will be so great that you cant move the selector out of park. nipper
