Everything posted by subynut
Superlite Wheels
Yeah, how much and is the offset right? This is good news!
how does your RX drive?
Don't know how mquch of this applies since mine is a wagon and part time 4wd, so it only applies to dirt. Before I put the LSD in, I had a fair amount of understeer going in and out of the corners. Now she feels more neutral, doesn't want to over or under steer. Just kinda goes around the corner. I can induce a slide with a quick stab of the brakes to start sliding, then jump back on the throttle to straighten out. Kinda hard to 'splain. 180? Start tuning, jab the brakes to get sliding. At about 90 degrees, hit 1st, stab throttle, and aaarrrroounnnnd we go! WEEEE!!!
First lifted run (PICS)
Ha! Try driving though a rock garden or REALLY soft sand. 4Lo ain't low enough even with my 185/80 13s. Singletrack, Great looking wagon! Looks very nice!
Pedal assemblies are the Devil!!!
Yup. He's right!^
rich fuel mix
Any codes? CEL on?
gear oil Q
Yup, dat's what I use. Are you changing the fluid? If so, then U need to add that LSD additive: Posi-trac or somthing to that name. Said it was for Posi and LSD.
Temp Gauge reading on EA81??
Mine runs about 1/2 with the Subaru T-stat (190). After I put a REAL guage in, she runs about 210 in stop and go traffic and the efans running. Out on the hiway doing up to 60, both fans are off and reading about 205. Flat out driving, around 210-215. Granted, this is an EA82, But it gives ya an idea.
squealing GL 10
Yup, dat's it.
tire size with pug wheels and r&r transmission
My brother is running 195/60 R14s on his and he has no rubbing at all. However, he has not fully loaded it yet. Dunno, does two 100lb dogs in the back count as fully loaded?
I did it! Pics to prove it!
That is CUTE! I like it! Wow, 26" tires? They look little, but grearing is a major factor to tire size when U cant change the R&P. :-\
Subarus rock!!!
Yup, Gotta love those Subaru engineers!
suspension lift not body
Yeah, my original struts had the adjusters on them. I had mine all the way up. Went through CV axels about every 3k-5k miles! That's with almost all hiway miles with a Sunday afternoon off road trip in the mix!
I'm back for now....
Ahhhh......THERE U are! I was just about 2 send U an email.
oil adapters and seat brackets
Yup, it'll work. Subaru uses the same oil filter for the EA81, EA82 and ER27.
Took her out on the freeway....WOW
Advance is running off the port on the carby. Checked the mech. advance, that is working. Vac advance is operating also. Tryied running the timing at 20 deg STILL no pinging! However, the tach started jumping a little at 20. So, I dropped it a little ( Don't know how much, didn't have the t-light attatched) and that solved that prob. Intristing, very intristing. She is running rather rich, don't know if that makes any differance or not, just thought I'd let ya know. I did pick up some jets and hopfully will get those in today and see what that will do.
Took a trip up to Tucson today. Ran her flat out a few times, 95 easily! Most of the time I was just using the primary, just used the secondary when I need to accelerate quickly. Didn't use 4th at all; 5th gear the whole way! Happy RPM range is 3k to about 4.5k. Well, with the exhaust and carby setup I have at this point. Running 14 deg timing and havn't heard one ping! I How far can I go? Vac at idle (750 RPM) is about 16Hg; up in Tucson, I saw 19! This engine ROCKS!
Reverse RPMs?
Sounds VERY electrical. Check ur connectons and as much of the wiring U can see. Make sure they're tight and no corrosion. I'd start there.
ACK help me decide on an oil... to many choices!
Castrol GTX or Valvoline; for a turbo, 10w-30 is what I've read.
XT6 Dyno results with Dynomax Ultra Flow SS Muffler
Definatly sounds meaner. Sounds like the throttle response is a little quicker too. Looks good.
WOOHOOO!! New engine in and running!
Well, took her off road today. Wow, what a differance! I was crawling along around idle with no pedal effort and she just kept on puttin along! THAT'S the kind of torque I was looking for. No more step on the gas, just get over the hump, jump on the binders style of driving. Out on the hiway, she just cruzzes along happy as a lark. I do have a hiccup just as I open the secondary and I had to turn the idle speed in about a turn and a half. So, now it's operation tune the carb. Who's the best place to get a jet kit?
Wiring Fogs to brights
Yup. Fogs are for seeing the road right in front of U whereas the driving lights or pencil beams are for seeing a LONG ways down the road.
CD's with around 300 WCSS 6 Pics
Got mine yesterday. Yes, those pics are cool! REALLY wish I coulda gone, BUT Suby had other plans. Anyways... I do have some problems reading the last three directories. They eventually show up after about 20 seconds. Hummm
I'm jumpin off the walls!!! Me suby is back on the road! Yippee!!! Ordered an engine from CCR and FINALLY got it in and running. Biggest hangup was needing parts and having to order them. Like, engine and tranny mounts. Get this: Checker was the only place in town that could get the mounts. BUT the engine mounts took 5 days to get and the tranny mounts took overnight to get. What gives? The other tricky part was getting the ditsy lined up correctly. Anyways, Suby's running again and I no longer have to drive that van anymore. Oh, I suppose U'd like specs. yes? Carbed EA82 longblock, SPFI pistons, decked heads (I forget how much), Delta torque cams, new clutch, and new disty. Oh, and I also put Limited Slip in the rearend too. Now all that's left is exhaust, I'm thinking duals, and tweaking the carb. Took her for test drive around the block and I definetly notice an increace in lowend torque. WOO HOO!! Thanks CCR!!
Noah, U DID get my PM, yes? I thought I put me address in there. Hummmm....
Call me Crazy!! an XT6 on Solid Axles????
Looks good! REALLY good! :clap:What's all attatched to the frame? Just the transfer case and axels? Or did you mount the engine and tranny to it too? Would like to see some close-ups of that setup, please?
