Scott in Bellingham
Everything posted by Scott in Bellingham
  1. I could help with the machine work
  2. Ive been looking at some of the redrives mostly the belt type , I think it has potentual, one drawback is its one gear not a hi or low
  3. Adam if you need any help ( machine work, welding etc. CAD drawing ) I will volunter myself and equiptment Scott
  4. you are correct,. that said if someone wanted the rear axle moved back I could fab up a custom lift with your specs: of lift, increased axle angle and axle placement also you can choose which componants you want on your lift which will give different results, say you want high clearance , then you would want to keep the rear cross tube and diff up high which would resolt in the swing arm swinging down causing a clearance issue at front of tire, now if want to keep everything at stock geometry the you would lower every part equally , this will keep the wheels centered .also it may be possible to put a spacer between the u-joint flange and driveline to prevent having a custom driveline built
  5. heres a few I have had no faliure to date , pictured is the compopnants for a 6" lift , the 3-1/2" lift has less parts
  6. 85 hatch junk 85 ea82 wagon chopped up for pattern making 88 wagon lifted runs 91 loyale cooked engine 88 turbo wagon runs , may become the ultimate offroader 87 ea82 wagon stock daily driver 90 Lagacy wagon fires , working on this one 7 total 3 run 4 dead 2 others at my place but they are not mine
  7. the spare 15 rim is made of thinner material , also it has no bead ridge that helps lock the tire onto the rim
  8. Go Rollie Go !!!!
  9. good luck, your not the first guy who thought this would be a great idea, , you would only need one with a locker, what most guys do is remove a axle for street driving, takes a few minutes and 2 roll pin removale
  10. maybe it could be a Creepie Crawler
  11. so if you add a nissan transfercase with a 2:1 ratio your final crawl ratio would be 44
  12. I keep seeing this term, "Crawl Ratio" now how is it figured out ? is it the low dual range gear x 1st gear x diff ratio ? what are the stock Soobs? what is like the ideal ratio for offroad?
  13. Rollie try this http://www.dnr.wa.gov/dataandmaps/maps/pdf/walk_both.pdf its a DNR ORV park , Ive never been there , heard lots about it
  14. now that Northfork is closed:( we need a new spot to play , I would like to check out Walker Valley near Mt. Vernon WA , understand its a area were you would need a lift and tires, would like to go out maybe after the new year , whos up to it? , would be good to have a winch along and some experiance , maybe theres a few thats been up before , maybe even a Jeep or a Truck , it should be fun. SJR
  15. Echo papers a good spot also rods Japanease Auto on the Guide , good Luck , keep us posted on your mods SJR
  16. I have a 87 ea82 SPFI 5sp dual range car tag 12/86 the computer I think gave out, the red LED doesnt come on , I have no spark , the car was running fine then just gave out, now I was wondering which computers will work out of which cars, I have a good comp from a 91 Loyale , it gives off flashing codes but still no spark, I noticed bunch of numbers on the ECM which ones are important and what exchanges with what? the original ECM has a big "N" on it also 22611 AA200 MECF-011 , 6Y24 3E thank you Scott
  17. Im running the ssr tsl 27" swampers they are way cool I was suprized at how quiet they are I am running 24 Lbs on 15 x 6 toyota rims off road they are King
  18. you should be able to get by with 1" - 1-1/2" extra , no more
  19. on the Nissan pickup whats the gear ratios for the diffs and is the diff the same outercase as the soob?, I know the axle shafts are beafier and bolt up with flanges , the case looks similar, if the ratio is the same as a soob I was thinking of running a front nissan set up in the rear of the soob , also whats the ratio in the transfercase? Thanks Scott
  20. James regardless of where and when the WCSS8 will be I think it would be cool if we (the subaru offroad community) could set up some type of compitition , more specialized toward ,rally, offroad , , there could be a hill climb compitition, mud bog compitition, , rally course ,, technical course , car show aimed towards "Offroad" , etc., ect., something for everyone who likes to take thier car and skills to the limit offroad, if we get organized thier could even be a event every other month or every quarter, up and down the coast, one meet could be in NW wash another SW WA , another in NW OR, and so on , the kick off to get the interest and ball rolling could be held at the AA Factory with all its amentities Scott
