montana tom
12
Everything posted by montana tom
Sunroofs and subarus seem to be nothing but trouble. On our 2001 obw limited it leaked , after much grief, it was the body seams under the headliner... good grief ! Now it does not leak but recently it started this new trick... front sunroof opens fine... just won't shut... SO if you keep trying to open it will now open the rear sunroof ... wide open, real rain catcher! .... then will not shut either of them , after both are open if you hold your tongue just so ...lift your right foot an inch... it will shut both properly GRRR Wife and I have learned to leave it alone but anybody else that gets in has to try it out. Point of the story LEAVE IT SHUT and disconnect the power to it !
Start with what year and model you have. Seems to me you unplugged or... broke something when shoving the tweeters into place. Only answer is take it back apart and hope it is just unplugged.
- 6 replies
- climate control
- issue
(and 3 more)
Tagged with:
On my 2000 obw , I had to buy a complete driveline, Unless i wanted a wrecking yard one shipped in for $$$ . On my 94 legacy I sent the driveline to a shop and they added greasable, replaceable u joints. Could be the same for a 98. Same driveline shop said it couldn't be done on a 2000 + I needed a new driveline. Give a driveline shop a call and ask , could be you could just repair your shaft. Highly doubt an impreza shaft would be the correct length. I don't believe a 2000 up would work either. Someone else may have direct experience with interchange. Good luck
Sounded like you are familiar with wrenches... if so you can do this yourself. watch a few videos to gain some insight. Tear down the motor yourself, fair chance the crank will be ok , rods may need resizing on the big end. Apx $100 or so. have them check your crank for sizing. buy correct size bearings for it. You said motor was fine other than pressure ... if you don't want to change them, chances are your rings are fine ,allowing you to leave the pistons in the bore. Some good new head gaskets, reuse intake & exhaust gaskets , same for valve covers. I wouldn't bother replacing the head bolts , just the sealing washers on the 6 large case bolts (they seal the water system from the oil) and as stated very important to replace the case O rings. Not all shops are truly familiar with subaru motors, if it were me I would do it myself.
It should be the rods not the mains.But change out both. Be sure to order half block o rings and case bolt sealing washers before reassembly . Here is the link for them on ebay 142038603617 and 131655496434 same company, subaru parts online. You will also want a tube of ultra gray for sealing the case halfs.
As somic said rock auto can send wrong parts. Look closely at your original connector ,compare it to the picture of the new one, if the connectors match you will be ok. I bought one for my 2000 obw recently... no problem with fitment, even got the cel to go off... 3 weeks later its back on, same code. Thank goodness montana does not have emission testing .
Find a bolt with the correct threads and plug the petcock hole, you don't need it. To drain, remove lower rad hose at thermostat housing, Messy but fast. To refill connect lower hose & remove upper hose from radiator. Pour antifreeze directly into upper hose until antifreeze is at upper hose (your block is now full) connect upper hose to rad, then fill radiator.
Look for and watch several youtube videos on splitting & reassembling the case. Biggest problem I ran into was the case bolts are really on there, Had to use an assistant to hold the case and a very powerful 1/2 " impact to get them free. Metric allen wrench (large) can't remember what size, you'll need it to access the piston pins. Small internal slide hammer is nice for getting the pins out but can be done without. Regular piston ring expander, and ring compressor. Plastic gauge to check bearing clearances. I'm sure others will offer additional tips.
IF it is the bearings then the oil pump will do next to nothing. Sadly subaru bearings are not all sized the same ... you must disassemble to find out what size they put in yours ....crazy... If the rods haven't spun then good chance the crank should be ok. Really LONG day to split a subi case and do a rebuild and reassemble, they definitely are not a chevy S.B.
Hate to say, but low pressure usually ends up being bearings. Having said that, for apx 154.00 bucks you can get a brand new subaru high volume oil pump on ebay from subarupartsonline ( 131638875556 ) Yours should not be weak after only 150,000 miles but it could be. If it is bearings and you choose to rebuild then having that new oil pump will be money well spent.
You probably won't be happy with a 2.0, they work well but need lots of rpms to do what the 2.5 does, standard transmissions work much better than an automatic with this swap. Not sure about the manifold swap. Rather than ebay just search for japanese takeout motors (same ones on ebay but hopfully closer to your home) I'm sure that a large city near you will have an outlet. Best choice if you like your car and want another 250,000 miles is call (colorado component rebuilders)(http://ccrengines.com/ these are not cheap but are a quality rebuild by a shop that only rebuilds subi motors.
