25
Everything posted by nipper
If your doing all this work, i would suggest just getting a new pump. I would change mine with every other timing belt change.
help leaking coolant under the thermostat housing.
nipper replied to egladman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what did you cut off? a hose? nipper -
ALlow me to introduce you to the search button .... do it on airfilters. I just did this yesterday and posted it in a long thread, and sorry folks not up to it again. My pain pills for my back are giving me a nice ride. Detailed test on GM duramx Deisel and aftermarket filters. Guess who came out on top...the OE airfilter. any filter that has better air flow has to have larger poors, and let more air in, hence more dirt. The pistons can handle it, but the fuel injectors cant, nor can any sensors down stream from the airfilter. nipper
Zero bounce is bad. You should get one to one and one half bounces. Knoking sounds i the universal joint in the sterring shaft, you need to have that looked at too, sometimes its normal, may be a sigh of it seizing. My money is on the struts. Did you check the front end with it jacked up off the ground?nipper
SOmetimes the engine cant be warm. Procedure is to remove all the plugs, and have a wide open trhottle. Crank the engine 7 times and repeat. Once you have done this, you squirt some oil in the cylider and do it alll aover again and record those numbers.If there is a increase in pressure, you have a weak rings, no change you a vavle or valve timing issue. nipper
no start
nipper replied to waltee_d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
what are ALL the codes you initally saw, What codes are you seeing now. Multiple codes are a chain reaction, and doe not mean every sensor is shot, just means they are not going into close loop when they should. nipper -
87 under powered, headgasket?
nipper replied to Joey Joe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like a head gasket and maybe a timing belt. I agree head gasket does not make a sooby loose power, but overheating it sure will. Engine may be tired. nipper -
Basic road trip Subaru toolkit
nipper replied to fj401968's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my AAA gold card :)nipper -
Actually the manual says 100K on the timing belt for a 2.5. I dont know if this applies across the board, but it seems the computer compares the cam and crank postion sensors and if they get out of synch wil make the check engine llight blink. Never ignore a blinking CEL. Thats what i was told on my 98 wuth the 2.2L . I thought that was a great idea. It may still be there in the newer ones, but now 60K is early for a Timing belt unless they have other business down there. http://www.cars101.com/subaru/subaru_maintenance.html#2000Maintenance nipper
Its across the board. Again it goes back to people wanting more junk on thier cars, they get heavier, lower milage. More electronics more things go wrong. Biggest reason cars go back to the shop are not the drivetrain, but all the widgets. The widgets drove MB and BMW way down in the quality surveys, not the drivetrains The newest marketing trick by GM is just to state higway milage in thier ads. I think subarus are nicely equpied. Compare the base models with anything else in thier class. There is no comparison. nipper
torque bind?
nipper replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Did you driv in left circles 8 times then right 8 times after the fluid change? I had the same thing after a fluid change, did the circles, and it went away. Aparently it lossenes up whatever gunk isthe fluid flush didnt get since the car was not running when flushed nipper
