montana tom
    12
Everything posted by montana tom
  1. The gold tooth thing needs to come off the threaded shaft. Vice grips from the top , wiggle and pull... might need to pry up from the bottom at the same time.
  2. Nice build, thanks for sharing. I will say that currently I like the look of your buddy's wagon .
  3. Sounds like fun... throw some of those bikes up on the roof. Mount your rear hitch high for ground clearance. Heck throw a hitch on the front as well ! As everybody has said "It Won't Last ! " But who cares.... your doing this for the hxll of it . Look at some air bags for the rear , airum up if you need more suspension. Larger tires cost more money... forest service roads tear them up. Use whats cheap and readily available. I have heard about dual range trannys for that year coming out of japan.... you could really cruise in low range... HAVE FUN ! EDIT; Oh yea... if you remove the back hatch and drive up a dusty dry mountain road you better have dust mask's for everyone to wear...
  4. Just replaced the purge valve on a 04 obw. Same symptoms, poor running after fueling. It had larger size vacuum lines than the earlier years, electric plugs were the same. On the 04 the valve was easily accessed... on the 02 & back it is on the bottom side of the manifold, slightly harder to get to. This valve is normally closed , you should not be able to blow thru it. There are 2 vacuum lines going to it , one with direct manifold vacuum and the other is the smaller line running next to the fuel filter. Disconnect the vacuum lines and see if you can blow thru it or not. If you can replace it! If you can't then it "may be OK " I would buy this from a wrecking yard that I could go to... online .... up to you. Look on your local craigs list for somebody parting one out.
  5. Good point Fairtax , I never even considered the different axles... For a clutch I always pull the motor out instead.
  6. Jeff , start at the rear hatch. That year group is known for broken /shorted wires, coming from the body to the hatch. The rubber tube connecting roof to hatch should be peeled back and wires inspected... hopefully you'll find your short there.
  7. Same Job , you won't run into anything new. Make sure to put a quality clutch in , like an exedy. I just put one in an outback the other day ... $176.00 delivered from ebay.
  8. If you just snapped the bolts they may come out very easily . Do it right ... remove the pump and deal with those bolts now. Imagine if it starts to leak on your 20 mile drive ... what if it pumps all your oil out in a minute or two ? It's not worth the risk.
  9. When its important to have the right part , I buy my subaru OE gaskets from subarupartsdirect on ebay average cost on head gaskets is about 75 bucks
  10. Most likely they stripped the bolt or just over tightened it and walked away... Some people should never touch a wrench. Pistons should be fine, new head gaskets, new valves and seals and you should be good to go. Oh yea you'll have to give your mechanic a pail full of $ as well...
  11. Tensioner bolt snapped while running ??? never heard of that before. Yes most likely you have bent valves. Amazing it runs. Do a compression test or pop a valve cover and see if the valves are staying compressed. The section of the block where the tensioner mounts is replaceable.
  12. Hmm, in that case they put in a mph speedo with a Celsius temp gauge . No difference, buyer is happy his speedo is mph and could care less that temp is Celsius.
  13. Finally got a look at the trans # on the Canadian 02 obw After a little searching "TZ1A4ZCDBA-RM" Is the same transmission used in the us cars. 4:44 differential . I'm curious that if they replaced the instrument cluster to get a mph speedo , then why the Celsius temp gauge ? I'm wondering if the Vancouver , BC market gets mph speedos because of the proximity to the US ??
  14. Easy to overfill a subi automatic. My guess is the seller thought it was low when not heated up so he added and ended up over filling. Overfull tranny will leak but usually at the tail shaft. Clean up the mess and find where that oil is coming from.
  15. No on the 3.0 and interestingly enough the speedo is mph with kph in the back and the odometer reads miles. But the temp is in Celsius ...and the under hood sticker says Canadian emissions ? Odd ... I don't have the car here as its sold, so I will have to get the tranny number as soon as I can. I do remember it matches the vin plate #. I will try a goggle on the tranny # asap.
  16. Hi guys; Bought a 02 outback wagon recently. This car was produced in the US but was built for the BC market. I'm wondering about the final drive ratio. This car has lower rpm readings than any other automatic US outback I've driven. 75 mph and its pulling 2000 rpm's... all others run closer to 3000 rpm... Tire size is stock outback 225x60x16 ??? Did produced for Canada outback get the 4:11 final drive , like a US legacy ? All the US outback's seem to have the 4:44 ratio... How can I decode the tranny code or the rear diff. ? With the current set up this car is getting 29-30 mpg ... much better than my MT outbacks that run a steady 26-27 mpg. Customer is wanting a replacement tranny and I want to confirm things beforehand, any help is appreciated !
  17. I would source another crank gear rather than trying another repair. Does the comp show any codes ? In Australia you are offered different options than we are limited to in the US . Twin turbos ... diesel engines ... they even have slightly different names, but they are still all subarus under the sheet metal. I don't think the outbacks here used the coil igniter at all,(i could be wrong) I remember them on 90's impreza's . Many others out there with more knowledge than me about electrical issues ,hopefully one of them can help you.
  18. I suspect the crank gear with the broken / repaired tooth. Also the left side cam gear must match the ecu. Crank gear and cam gear must stay with the ecu.
  19. Upstate new york, late sept... Did you have the temp turned up for winter ? We have gone from raging fires to snow on the mountain. Check the things suggested by Imdew. Have the codes read on your car (auto zone) its possible it's not even coolant related.