- 7 replies
- Japanese engine
- 2.5
(and 2 more)
Tagged with:
In the past on ebay I found and bought a complete set of japanese made valves for about $65 ... pop them in smooth the heads and bolt them up.Beware the (kits) that sell everything you could want...gaskets, valves, guides , timing belt ..... most if not all are china junk. Or check out the japanese take out motors. They are readily available on the coast. Install the whole thing or pull the heads and save the short block.
VERY Good point about the MAF, and oiled filters, i had never thought of that.. My 2000-2001 obw's both have K&N's but no maf. 987687 is correct about the hot air in the engine bay... won't matter when your doing 100 mph but at idle and in town it won't help, will hurt. Find a way to plumb the outside air to that filter and it will help. Oh and throw a set of headers on that...if your hot rodding it.When you make it get more air it needs to exhaust as well. And then of course you need cams then nitrus oxide...then ....a lot more ! But before all that put a roll cage and a 6 point racing harness in it... fast cars eventually crash.... LOL sorry , its that old thing again... good luck have fun!
Ugly ? no .. looks like a subi motor to me... I see that it has an upgraded air filter on it. If that is a K&N filter they work great BUT... you must clean and oil it regularly or it it will plug up ... I have seen several people install a k&n (lifetime) filter and never look at it again... its lifetime right ? NO, its not unless you clean and oil it. These same people wonder why there motor only lasts a short while then seizes up. Sounds like you are looking to hot rod this car ? Talk to the folks at colorado component rebuilders. They can tell you what will work and what will just come apart on you. Adding a turbo to this car could be done but it will be a large hassel. Locate a wrx or an sti car already turboed and make it scream. Keep your impreza to go to parts store, then if the hot rod blows up you can still get around. Having said that when I was younger all I did was build and drive hot rods no grocery getter for me... guess i've gotten old... If you want a hot rod, build it , they are expensive but great fun.
Can't say about where in el paso, but what you may want is a japanese take out motor. Low miles, relatively cheap. You swap all the externals over from your original motor. If not that then another option is to go with a complete rebuilt longblock, from a reputable rebuilder like colorado component rebuilders (http://ccrengines.com/) That will get you a motor that should last a good long time. Craigs list for crashed cars or last choice would be a wrecking yard.
My experience with subaru rod knock is, Noticeable clatter at first start up...in yard at apx 3000 rpm noticeable knock . also if you listen closely while driving you should hear the same knock at certain times ( when engine is floating). If this is a jap takeout, it has a warranty. They won't pay your labor unless an extra policy is paid for but they will replace the engine. I have installed 2 dozen or more of these mainly in subi's but toyota & nissan's as well. Only got one motor (toyota) that threw a rod thru the block. Was replaced with hardly any questions asked.... they even let me keep the blown motor (had a perfectly good head) . They can look bad and you have to follow their instructions on removing and replacing everything but compared to a pull and save motor that you have no info about nor a warranty other than if it doesn't run bring it back... I will recommend a takeout motor every time.
2.5 L is a 4cly. Shaking and sounding like a diesel is definitely not normal. Could be any number of things causing it to shake. Depends how much they want for it. 2002 with 60,000 miles if its not rusted out yet & the price is right ... could be a good buy as long as you are equipped to diagnose & fix it.
Floyd; Hopefully it did not get it too hot or there could be head gaskets in your future. Subi's use a heavy duty thermostat that rarely fails. Hopefully you popped a hose for some reason. There are several nearby that could be the culprit. Easiest way to locate a leak is with a cooling system pressure tester. If you don't have access to that, then a poor mans tester is to fill system with fluid... and have your assistant squeeze first the upper rad hose then the lower while you lay underneath getting antifreeze all over your face, looking for the leak. lol not fun but it does work. Remove any skid plate/plastic covers that are in the way , dry everything you can. Add water, if it is a busted major hose it will pour out. If it is say a heater hose then you will need to squeeze to get pressure there. I should mention that the quickest easiest way to fill a subi cooling system up is to remove the upper rad hose from the radiator, pour fluid directly into the hose until the engine is full ... then reconnect hose and finish filling from radiator. Good luck I'm sure others will have other suggestions to help.
- 2 replies
- coolant
- 2010 impreza
(and 1 more)
Tagged with:
one of the starter bolts is an engine/tranny bolt. YES the torque converter must be unbolted from the flywheel , use the inspection hole behind pass side intake manifold, the tranny must be raised , the dog leg removed . I have used a large dull flat blade screwdriver to help persuade engine and tranny to part ways. stuck guide pins are usually to blame be sure to put a swipe of anti seize on them for reassembly.
